2008 E90 M3 iDrive bluetooth settings unresponsive, won't connect (video clip)
11-24-2019, 07:13 PM | #1 |
Rep 40
In short, when I purchased the car back in late May the bluetooth connected and worked flawlessly for about 2 months. Since that time, it no longer connects, the phone cannot be deleted from the system, and bluetooth cannot be turned off in settings.
I have tried a battery disconnect and a restore (press volume knob and both eject buttons simultaneously), but not a full iDrive reset to default (not sure how). Video shows issues below. Seems like the settings are locked up for BT and maybe a reset to defaults might be an option if I can figure out how to do it. Last edited by RoofusM3; 11-24-2019 at 07:23 PM.. |
11-25-2019, 03:36 PM | #2 | |
Rep 237
11-25-2019, 04:34 PM | #3 |
Rep 1,309
^ As neil said, the bluetooth module in the trunk might have died due to condensation, or due to water intrusion, or due to some critter chewing on the wires, or a few other possibilities.
You can check it out by taking out the trunk floor panel that is closest to the back seats. Might have to take out the under-floor tray to get to it. |
11-27-2019, 01:14 AM | #4 | |
Rep 40
What's weird is I changed my battery about a month ago and I feel certain power was off for more than 10min. But maybe not because my radio settings were still saved. I'm assuming all of that will go away and return to default if the battery is off long enough. I'll give it another shot tomorrow. Do we have a radio security lock out on these cars? With my last car, E36 M3, I needed a security code to get back into the radio. |
11-27-2019, 01:30 AM | #5 |
Rep 1,309
Does your car have the logic 7 audio system (with the center speaker)?
The MOST optical loop is used for transmitting audio to the logic 7 amplifier, and to transmit audio and controls to the sirius/xm receiver, bluetooth, and a couple other things. If you don't have logic 7, it could be that the most loop was damaged or disconnected somewhere, and you wouldn't have otherwise seen evidence of it except for bluetooth no longer communicating. Something else to check |
11-27-2019, 12:37 PM | #6 | |
Rep 40
11-27-2019, 02:12 PM | #7 |
Rep 1,309
In that case, if you have audio, then your MOST loop is okay.
So, back to probably a problem with the MULF or TCU. If you have bmw software you could try to communicate with those. |
12-18-2019, 09:50 AM | #9 |
Rep 40
***UPDATE 12/18***
I got around to having some time to disconnect the battery this past weekend. When I hooked power back up, to my surprise all my radio presets, M-settings, and a few other items were still saved. Time/date and phone/bluetooth info were all deleted. So... as you can see in the video, I previously could not toggle the bluetooth on/off check box. After the battery reset, I could toggle this check box again and could clear old phones and connect new phones once again. I was able to reconnect my phone and use it to make calls. It was working as intended. However, after work, I got in the car and after a bit attempted a phone call and realized it was not working again. Checking the settings screen, I could once again not delete the paired phone profile or toggle the bluetooth on/off check box. The only thing I can tie this to is that I had plugged my phone into the usb port to listen to music. When I had originally connected to bluetooth after the battery reset, I had not plugged in my phone to test phone calls. Have any of you heard of connecting over usb for music causing issues with bluetooth connectivity? |
12-18-2019, 12:21 PM | #10 | |
Rep 1,579
12-18-2019, 12:27 PM | #11 |
Rep 624
I don't know if this is way off base, but some features cannot be modified while the engine is running, or the ignition is in the ON position. In the video, it sounds like the engine is running. Have you tried making the changes with the engine off/ignition off?
Cheers! |
12-18-2019, 01:13 PM | #12 | ||
Rep 40
12-18-2019, 02:54 PM | #13 | |
Rep 1,579
Do you code? If so, you could remove the TCU and enable the bluetooth on the MULF. You would need to code to disable SOS/assist, terminate or repatch the fiber and move the mic and bluetooth antenna wiring to the MULF. As for visual inspection, MULF and TCU are stacked under the carpet in the trunk. MULF will be the slightly shorter of the 2 boxes. |
12-18-2019, 03:15 PM | #14 | |
Rep 40
01-14-2020, 07:39 AM | #15 |
Rep 40
I got a Foxwell over the weekend and it was able to find a fault with the TCU that wasn’t showing up on my Carista reader. Code was A379.
Does that indicate that I should just replace the TCU? Anyone out there repair these or recode without having to go through the dealer? |
