12-01-2019, 12:56 AM | #1 |
Rep 774
good springs+shocks vs entry level coilovers
so I've had my mind set on Dinan lowering springs and Koni yellows, but now I also see inexpensive coilover setups. my question is, would a coilover setup be better because they have been designed with matching springs and shocks? some inexpensive option coilovers I'm seeing are ISC N1, Vogtland, ST, Megan, and BC ... some being as low as $699/$799 so I'm basically $100-$200 away, if that, from these cheaper coilovers compared to the Dinan/Koni route. My goal is to get rid of some wheel gap and improve handling over stock. the car won't see any track time and is my daily driver. :
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
12-01-2019, 01:51 PM | #2 |
Rep 1,934
Out of those coilover options you would be good with any of the BC, ST, And Vogtland (they are big in the VAG world so they know what they are doing). The ST are actually a galvanized steel version of KW v1 coilovers (stainless steel, no rust). The BCs are also a good entry level option, pretty customizable, and you can add swift/hyperco springs no problem.
Many people laud the shock + spring combo, but it's definitely hit or miss to get the height you want. I would skip right over those to the paired coilover options.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
DreamerJoe245.00 aps336.50 |
12-02-2019, 11:41 AM | #3 | |
Rep 774
12-03-2019, 11:55 AM | #4 |
Rep 891
It is very hard to nail a shock spring combo. I have two friends who have swapped springs and shocks more than twice because of either ride height, noise or rate complaints. They've both spent enough doing all that to have just bought a nice coilover system from the start and they both regret not doing that. Some people like to experiment, but there is a reason why these companies spend the money to pair and test this stuff, I'd rather pay a bit extra so it's the professionals doing it.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
12-03-2019, 02:12 PM | #5 | ||
Rep 3,954
MacklinUSOB518.00 alohasurftoad3124.00 |
12-03-2019, 02:48 PM | #6 |
Rep 10,304
@DreamerJoe, what vehicle do you have?
With springs and shocks, there is only one suspension height setting which will eventually change as the suspension settles down. I suggest coilovers such as KW Street Comfort as the entry point. |
12-03-2019, 04:32 PM | #7 | |||
Rep 774
12-03-2019, 04:44 PM | #8 |
Rep 774
I have a 2013 F30 RWD M sport. and initially I was considering springs/shocks because of the price factor, and if a good spring shock combo is running me $700, and the entry level coilobers are $700-$800 that's what I was leaning towards.. I really don't want to spend $1,600 on coilovers, my last car I spent $2,600 on them and honestly felt it wasn't worth it and would have been just as happy with a $1k setup. I just have to find which out of the entry level coilovers would be the best choice. ISC, Vogtland, BC (read a few negative things already), and bilstein has some that are just a little more which is probably top of my list right now. I'm just not seeing any reviews on Vogtland or ISC, maybe I need to look at users outside of bmw.
12-03-2019, 07:49 PM | #9 | |
Rep 10,304
12-03-2019, 08:34 PM | #10 | ||
Rep 774
12-03-2019, 10:27 PM | #11 | |
Rep 5,399
Then it would be pretty straight forward to choose a spring set for your desired stiffness and ride height such as Dinan, Eibach, H&R, etc. I happened to choose Eibach for my car and the drop was exactly as they advertised. Check out Bimmerpostings from Farkle! who has done a tremendous amount of shock/spring research. |
12-04-2019, 12:12 AM | #12 | ||
Rep 774
12-04-2019, 01:48 PM | #13 |
Rep 3,954
I have them on my car. They are fine for a DD. No issues at all. But I run 18" wheels and non run flat tires.
12-04-2019, 05:53 PM | #14 | |
Rep 774
12-04-2019, 07:32 PM | #15 |
Rep 3,954
They are not adjustable. However, they do include all the hardware such as top mounts, bolts/nuts, etc. You can assemble the M Performance Suspension kit before actually removing your old suspension parts.
12-04-2019, 07:46 PM | #16 | |
Rep 241
12-04-2019, 10:54 PM | #17 | ||
Rep 774
12-05-2019, 05:32 AM | #18 | |
Rep 3,954
01-09-2020, 05:23 PM | #19 | |
Rep 3,748
Any update which suspension you choose? Did you try the Vogtland? I am also looking at Vogtland coilovers. Currently I'm set on getting eibach/koni red set up. I just really want to lower my car 0.5" more from stock m-sport. I know the vogtland coilovers said 1.2" but I bet that's from base model suspension. |
01-13-2020, 07:58 AM | #20 |
Rep 1,499
FWIW I have H&R Sport Springs with M-Sport shocks/structs and i think it's perfect. Body roll was significantly reduced over the stock M-Sport springs. Ride height is perfect with no rubbing running wider tires (245/35 R19 front, 275/30 R19 rear) even on track days and comfort level is great. I bit stiffer than stock M-Sport suspension but not jarring. What really pushed me to the H&R springs was getting a used set for $300 which you can find pretty regularly. I realize my stock shocks/struts will probably wear faster with the drop but when they blow I'll upgrade to coilovers at that point and probably be able to sell the H&R springs for what I paid for them.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
04-15-2020, 01:55 PM | #21 |
Rep 774
so I decided on ST coilovers, and for an additional $160 (+$80 for extensions) I'm going with the ST XA, w/ adjustable dampening like the KW V2. now, since the rear shock needs to be removed to adjust I asked a rep from ST if the KW extensions will work, since the difference between the 2 is not in design but materials used, he said yes they should work just fine. now my question to you guys is, which extension length will be best?
they come in 8mm, 9mm, and 10mm diameter and lengths of 100mm, 150, 200, 250, 300, and 350. at first I though longer is better, but if anyone knows the proper length it would allow a much cleaner install. and I almost went with the Vogtland coilovers, willing to test them out, but it turns out they use the Koni FSD shocks and most reviews on them aren't that great.
04-15-2020, 02:21 PM | #22 | |
Rep 3,748
