10-16-2019, 11:01 AM | #1 |
Rep 77
Super pro arms
When do you think these arms will go on sale for our F3x?
At the moment they are for series 1 and 2. https://mp-uk.com/choose-your-car/bm...2-e87-e88-all/ |
10-16-2019, 11:58 AM | #2 |
Rep 681
Superpro bushings haven't holding up well in the LCA on f3x. Mine was completely cooked after a couple thousand miles. I'd inquire if superpro plans to make them more robust to lateral movement because the LCA bushing is susceptible to more than just vertical movement that the poly was designed for.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
10-16-2019, 02:35 PM | #3 |
Rep 128
The link is for the E series chassis. When the F series stuff comes out, the same part will fit 1, 2, 3 and 4 series.
I will keep repeating the same thing: - SuperPro have pulled the LCA bushings from their store. They have recognised the PU prematurely fails in that LCA joint. - the above product linked by the OP is for the full LCA and tension arm replacement kit. SuperPro have already prototyped these and are waiting for manufacturing capacity to release them. They are based off the Lemforder F80 arms. I have the prototype on my car. Graham (SuperPro CEO) personally delivered and oversaw their installation to replace the failed bushings. |
10-16-2019, 03:15 PM | #4 | |
Rep 681
Another note is that if the new arms are based on the f80 arms, then that's a non-starter for xdrive cars as the the f8x arms offset the carrier to the point where axles slip out.
2006 997.1 C4S |
10-16-2019, 03:19 PM | #5 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Is the LCA part a monoball? The E-series part looks to be from those photos.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
10-16-2019, 04:01 PM | #6 | |
Rep 128
The UCA/tension arm will have a PU bush on one end where the "M" branded OEM parts use a harder rubber bush. So basically, if the "M" branded stock F80 arms use: - a monoball (LCA), the SuperPro version will also use a monoball. - a rubber bush (UCA/tension arm), the SuperPro version will use a PU bush. |
10-16-2019, 04:03 PM | #7 | |
Rep 128
And yes, all this development is for RWD cars only, as far as I'm aware. We don't get X-Drive in Australia. |
10-16-2019, 04:44 PM | #8 | |
Rep 77
Why use pu when M don't use it? |
10-16-2019, 05:31 PM | #9 |
Rep 681
That's what superpro currently offers for their standalone LCA bushing. It looks like SuperPro Aus is working on a monoball solution for the LCA for sDrive cars. So hopefully you have an sDrive car and not xDrive. Otherwise, other parts of the world still seem to selling the PU standalone busing from SuperPro (which is what I would avoid for the LCA).
Edit: Oops, I misread your comment. f8x uses a PU bushing still in the tension strut/UCA. That's what is available for other aftermarket options as well and they hold up without too much trouble. Its moving from a monoball/liquid filled bushing to a PU bushing on the LCA that's an issue. One which they're addressing for sDrive.
2006 997.1 C4S |
10-16-2019, 05:34 PM | #10 | |
Rep 128
Why upgrade from rubber subframe bushes to PU bushes?
Why replace any rubber part with PU? Because PU is better for performance than rubber. It was just very unfortunate that PU was not suitable for use in the LCA joint due to the rotation. Quote:
