08-26-2008, 11:02 PM | #1 |
Rep 2,067
Best Nike Running Shoe?
I am torn between a few shoes and need some advice.
My main concern is comfort/cushion then support. I don’t really care about the looks too much. I weigh 155lbs but plan to drop down to 140lbs if that matters. I am deciding between: 1. Air Pegasus +25 2. Air Zoom Vomero +3 3. Air Zoom Structure Triax +11 Other recommendations welcome I plan to do anywhere from 10-30 miles a week. |
08-27-2008, 12:07 AM | #3 |
Rep 61
This is coming from someone who used to be very very heavy into the running shoe market and still keeps up pretty well. I sold running shoes at a high end runners store for about 4 years and was one of the top guys in the nation. This is one thing I know very well.
In general there are very few Nike running shoes I would recommend, however you pulled two of them into your list. The Pegasus and Structure Triax are both good shoes from Nike. That said they are fundamentally different. The Pegasus has always been a straight cushioning shoe for a light weight runner (which you are) but the structure triax is typically built for a more mid to upper weight runner who wants some stability (motion control) in their shoe. The Triax is typically built for someone who over-pronates, or tends to roll their foot in at a faster rate through their natural stride and pushes off on the inside of their foot. If running is something you plan to do with some consistency I heavily suggest you get yourself into a runner's shop and bring in an old pair of running shoes if you have any (if you don't then take in a pair of shoes you were around a lot). They should be able to look at both the wear pattern on the bottom of your shoe as well as your natural gate in the store to determine if you need any added support (motion control) in your shoe. That would help determine if a shoe like the Triax (built for stability / over-pronation, motion control) or the Pegasus (built more for cushion and someone with a neutral stride). I am not sure why you are only looking at Nike but I always tell people to look at a few different brands. Not sure what you tend to like about Nike but most people it is usually the softness and the weight. I will warn you now that softness doesn't equal shock absorption (which is what you actually need running) but the shoe should feel comfortable, many (especially a lot of Nike) are too soft to do any real good. If it is light weight and softness you like in the Nike I would highly suggest you also try on something from Brooks and Mizuno, maybe an Asics as well. A New Balance or Saucony (the other major running shoe brands) will probably be a little firmer and heavier than you would like. I personally run in mostly Mizuno but do have a few pairs of Brooks and Asics that I use. I don't like to run in New Balance but love them for everyday wear. Saucony have never fit my foot right but work great for some people. With the mileage you are looking at you want to get a decent mid-upper level shoe. Assuming no sale prices (which you can typically find looking for the previous year's models) plan to spend in the 74.99-89.99 range. Those will more than meet your needs. However, if you want to take care of yourself and feel a little pampered the upper-ends are in the 99.99-134.99 range. A lot of the upper end shoes will actually be built for people a little heavier than you but there are a few that are made for someone smaller. In general you will be gravy in the 74.99 to 89.99 range. I just realized that was a wall of text but it should really help you. Can't tell you what is better for you without the ability to determine a little more about your natural stride. If you need suggestions on things from the other brands let me know and I can try and outline. But seriously find a reputable store and get in there and listen to what they have to say. Your drive a BMW so I trust you to be intelligent enough to know whether you are talking to someone who is throwing bullshit or knows what they are doing.
325i 6MT, Mystic Blue, Beige w/ Poplar, Premium Package, Navi, Comfort Access, Xenons, Heated Seats, Satellite Prep (for when I want to go back and add Sirius)
08-27-2008, 12:10 AM | #4 |
Stackin' Chips
173
Rep 608
+100000000
Adidas running shoes FTW! Adidas Supernova Cushion is excellent for running, your feet will thank you!
08-27-2008, 12:40 AM | #5 | |
Rep 2,067
I highly appreciate you taking your time to write your reply, it has a lot of useful insight. I really do need to get into a specialty store however I am in a small town in the mountains of Colorado till October. When I get back to Florida I will try to go to a shop and get something more tailed for my actual foot. I read a lot of people recommend having two pairs and switching off to save wear? I thought about it more and I realistically want to start off running 2-6 miles 3-4 times per week then eventually up it to 5-10 4-5 times per week. December 7th I am doing the 1/2 Marathon of the Palm Beaches. I understand you are very well qualified so perhaps if you have any extra time you could send me a few links (reviews/purchase) to some shoes you recommend. My body type is 5'4" currently 155lbs but going to trim down to 140lbs. Muscular body style. |
08-27-2008, 01:05 AM | #6 |
Rep 26
I was also looking for running shoes a few weeks ago. This helped me get started:
http://www.runnersworld.com/cda/whic...-0-0-0,00.html I ended up buying these: http://www.zappos.com/n/p/dp/33892425/c/122141.html |
08-27-2008, 12:04 PM | #8 |
Rep 4,959
If you want the best running shoe period, go with the Asics Gel Keyano 14. Hands down the most comfortable running shoe I've ever worn.
