11-03-2019, 09:10 PM | #1 |
Rep 109
m performance electric steering v2 trim fitment
Anyone here having fitment issues with the m performance electric v2 steering wheel trim?
I'm trying to install the factory carbon fiber trim that came with the wheel and am having fitment issues. |
11-04-2019, 02:07 AM | #2 |
Rep 10,473
11-04-2019, 06:31 AM | #4 |
No 55mph
1622
Rep 8,477
Are you trying to install the trim from the 1st (2) pics to the wheel in pic #4?
If so, that's your problem. The bottom of your electronic wheel is using the split/double spokes that are usually found on the M series cars - as per the split rear trim cover that you show installed With that split rear trim you would need to use this split spoke front trim version: Item 2 in following diagram: https://www.realoem.com/bmw/enUS/sho...diagId=03_0098 Cover for steering wheel, Carbon M PERFORMANCE 32302345203
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
IK6SPEED4495.00 |
11-04-2019, 06:33 AM | #5 |
No 55mph
1622
Rep 8,477
-OR-
another cheaper option to be able to use the solid front trim you show is to buy the solid rear trim for use with paddle shifters - such as the trim that would normally come with a non M car
11-04-2019, 07:29 AM | #6 |
Rep 109
thank you 1QuikWS6. I've been using the metal split v trim and i wanted the carbon fiber trim to match the interior trims but it just wont fit. i prefer the dry carbon fiber.
I might have to order this one: https://www.ebay.com/itm/BMW-M-PERFO...L/323944874201 |
11-04-2019, 07:31 AM | #7 | |
No 55mph
1622
Rep 8,477
That's what I'm using on my wheel
