Need to repair damage
11-28-2019, 08:18 AM | #1 |
Rep 112
Drives: E90 330i N52
I was in an accident and my front end is a bit messed up, I'm thinking I can fix most of it myself, just need some help in the process as I've never attempted this before. Currently it's not driveable and I think it due to the 'tie rod' at the bottom as you can see in the attatched pics.
Does anyone have a part number or anything to help me out, and in which order should I go about repairing everything else? Thanks. View post on imgur.com View post on imgur.com View post on imgur.com |
11-28-2019, 09:08 AM | #2 | |
Rep 2,476
That's not a tie rod, it's a control arm and there's going to be quite a bit of damage that you're not seeing yet. Only way to really know is to tear it down, inspect everything and get a hold of factory chassis dimension specs to see what's been bent as far as the frame and major support structures go. What is your goal with the car? Are you trying to get it back to factory spec and appearence? Will this end up a beater that you don't really care about? Using this as a learning tool and don't care so much on the final outcome? I don't want to discourage you, but that is a large undertaking if you're expecting "like it never happened" results. |
11-28-2019, 09:12 AM | #3 |
Rep 1,602
youch.
The issue with those kind of damage, is when you get all new control arm set, you'll realize that it wont fit because of the frame damage... Everything is repairable, B is for Build guy is the example, but at what price and how safe it will be? Does your car is a unicorn? |
11-28-2019, 12:11 PM | #4 |
Rep 1,080
What you can do is tow it to a body shop that has a frame machine. Have them check the frame. Ask them to repair the 'hard' stuff, and then you can do the fender and whatever else.
I'd look for used parts of the same color |
11-28-2019, 12:25 PM | #6 |
Rep 1,364
Drives: 09 E90 335i M-Sport 6MT RWD
From the picture it looks like an N52 E90 M-Sport? Depending and mileage/condition depends if you want to go forward.
I agree with others. Id pull the bumper/fender and visually check for frame damage then head to a shop that can verify it is. You could always just swap the lower control arm(the broken one) to make the car able to roll again |
11-28-2019, 01:43 PM | #7 |
Rep 3,061
It must have been quite a hit if the control arm snapped, what did your insurance agent say? If you are hellbent on a DIY, I’d pull the bumper, fender and wheel and investigate further. If there is frame damage, you may be in over your head and it may be a total loss.
11-28-2019, 02:27 PM | #8 |
Rep 4,325
It doesn’t look too bad honestly!
The lower control arm has to replaced and so does the inner tie rod as it is bent. The tie rods are so cheap that you should replace both inner and outer tie rod just to be sure they’re both good. If you just swap the control arm, it will roll around but the alignment will not be straight. I would start with replacing those 3 first to make sure the subframe is good and the suspension will line up. After that, looks like all you need is a metal bumper, plastic bumper, fender and headlight! Core support, apron and frame all look fine from the photos. |
11-28-2019, 05:26 PM | #9 | |
Rep 2,476
That's also after fixing the steering/suspension, getting it to a body shop to verify chassis/frame integrity, rounding up all of the parts, body work/paint.. |
11-28-2019, 07:01 PM | #10 | |
Rep 4,325
There a few things he probably won’t be able to do, paint and fender/bumper and the alignment, the rest is simply R&R. The nickel and dime parts, if ordered online won’t be much, if pulled from a scrap yard or parts car, they will be even cheaper. The 2 main parts I see that would run the bill up if not available locally would be the fender and the bumper/metal bumper. I'd bet money the frame is straight. I would not be so quick to junk as others have suggested. All of this of course my opinion based on the photos. |
