E90 M3 control arm upgrade
11-11-2019, 08:41 AM | #1 |
Hoonigan
6893
Rep 3,001
Drives: '09 328i, '98 Wrangler
What's the consensus on alignment after upgrading the control arms? My car was aligned about 8,000 miles ago. I'm doing the M3 lower control arms on my 2009 328i this weekend. I searched and it seems some people say you absolutely need an alignment, others said it isn't needed.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
11-11-2019, 09:12 AM | #2 | |
Rep 2,367
Drives: 2011 335i
I can't stress it enough. Car will literally drive like shit. On the way to getting it aligned i had to be careful Cause the steering was just all over the place it would get stiff then loose then stiff again |
CTinline-six6892.50 |
11-11-2019, 09:19 AM | #3 |
Rep 3,191
I don't know why anyone would think you don't need an alignment after.
11-11-2019, 09:23 AM | #4 |
Rep 1,272
11-11-2019, 09:44 AM | #5 |
Rep 18,808
Converting to M3 thrust arms do not need an alignment. Converting to M3 control arms does need an alignment. M3 control arms change the suspension geometry. The thrust arms are the same aluminum part with solid bushings (vs. hydraulic for non-M part), so the dimensions of the two versions of the thrust are the same.
CTinline-six6892.50 lab_rat394.50 |
11-11-2019, 10:06 AM | #6 |
Hoonigan
6893
Rep 3,001
Excellent, thanks for the quick replies.
11-11-2019, 10:20 AM | #7 |
Rep 2,806
After the M arms are on, adjust each outer tie rod outward 3 turns to make it driveable to get to the alignment shop.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
11-11-2019, 11:20 AM | #8 |
Rep 4,330
the dimensions of the m3 bushing are not the same for an XI thrust arm.
measured myself. bought the fancy CTA tool too compress the shell to fit them in my arms. the bushing eye is also offset. I'll have to find the measurements I took. I'll get to them eventually, but I just slammed stock ones in it for now. |
11-12-2019, 03:09 PM | #9 |
Rep 940
I avoided the issue all together by getting the shop to install the arms and do the alignment. Figured a control arm install was fairly quick and cheap.
I will go on record to say I got the M3 front arms at the same time as I switched from Michelin RFT to Conti ECS non-RFT. Feels like the handling got worse. |
11-12-2019, 04:18 PM | #10 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
11-12-2019, 04:23 PM | #11 |
Rep 3,729
Try driving without an alignment and let us know how that works out. Your steering wheel will lock to one side or the other without one. It would be nearly impossible/extremely dangerous to drive lol
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
11-12-2019, 04:52 PM | #12 |
Rep 2,367
Drives: 2011 335i
11-12-2019, 05:03 PM | #13 |
Rep 3,924
Surely just use the old string trick to get the alignment somewhere near, so you can drive to the alignment shop safely? Doesn't have to be perfect; just needs to be somewhere near. Last time I worked on the suspension arms on my car, I got the alignment within spec using a piece of string for toe and a spirit level for camber...and yes, I do trust the shop I took it to!
11-12-2019, 05:24 PM | #14 | |
Rep 2,806
11-16-2019, 06:48 PM | #16 | |
Rep 355
