e93 rear window not fully closing after regulator change?
11-27-2019, 08:03 AM | #1 |
Rep 24
Hi All,
One of the cables snapped on my rear window (2007 e93 330i), so I picked up another regulator off of eBay and put it in. All seemed okay but when I put the window up it doesn't close fully? Tried the reset procedure in this thread but it makes no difference? It does seem llike the window goes to the end of its travel. Is it possible teh regulator isthe wrong one? Or any ideas on why it wont close fully? Many thanks. upload |
11-27-2019, 02:49 PM | #2 |
Rep 1,682
Broken regulator is a common problem. I repalced mine with Uro brand for about $30 USD. Did the reset procedure and everything was working again. Uneventful really.
I did tape the widnow glass in the fully closed position before installing the motor, did not know if that made a difference. |
11-27-2019, 10:44 PM | #3 |
Rep 1,271
Throw the car in the trash and start over lol jk. I have to replace mine too so I'm dreading this. I hope you figure it out
2007 335i Jet Black e92 6AT - VRSF Full street exhaust DP, Chargepipe 7.5 FMIC, MHD, XHP, Koni orange/Eibachs, some other stuff
2007 335i Jet Black e90 6MT - Eibachs, magnaflow exhaust, carbon hood, short shift kit, some other random stuff - being sold somewhere sometime soon probably 2010 335i AW e90 6 AT Msport - The GF took this one over... JB4, PE exhaust, Koni yellows/Eibachs, pink badges, fuzzy steering wheel cover ? |
11-28-2019, 06:08 AM | #4 | |
Rep 24
There is some movement on the two mounting bolts of the regulator and i've tried loosening them and the lower bolt, hoping it would be free to push itself into line, but no luck. I've also tried pulling it forwards by hand and there is enough play to get it to almost sit where it needs to, but it wont do it by the motor alone. Even if I leave the roof down so it hits no resistance, it will not close fully??? Rain stopped play yesterday but th's weekend i'll lift the regulator out and see if i can reposition the glass itself? It really is beyond frustrating. The regulator is a 2nd hand one but a genuine BMW part and in good condition. When you do your one you may find this video a help if you've not done one before. Hopefully you wont have the issue I am!! |
12-02-2019, 09:51 PM | #7 |
Rep 666
I've attached the TIS instructions. Have you followed all of the steps and checked the gap tolerances?
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
12-03-2019, 07:14 AM | #8 | ||
Rep 24
Would you be okay with me uploading those PDFs to the BMW e92/3 facebook page as there are a couple of other guys on there with misaligned windows? Last edited by Taipan; 12-03-2019 at 07:27 AM.. |
12-03-2019, 06:03 PM | #9 |
Rep 342
Have you try to reinitialized the window with INPA?
I keep getting robbed because I leave the front door open..
I could close it but I feel doing so would be a victory for the thieves.... |
12-04-2019, 04:19 AM | #10 |
Rep 24
No. This is my first BMW and I'm not even sure what INPA is, lol. I tried a few initialising sequences using different button pushes, but to no avail. I think it is an alignment issue as it moves freely and reach the full length of its travel etc, but its just stopping short of where it needs to be. If I can loosen soem bolts and slide it forwards it should be okay, but ill check all the measurements etc.
Thanks for the reply, i'll google inpa and get soem info on it... |
12-09-2019, 04:14 AM | #11 |
Rep 24
Fixed it! The adjustment instructions specify you need a BMW special tool. Okay that may make it easier, but there is a simple way to do it. In short, the main adjustment is actually in the glass position. You simply slacken the two 8mm bolts and shift it around until you get the right position. A bit fiddly as you have to lift the regulator in and out each time, but far from being the end of the world. You obviously have to remove the three mounting bolts (2 x top, 1 x lower) and best to mark the upper twos position, so you can see where the regulator will be fixed and your glass adjustment will be made based on that. I've probably made it sound a lot more complicated than it is.
Adjusting bolts Gap closed and window perfectly aligned. |
TinCanSailor633.00 E93Seattle (Racerbruce)799.50 |
10-17-2023, 06:21 PM | #12 |
Fueled by Recycled Dinosaurs!
633
Rep 1,177
Drives: F06 M6
Found this thread via google search. Wanted to say thank you for the tip about adjusting the window without the special tool.I sincerely appreciate all the contributions to this thread as I watched the video and read the pdf's, it was all incredibly helpful. I thought the regulator was busted so I bought a new one from BMW South Atlanta and had it shipped to Tampa. I installed it today only to discover that the window was still rolling up wonky. Hindsight I think the window tint folks we use jacked up the window alignment but at least I know the car has a solid/new regulator now. You all are a credit to this community and the BMW community as a whole.
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
10-18-2023, 04:05 AM | #13 | |
Rep 24
TinCanSailor633.00 |
10-19-2023, 08:18 AM | #14 | |
633
Rep 1,177
Drives: F06 M6
I know that was a bit more luck that skill but I do have a knack for spatial orientation tasks. Maybe credit for that goes to Tetris
