M3 control arms, DIY alignment?
11-18-2019, 11:46 AM | #1 |
Rep 996
It’s about 40 degrees in nyc, so time for another project.
Planning to install front m3 control arms (replacing stock 325i arms), and just wanted to clarify an alignment question. How can I eyeball the tie rod adjustment? So after installing arms, I would mark the tie rod with a sharpie, then 3 full rotations to extend the tie rods on each side? Would this be good enough to drive a couple thousand miles on? Thanks |
11-18-2019, 01:33 PM | #2 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
DIY toe alignment should get you close enough until your next proper alignment:
https://jalopnik.com/how-to-do-your-...d-t-1820555295 |
lab_rat394.50 |
11-18-2019, 07:23 PM | #3 |
Rep 3,924
I'd go for string lines from the rear wheels, personally. Set the fronts parallel to the strings, or slightly toe out, and you should be close.
Just counting turns won't get you close enough to drive thousands of miles without ruining tyres. It would get you close enough to drive to an alignment shop though. I have to ask though - why not get an alignment done properly? It has the biggest effect on how your car handles! |
11-18-2019, 07:48 PM | #4 |
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
Alignments are cheap, tires aren't.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
11-19-2019, 11:06 PM | #5 |
Rep 2,367
Drives: 2011 335i
