10-22-2019, 10:00 PM | #1 |
Rep 8
Billstein b14 coilovers
Hey guys, I put on Billstein B14 coilovers about 2 months ago along with a new wheel setup.
Im wondering if you guys have any suggestions on how to make the coilovers sit lower.. I expected them to drop the car more but I've still got a bit of a wheel gap in the back.. Car is a 15 335i xDrive for what it's worth.. TIA! |
10-23-2019, 02:39 AM | #3 |
Rep 8
10-23-2019, 02:44 AM | #4 |
Rep 10,304
@CitrinMetallicF30, coiuld you please post pictures of front and rear wheels and close ups showing wheel / fender gap?
10-23-2019, 06:31 AM | #5 |
Rep 128
Are you certain they were installed correctly?
You can actually remove the rear adjustable spring collar entirely - and this will drop the rear another inch. As above, post some photos. |
10-23-2019, 10:53 AM | #6 |
Rep 8
Here's a few pictures[IMG]undefined[/IMG]
10-23-2019, 10:55 AM | #7 |
Rep 8
I believe they were installed correctly.. I've heard about this piece you can remove, what does the component look like?
10-23-2019, 11:04 AM | #8 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
You can switch to shorter springs. Just have to verify that the dampers can't bottom out (which you can prevent with shims).
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
10-23-2019, 11:54 AM | #10 |
Rep 8
10-23-2019, 11:56 AM | #11 |
Rep 8
10-23-2019, 10:11 PM | #12 |
Rep 8
Just too add, here's a pic of how the rear coils are installed.. not the clearest photo but maybe some people more knowledgable could identify if there's any issues here or if they look improper
10-24-2019, 12:18 AM | #13 |
Rep 3,540
Looks like your rear spring isn't installed correctly. The spring cup at the top should be removed and replaced by the height adjuster. Your spring is also upside down. The bound coils with the ground flat end of the spring should be on top against the adjuster. This is why you can't get low enough in the rear.
10-24-2019, 01:38 AM | #14 |
Rep 128
As Farkle said, it's been installed incorrectly.
This is what they should look like. The adjustable spring collar is the silver and black part at the top. |
10-24-2019, 09:52 AM | #15 | |
Rep 8
10-24-2019, 11:16 AM | #16 | |
Rep 3,540
10-24-2019, 12:10 PM | #17 |
Rep 1,934
The photo of your car actually looks perfect. Do you know your ground clearance or Fender To Ground measurements?
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
10-25-2019, 11:17 AM | #18 |
Rep 75
Heres a pic of the final on mine.. they did settle.. but its as low as it will go.. included a pic of the subframe out for your reference if that helps...
2014 F30 N55 EWG - BigBoost 3.3 Turbo Kit - N52 Exhaust Cam - BPC MILV - ER FBO - AFE Momentum CAI - XDI-35 - MPE w Carbon tips - MHD Custom Tune by efi_bob at Stage Fabrication - 19" Apex Arc 8 w 255/35 square - Bilstien B14 Coil-overs - GC Camber plates - Solid Sub-frame bushings - Powerflex Diff Bushings - BMW L/S Diff - XHP Trans tune -600whp 511wtq on pump 93 with Meth PI
10-25-2019, 02:54 PM | #19 | |
Rep 128
- do you run all four (I can only see three in the photo)? - how are they in terms of additional noise and harshness? I've been looking everywhere for feedback as no one in Australia that I know of runs them! I noticed you're running subframe and diff bushes (although I can't tell what brand). I too am running Superpro subframe and Superpro diff bushes. I was hoping to see whether the hard race rear arms are overkill. |
10-25-2019, 03:32 PM | #20 |
Rep 3,540
Your rear springs are upside down in the subframe photo.
10-25-2019, 04:47 PM | #22 | |
Rep 75
