Can high coolant concentration cause issues?
12-10-2019, 08:10 PM | #1 |
Rep 6,316
I was doing my vehicle check service and notice my coolant using a coolant tester reads at a bit higher than in the picture below (not my picture).
Would having a concentration high cause issues? I suppose the coolant is more thick to push through? Should I suck out some fluid and get it down to a lower mix like 50/50. My winter temps are at most -30 on extreme so 50/50 mix is fine. I guess I've been driving like this all summer to when I was hard on the car. Last edited by TheMidnightNarwhal; 12-10-2019 at 08:26 PM.. |
12-10-2019, 08:22 PM | #2 |
Rep 13,128
There is a reason they call it anti freeze
A high concentration is more likely to do you good in the winter. |
12-10-2019, 08:26 PM | #3 | |
Rep 6,316
Like what can happen? Coolant doesn't go where it's needed quickly or blows a hose or? |
12-10-2019, 08:26 PM | #4 |
Is it the shoes!?
3885
Rep 5,112
It is recommended not to exceed a ratio of 60% ethylene glycol-based coolant, as the freeze point will then typically start to increase again and defeat the purpose of coolant's freeze protection. It won't cause any other issues beyond that.
TheMidnightNarwhal2682.00 |
12-10-2019, 08:31 PM | #5 | |
Rep 6,316
Like I know one of the main purpose was for anti freezing as well as boilover but didn't know it went back down as the concentration was higher. |
12-10-2019, 08:36 PM | #6 | |
Is it the shoes!?
3885
Rep 5,112
Science man. It's fvcky. |
12-10-2019, 09:34 PM | #7 | |
Rep 1,322
But if you arent dealing with truly extreme temps its not going to matter. |
12-11-2019, 08:00 AM | #8 |
Rep 14,829
From years ago we learned to never go beyond 70% coolant. Real life proof, is my neighbor poured 100% into a hose system running under his porch. It burst. Pretty sure 100% is good to maybe 14F, and that's it. So I would do 60% so I didn't get too close. in reality 50/50 is good to -34F so it's not that common that beyond 50% is really needed.
12-11-2019, 08:01 AM | #9 | |
Rep 14,829
Meaning, if you live in AK where it could matter, you want no more than 70%. 70% has more anti-boil than 60%. If I am not mistaken 100% has greater anti-boil than 70%. |
12-11-2019, 08:05 AM | #10 |
Rep 14,829
Again, my neighbor has an irrigation system running under his porch, and he asked me to help fill it. I remembered it was 100% concentrate so I told him, I seem to remember that 100% freezes at 14F or something. He said that's ok. It did end up bursting as we got temps near 2-5F that winter. If we had used 50/50 it would have been fine. But he's like me, old fashioned. If 100% costs $15, then 50/50 should cost $7.50, not $13.
12-11-2019, 09:31 AM | #11 | |
Rep 1,322
12-11-2019, 10:57 AM | #12 | |
Rep 1,602
So the best mix would be : having max water concentration, and avoiding boiling point and freezing point as per your environment. |
12-11-2019, 03:39 PM | #13 | ||
Rep 494
12-11-2019, 03:47 PM | #14 |
Rep 358
50/50 max. Antifreeze is a poor conductor of heat. Water does the work, the antifreeze provides lubrication, rust-inhibitors, freeze/boil protection, etc. You're not doing your engine any favors by running more than 50% antifreeze.
2006 e90 330i | Black/Terra | 6MT | ZSP | ZPP | ZCW
