Any ZF 6AT experts here? Shifted to D3 and redlined the motor! Why??
11-30-2019, 02:25 PM | #1 |
Rep 3,731
So I had a very weird thing happen to me today as I'm driving my car around (07' 335i with ZF 6AT)...it kind of scared the crap out of me.
I was out driving on some backroads, and I decided to do a pretty hard pull just to make sure everything was in good working order. I'm running the MHD 2+ flash with the xHP Stage 3 transmission flash. The car/trans has 100K on it. I was on the gas pretty hard, about 3/4 throttle....after I hit around 90mph I let off the gas to slow down. As soon as I did that, I got the "TCU Fault GEAR" on the dash display, and then the transmission decided to downshift down to D3 for some reason. Well, at 80-ish MPH, that's almost 8,000rpms! I hit the brakes and slowed down as fast as I could.....and the transmission just stayed in D3 and wouldn't shift. I'm glad a rod didn't come out the side of the block or something. I pulled over, shut the car off, restarted it..and all was good. I got on the gas hard to make sure everything was ok, and it seemed to be. I just recently put new fluid, filter, D-seal, and sleeve seals in the transmission...I haven't had any issues at all, it's been working great. Why in the hell would the transmission drop down into 3rd and try to pop the engine!! ?? These are the TCU fault codes I got when I scanned the car after I got home. 4F850 - Gear Ration Monitoring Clutch E 4EE81 - Turbine Speed Sensor 50DD2 - Activation of two same priority emergency functions Any ZF transmission experts on here that can give me some info?? Good thing I wasn't going much faster...who knows what would have happened......I sure don't trust going fast in this car at this point. Could it have anything to do with the shift solenoids?
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
11-30-2019, 05:48 PM | #2 | |
Rep 3,731
11-30-2019, 10:16 PM | #3 |
Rep 1,245
What?
3rd gear runs to 95mph at redline 7000 rpms. Not saying you don't have an issue, clearly you do. But a downshift to 3rd at 80 isn't even a remote issue. That's like 5900rpm
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50 11.61 @ 117.5 New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets |
12-01-2019, 03:59 AM | #4 | |
Rep 3,731
Whatever gear it dropped down to....the tach shot way up into the red, probably 7500 if not more. Last edited by iqraceworks; 12-01-2019 at 07:40 AM.. |
12-01-2019, 02:51 PM | #5 |
Rep 2,773
what is overall mileage of the car ?
12-01-2019, 03:27 PM | #7 |
Rep 2,773
i see that you already made topic on n54tech.com
i think you can find more opinions on tuned n54 with at on n54tech from my own experience with 2.0d and without tuning i had around 280000 kms mileage when sometime on freeway i had to speedup a lttle and my RPM went high few times without any visible drag i decided that torque converter cannot lockup anymore under high load after that i've replaced torque converter and fluid if you dig any AT forum you can find that Gear Ration Monitoring Clutch E error is first sign of the worn AT. You can read AT adaptations parameters from ZF TCU using INPA or Rheingold and put them here if any clutch lock parameter will be more than 300ms then you AT is worn
12-01-2019, 03:42 PM | #8 |
Rep 3,731
As far as I can tell.... my transmission isn't slipping. I've ran it through the gears several times.....never felt it slipping, or got any errors. I pulled the adaptations and the highest chargetime is 33ms.....so I guess that's a good sign.
I'm just trying to figure out why it just downshifted and tried to pop the motor. When the transmission goes into limp mode (gear sign on dash).....is it supposed to do that? What if you were racing on the track at 100+ mph and it did that? Seems like a great way to throw a rod out of the block. I'm wondering if if could be a problem with the shift solenoids? Or is that normal for it do downshift like that when it goes into limp mode...no matter how fast you are going? Is there a forum just for these ZF transmissions? |
12-02-2019, 06:52 AM | #9 | |
Rep 3,731
Here are my adaptation values and fault codes if anyone has any ideas.....
12-02-2019, 09:45 AM | #10 |
Rep 85
Attached are a couple of ZF manuals. Includes data on clutch timing, pressures, testing solenoids.
2007 530I, 2007 328xiT
2003 325XI (gone) 2004 530I (gone) 2001 530I (gone) BMW CCA Member 15+ Years |
12-02-2019, 09:51 AM | #11 |
Rep 3,731
Thanks!! I did get a reply back from the ZF tech guys. They told me that when the 6HP21 transmission goes into limp mode....it should drop into 4th gear and stay there. He doesn't know why mine dropped down into 3rd.