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV Gone: '20 W205 C43 Sedan Gone: '18 W205 C43 Sedan Gone: '13 W204 C63 Sedan |
08-27-2008, 12:32 PM | #9 |
Rep 5,319
I think Saucony makes a good running shoe.
08-27-2008, 12:58 PM | #10 | ||
Rep 61
Being loyal to a brand is fine but I always suggest trying another just to see the difference. I never intend to bash Nike as they do make some good shoes but in general they are more fashion focused than the other brands who are pretty dedicated to their running line (it is where a huge source of their profit comes, not so for Nike). As I mentioned below poke around on RunnersWorld a bit. Their word is not the authroity but they can definitely head you in the right direction. Reading reviews on the site you purchase from isn't as good as from somewhere that is solely dedicated to running and comparing all of the shoes. It is nice to be able to rotate shoes day to day but it is not a necessity. Any running shoe is going to begin to breakdown on average between 500 and 600 miles. That just means if you are rotating shoes the two last you for a longer time but you will get the same milage out of both. Also, I could not recommend any more strongly to make sure you buy some decent running socks and to preferably replace the cheap insole in whatever shoe you buy with a replacement performance insole (usually $10-$20). When you lose that "new shoe feeling" is the original, very thin insole breaking down in the first few weeks. I good replacement insole with come close to double the shock absorption of the shoe, make it feel more comfortable, and should last you through about 2 pairs of shoes (1000-1200 miles) on average (so you shouldn't have to buy a new one with each pair even though some like me will). Quote:
RunnersWorld is a good place to start and get general ideas of shoes you might be itnerested in. However, don't settle in on their Editor's Choices, generally they are good shoes but some are overrated and I think while they try to be as fair as possible I don't think they can give some brands the ratings they deserve sometimes because they need to keep everyoen involved. This is absolutely true. I have ordered shoes online several times but almost always have tried them on in a store previously. The only exceptions to this have been shoes that the manufacturers tend to never really change (ex. the Asics Gel Kayano posted earlier) but even then I have had to return to change sizes every now and then.
08-27-2008, 01:00 PM | #11 | |
Rep 61
Saucony does make a very good shoe. However, most of their shoes are cut for a particular foot shape (last) that doesn't work for everyone. Their cusionhing system (Grid) is also sometimes a little to stiff for some people.
08-27-2008, 01:14 PM | #12 |
Rep 117
Listen to wrestleSBA. You need to know what type of foot you have and get the appropriate shoe for that type. No shoe is good for every foot type. If you can't get to a good running shoe store to be evaluated then use the Runners World guide. Dip your foot in water and step flat on a piece of paper. This will give you a basic idea of what type of foot you have. Good luck.
08-27-2008, 01:16 PM | #13 |
z4um Hooligan
153
Rep 586
This is the brand to go for. They are the best when it comes to comfort and cushioning. I find that the Nike brand is very overrated and played out. Other brands worth checking out are New Balance and Asics.
Charles
flickr |
08-27-2008, 01:45 PM | #14 | |
Rep 4,959
08-27-2008, 02:23 PM | #15 |
Rep 7,719
I do agree with some posters that say running isn't Nike's forte. My step dad loves Saucony shoes, he runs 10-15 miles a day and finished 10 L.A. Marathons.
The only thing that Nike has on lock is the basketball category. |
08-27-2008, 05:19 PM | #17 |
Rep 7,719
10-17-2008, 08:32 PM | #18 |
Rep 2,067
I went into the running store today. They said I have some over pronation. I ended up going with the addidas supernova sequence. I tried on a 9 and needed a 9.5 so they ordered the shoe for me. They felt light and supportive, whats your opinion on those?
10-17-2008, 09:01 PM | #19 |
Registered Sex Offender
597
Rep 4,757
Nike Free 5.0
Totally different from anything I've ever worn. If you haven't, try them. It's like you're barefoot but it doesn't hurt.
Stop putting stuff like painted reflectors and premium package in your signature. You're embarrassing.
10-18-2008, 09:27 AM | #20 |
Rep 115
Drives: Dinan Montego Blue 335i E92
new2the3, where in florida are you? i recently got into running and went through the process much as you did, and luckily had a running shop recommended to me. I also am a seasoned nike shoe wearer and naturally leaned towards nike running shoes, but after goin to the store, having my gait recorded and analyzed, I ended up getting a shoe that was for me, not just based on style and brand love lol. enjoy, and take care of your feet!
10-18-2008, 09:58 AM | #21 | |
Rep 2,067
10-18-2008, 12:17 PM | #22 |
Rep 5,497
How many times did you walk or stop?
2007 E92 Montego Blue 335i
