Airbag light on, BST error?
12-04-2019, 11:24 AM | #1 |
Rep 6
So my airbag light has been on since I bought my car used 6 months ago. I ran the codes the day I got it and all the airbags said they were good. The code pointed to the BST (battery safety terminal)
I would replace it but the car has never been in an accident so it shouldn't need replaced. I did however notice that there was a little yellow and black wire plugged into the BST (you can see it in the picture) I assume it's a control/sensor wire to the computer. It was disconnected and smashed. I did my best to fix it and reconnect it (heat shrink on the frayed wire and glue for the cracked plastic) After reconnecting I cleared the codes aaand... no dice. I'm kinda at a loss, and I'm completely tired of the dash light. Last edited by theGiantMidget; 12-04-2019 at 11:32 AM.. |
12-04-2019, 12:56 PM | #2 |
Rep 3,731
Do you have the INPA software? It sounds be one of your seat belt tensioners....or the connectors/wiring for them.
INPA will let you check all of the devices.....and see what is actually triggering your airbag light. I had the same issue...turned out to be one of the seat belt tensioners. I think Bimmergeeks app "Pro Tool" will let you turn the airbag light off.....but the app is a little pricey.
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
12-04-2019, 01:38 PM | #3 |
Rep 1,893
You can’t fix the BST. Cut the wires, solder a 2 ohm resistor across them, clear the error code.
This fix bypasses the BST device. Otherwise, you’ll have to replace battery terminal- about $200 |
12-04-2019, 02:01 PM | #5 |
Rep 3,731
Yep...I'm pretty sure you can. Pro Tool app.
12-04-2019, 02:05 PM | #6 | |
Rep 3,731
You can also use INPA to see what is actually triggering the airbag light...could be several different things...not just the BST.
Ridu0.00 |
12-04-2019, 02:37 PM | #7 | |
Rep 1,893
Also, I still don't think you can generically disable the airbag light. You can use coding to disable model specific features like seat sensors, side bags and head restraints. For example, to install performance seats etc. But that does not disable the light for a BST fault or the dash airbags. You'll also have to disconnect the wires to the seat sensors etc or the coding disable will not work. |
12-04-2019, 03:15 PM | #9 |
Rep 1,893
Well, I stand corrected at least about the BST - you CAN code out the BST error, rather than soldering on the resistor.
You can do it with NCSExpert or the Bimmergeek ProTool |
12-04-2019, 03:41 PM | #10 |
Rep 6
I'm loving the resistor idea. I should be able to clear the code afterwards with my foxwell NT520 scanner correct? I don't think I need INPA for that.
diesel torque is king
12-05-2019, 01:41 PM | #11 | |
Rep 1,893
However, I would urge you to take a little time to install BMW standard tools (INPA, NCSExpert, WinKFP, Tool32) or ISTA-D (download links available at www.bimmergeeks.net) and learn a little about how to use them. It will save you time and money in the long run. |
12-05-2019, 02:34 PM | #13 | |
Rep 44
My 06 had airbag and seat belt lights on when I bought it and also got code for BST. After poking around in the back, I realized a couple of strands of the red/blue wire (most likely the same you have, just different colors) were broken from where it was zip-tied to one of the positive cables. Went to Pick-n-Pull and got about 12 inches of the wire and the connector, soldered it in, cleared the code and lights were gone. The whole effort took maybe 10 minutes from start to finish and I am not very handy with soldering iron at all.
2006 325i
1999 R1100RT Plus some GM products... |
12-09-2019, 08:48 AM | #14 | ||
Rep 6
my guess is that the BST is bad or it's just not making good connection with the property connector. I would replace the connector but I'd have to buy a parts car, to buy knowledge you can't find that connector to buy.
12-09-2019, 09:24 AM | #15 | ||
Rep 6
I just don't have a laptop or tablet to use right now.
12-09-2019, 10:17 AM | #16 | |
Rep 1,579
https://www.ecstuning.com/b-genuine-...g/61129130178/ |
12-09-2019, 02:36 PM | #18 | |
Rep 44
2006 325i
Tags |
battery e90 code, bmw 335d, bst, e90, help needed |