He said check the transmission fluid level.......not sure why it would be any different than it was a month ago when I put fresh fluid in it, but I will check it again. He also said that the adaptation values looked good ...so he didn't think there were any issues with the clutches or seals....so that's good. He said it could be an issue with the TCU....so that sucks. I wish these damn things weren't so complicated. I guess I will check the fluid level, and go from there. |
12-02-2019, 10:10 AM | #12 |
Rep 1,682
No expert here, just enough to realize my GM transmission really is crap. Wished for a ZF.
I doubt the pre-charge pressures and times mean a whole lot. When I reset the silky smooth 6HP19 in our Audi and tried a few adaptation drives, the pressures where pretty much mid-range of -200 to 200, as far as I could remember. Did not remember anything out of the ordinary with the pre-charge times either. Middling was all I could remember. Based on the document's shift matrix, it is interesting that your error code included Clutch E problem, as gears 4, 5, and 6 all use E. And E clutch is known to have problems as a bushing leaks ATF pressure by the oil pump. https://axleaddict.com/auto-repair/Z...E-Clutch-Fault Also interesting is when you restart the problem would go away. Does that say an ECU/solenoid problem? After all, the ECU is supposed to protect the engine and not allow such a shift/rpm combination. I recently changed the "double-D"/"Bridge seal", mechatronic sleeve and the 4 round tube seals on the Audi. All were in good visible shape except the sleeve had some leaks. Afterwards the 200K mile transmission shifted beautifully. Like new really like when we got it. With the ZF transmissions I think if people actively change the filter and fluid every 50K it will work wonders for the life of the transmission. What fluid did you use? Maybe change out the filter/pan too (if you did not last time)? You have the plastic pan right? Last edited by mainbearing; 12-02-2019 at 10:19 AM.. |
12-02-2019, 05:22 PM | #13 |
Rep 3,731
Just for troubleshooting purposes....I took the car back out today after it was nice and warned up. I ran it through all the gears manually....at wide open throttle, shifting pretty early (around 4,000rpms) just to put a lot of torque on 4th, 5th, and 6th gear. For the life of me, I couldn't get the transmission to act up at all. No slipping, no faults, nothing but good shifting.
As this point, I'm having a hard time believing that it's an "E" Clutch issue (especially with the adaptation pressures being so low). I searched for a long time online, but I can't find much info on that 4EE81 Turbine Speed Sensor fault. Since I'm not getting a "Gear ratio" or any type of "slipping" type fault.......is there a chance that the Turbine Sensor itself could be crapping out? Anyone have any more specifics on the 4EE81 Turbine Speed Sensor fault code?? Does that mean that the turbine speed is out of specifications, or does that just mean that the sensor is bad/faulty/giving a weird reading? I've heard of crap getting on the sensor, causing issues. I still need to double check the transmission fluid...but at this point, I doubt that has anything to do with it.
01-08-2020, 04:34 AM | #14 |
Rep 2,773
if you not have this error code active now, then you do not have problem now
01-08-2020, 12:56 PM | #15 |
Rep 901
Have a look at this: https://axleaddict.com/auto-repair/Z...E-Clutch-Fault
Might be an issue with clutch E, it is used for all the gears past the 3rd |
01-08-2020, 01:33 PM | #16 |
Rep 3,731
I have already changed the fluid, filter, and the seals... But every once in a while it will still do the same thing. I think my next step is to pull the valve body off again and put all new shift solenoids in it and see if that fixes the problem. If that doesn't work, I've got another transmission that I might try to rebuild myself.
I really wish the car had a 6MT and not this goofy computer controller ZF 6 speed auto. |
01-08-2020, 08:02 PM | #19 | |
Rep 3,731
My car was bone stock when I got it...with about 80,000 miles on it. I thought these ZF 6 speeds were supposed to be bullet proof? |
01-08-2020, 08:40 PM | #20 |
Rep 901
Well, by the most part. I've read somewhere that zf 6 speed on the lci e90 is slightly more robust, especially in terms of that e clutch.
Opening up and replacing worn stuff in a used but correctly functioning zf 6 speed might not be too bad of an idea. Might cost you some more money but might give you some extra assurance and possibly some good youtube material. Afaik, zf 6 speed is not that bad to open up and rebuild. I'd suggest taking a look at 4l60e trans rebuild videos, many of those explain the fundamentals such as how to set clutch pack clearances without expensive special tool or how to disassemble clutch drums with spring cages etc |
