E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Tank Breather Valve O-ring Replacement
Reply
      12-02-2019, 08:33 AM   #1
rt7085
Drives: E91 328xi wagon / Mercedes GTS
Does anybody have a good source for the rubber o-rings that are used for the tank breather valve pipes. See picture below. It is a 12 mm o-ring. Mine packed out a bit over time, causing a minor tank evap leak.
      12-02-2019, 05:15 PM   #2
rt7085
Turns out Rockauto send me a "broken new vapor canister purge valve". I put the old one back. When you blow on the valve intake it allows air through. That should not happen. Lesson for everybody: Check whether the valve seals before you put it in. Or check any part for that matter for good behavior when possible..... Ugh.
Reply
e90post
