12-10-2019, 09:19 AM | #1 |
Rep 29
Rear drum brake issue
I have an issue with my handbrake not catching my drum when I pull the handle up. I bought a brake kit from ecstuning which includes all pads and rotors. I replaced the rear rotor and adjusted the drum spring and when I went to pull the handbrake, it still goes all the way up. So I'm thinking that the hub on the rear rotor is too big for the drum pads to catch the rotor. Has anyone encountered this issue? If so, what was the solution? Thanks.
12-10-2019, 10:10 AM | #2 |
Rep 16,143
If they're the wrong rotors you need to get the right ones. It seems unlikely that the wrong rotor would allow the calipers to fit. Did you adjust the shoes? https://www.newtis.info/tisv2/a/en/f...brake/Gff2d2Mq
12-10-2019, 11:11 AM | #3 | |
Rep 29
12-10-2019, 12:39 PM | #5 |
Rep 29
12-10-2019, 01:32 PM | #6 |
Rep 8,942
I'd suspect the rotor as well. The reason I mention this, I bought a BBK for my F23 then decided to use it on my F31 instead. They had to swap the rear rotors out specifically for the issue you are describing. Didn't cost me anything, but it did alert me to the fact that while much of the kit was identical car to car the rear rotor was not.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
12-10-2019, 01:59 PM | #7 | |
Rep 29
12-10-2019, 02:45 PM | #8 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Did you order the rear rotor for a 35i or xDrive vehicle? IIRC those had a larger hat than the ones for the 28i RWD vehicles.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
12-10-2019, 03:11 PM | #9 |
Rep 8,942
I got the whole set from Sun BMW, and I got the rear rotors for a 2016 M235 xDrive convertible. They would not work on my 2016 328 xDrive wagon. The rest of the kit - calipers, pads, front rotors - identical.
2022 Macan S
12-26-2019, 06:14 PM | #10 | |
Rep 29
12-27-2019, 08:41 PM | #11 |
Rep 16,143
It's not the parking brake, as that's not engaged with the brake pedal. Vibration could be caused by improper/inadequate lubrication of the pad to caliper/pad holder interfaces.
12-27-2019, 09:59 PM | #12 | |
Rep 5,399
Quick way to determine rear parking brake/rotor hat size
