12-05-2019, 07:05 PM | #1 |
Rep 5
M330i bumper for base model?
Was wondering if anyone knows if the 330i M sport bumper could fit and replace the front bumper on the base 330i?
Haven't really found much info on this as it seems everyone has the 330i M sport package already lol (if only I had a bit more money ). Cheers! |
12-05-2019, 10:18 PM | #2 |
Petrolhead
1943
Rep 3,521
It should. I dont think BMW will redo the entire front end just to fit a different bumper.
12-06-2019, 08:54 AM | #5 |
Petrolhead
1943
Rep 3,521
Well yes. Youll need the wiring, switch (on the headlight switch console) and coding (?) for the fog lamp to work. I was talking about the clips and stuff which should be the same, making it possible to install the M sport bumper in place of the ordinary bumper.
12-10-2019, 12:30 AM | #7 |
Rep 1
I was able to find this:
https://parts.bmwmonterey.com/a/BMW_...r/51_A302.html but not sure that's everything you needed to replace a base model bumper though & how hard it is to replace it. |
07-13-2020, 11:12 PM | #8 |
Rep 24
OP, were you able to go through with this conversion? I'm asking because I am thinking of doing the same. Thanks!
07-14-2020, 09:32 AM | #9 | |
Rep 71
Other small components will need to be changed as well. Including, but not limited to lower re-bar rebar shock absorber all bumper trim pieces |
07-14-2020, 10:16 AM | #10 |
Rep 24
Because the bumper mounts are different, would that mean that this conversion would not be possible to do?
07-14-2020, 02:25 PM | #11 | |
Rep 71
It's just there are additional pieces that will need to be changed out besides the main bumper panel/trim pieces. Some of the internal mounts and structure pieces are different between the M and non-M bumper. |
