12-03-2019, 09:39 AM | #1 |
Stance to make her dance
714
Rep 2,006
Bilstein B8+H&R Springs OR Bilstein B12
Hello everyone!
I'm looking to lower my 2014 F30 335i RWD. I have decided on either Bilstein B8 + H&R Sport Springs, OR Bilstein B12 (which is B8+Eibach springs). I've done some research and it sounds like B8+H&R combo will lower the car a little bit more, but there's obviously a reason why Bilstein did the B12 setup with Eibach. I havent found any side-by-side photos to compare the two setups otherwise. Piecing the B8+H&R spring combo also seems to be a little bit more expensive vs the B12 setup. DO NOT TELL ME TO BUY COILOVERS - my options are above and those are the only two that I am considering. I have had plenty of suspension setups on ALL of my cars (springs, coils, air), so I know the pros/cons of all of them. So spare me on the lecture Of the two setups above, which would you go with and why? Who has best pricing on these two setups? Thanks!
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2022 G80 CX M3, Individual BRG |
12-03-2019, 10:11 PM | #2 | |
Rep 27
12-04-2019, 03:38 AM | #3 |
Rep 468
My 2 p when it comes to Bislteins matched to H&R springs.
You get the looks you want or sure, but nothing else in terms of drive ability and effectiveness of the shocks. B8 or B6 whatever you decide to use will be compressed all the way down, giving you less the '5 of the free travel which means you will be 100% sitting on the bump stops at all times. If you removed them or cut them it will be the same. Which means you hit a tiny little pothole, you will bottom out and more then likely bust the top mounts. If you search here on the forum you will find that any B/HR combo ends in the same way, bust top mounts. Your shock comes right trough them from minimal impact. B12 is an awesome combo, and you can chose between 2 type of springs, one lower then the other. |
12-04-2019, 10:29 AM | #4 |
Rep 2,674
B8's go great with h&r sport springs - i only have the b8's in the rear and it as a huge improvement. One day I'll get them up front too.
12-04-2019, 10:52 AM | #5 | |
Rep 10,301
Any thoughts if the lowering target would not be achieved for any number of reasons? |
12-04-2019, 11:07 AM | #6 | |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
johnung4537.00 |
12-05-2019, 09:04 AM | #7 | ||||
714
Rep 2,006
Good option but out of my price range, I think.
Do you have experience with the B12 setup? I havent seen many pictures with B12s, so I dont know how the car sits. From reading, it sounds like it doesnt sit as low as B8's w/ H&R Sport Springs. Quote:
12-05-2019, 08:46 PM | #8 |
Rep 5,458
Drives: F30
B8 and ACS spring kit is a very nice option. Tellin' you.
12-06-2019, 07:49 AM | #9 |
714
Rep 2,006
Yep, I've seen that combo as well!
12-07-2019, 03:21 AM | #10 |
Rep 468
I have the B12 and have tried 2 spring setups.
The only reason I comment on HR, regardless wether the issua has been resolved, as they lower the car the most, which leaves the B8 strut with minimal compression left. You can see some pictures where I marked my strut to see where the ride sits and how far it compresses under driving conditions. The black marker lines are where strut doesn't travel which means it compresses well and it doesn't bottom out |
thompsac25714.00 Skrrtt33515.00 |
12-09-2019, 07:54 AM | #11 | |
714
Rep 2,006
But your B12 setup looks pretty good. Happy with them so far, I presume? How does it feel compared to stock?
12-15-2019, 11:11 AM | #13 |
Rep 942
Why is this combo a no go? Tons of solid reviews with H&R sports and B8s. I have h&r sports on the car and B8s, in my trunk ready to instal next week.
2013 e92 M3
2011 X5 35d 2018 F80 M3 ZCP |
12-16-2019, 08:00 AM | #15 |
714
Rep 2,006
I guess I'm just deciding between Bilstein B8/H&R combo vs. Bilstein B12's
I'm not sure if I will be happy enough with the B12 drop. Might make me want more...
12-20-2019, 05:33 PM | #16 |
Big Turbo Boys N Girls
327
Rep 579
I ran the B8+ H&R combo. Worked soo good and were a dream to drive on the street. But the back sits super low on the stock Super Sports RED's which I did not like and after 3 months I than had H&R make a custom spring that is in between the SPORT and SUPER SPORT height for the rear to better match the stance. I drove that setup for another 9 months and the ride was not too stiff and absorbed the small bumps well and were stiff enough for the back twisty roads and took the corners way better than the stock 704 option. Dampening is on point for this setup as well and does not crash and I never bottomed out even on worse roads.
I went one step further and now I have a custom valved B8 to the custom H&R springs and it's about same setup as stock B8 valving but more aggressive as I use it more for track so needed the little bit more dampening. But I got a lifetime warranty and you know they wont leak like coil overs do after 30-50K. I would see if the Eibach springs sit higher on the back then the RED's. If they are higher than go with the Eibach's(Stiffer) they are closely matched to the valving like the REDS(Less Stiffer than Eibachs) are but give you a better stance in my opinion.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
12-23-2019, 07:50 AM | #17 | |
714
Rep 2,006
Thanks for chiming in! Interesting. I assume it cost you quite a bit extra for H&R to make custom springs for you. I think the Super Sports sit a little too low for my liking. Thats why I'm leaning towards the BLUE regular H&R Sports. I think it'll pair pretty nicely with the B8's. I think the B12 (Eibach B8 combo) wont sit low enough for my liking. And like you, the H&R Super Sport REDS will be a little TOO low.
01-10-2020, 12:29 AM | #18 | |
Great Teacher
1124
Rep 1,314
Drives: 06 e91 325ix
Farkle, do Bmw still have the rough road spring pads for f30 like they did for everything from e34 on? They used to use them in America and it was a cheap extra drop to go with the thinner pads up front. I’m iX so my cars RealOEM doesn’t show different ones So I’m not sure they exist anymore for this chassis. |
01-10-2020, 01:34 AM | #19 | |
Rep 5,399
However before purchasing I would also research the specs on those specific H&R and Eibach springs to make sure that I understand how similar or different they are. Farkle! has assembled a lot of information so you may find that in his postings and links. With your comments, you appear to be focused on the visuals of ride height and fender gap much more so that the actual ride of the proposed new suspension. It's possible that you could install them both and not be happy with the ride height of either option. You would seem to be an ideal candidate for one of the Bilstein coilovers. Then you could tweak and adjust it to zero in on an appearance that you would enjoy. |
thompsac25714.00 |
01-10-2020, 10:10 AM | #20 | |
714
Rep 2,006
I would not be opposed to Bilstein coilovers, but now we are talking a different price point... I appreciate your input!
01-10-2020, 10:47 AM | #21 | ||
Rep 3,540
01-10-2020, 12:05 PM | #22 | ||
Rep 5,399
B8 + Eibach Springs $1,067 (separately priced) B12 (above config) maybe $969? Not certain B14 coilovers $1,044 (1.2"-2.0" drop) B16 coilovers $2,034 (0.5"-1.3" drop) (Adjustable dampers) I thought I remember another drop range available too So B14 coilovers would be in same price range. Don't recall specifics vs B12 off the top of my head but worth looking into. |
thompsac25714.00 |
