Bimmerpost
4 Series
Technical Topics B48 4-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications G20 Throttle Input While Downshifting
      12-21-2019, 09:13 PM   #1
Nichols623
Drives: G20
Hello G20 Forum. I’m new to BMW and I wanted to ask fellow G20 owners of this symptom is normal. During breaking, around 3rd 2nd and 1st gear, there is a slight throttle input when the transmission is downshifting. Requires the driver to adjust breaking pressure to accommodate so not to jerk, just slightly. While I don’t expect BMW transmissions to act like Honda or anything, just wondering if this was normal, perhaps due to dual clutch tech. Not sure.
      12-21-2019, 09:54 PM   #2
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
My G20 330i behaves exactly like you said. 1300 miles and I still can’t modulate the brakes perfectly for a jolt free stop in Sport mode. Sucks. Same issue in another 330i I test drove. Btw our cars have the zf8 tranny, not dual clutch.
      12-22-2019, 01:59 PM   #3
g20beam
g20beam's Avatar
Drives: G20 330i M Sport
2019 BMW  [0.00]
I am on Stage 1 93 tune by BMS and I no longer have this issue. Because of emissions requirements they probably restricted performance in 330i and since the engine is not operating at the optimum output level because of emissions regulations and requirements, the 4-cyl engine doesn’t make enough power and therefore causes jerkiness while braking..
      12-23-2019, 12:23 AM   #4
VipinLJ
Petrolhead
VipinLJ's Avatar
Not sure if it’s an emission thing or not. My B9 A4 made the same power and the brakes were strong and grabby on that. But it had the same stopping power till the car came to a complete halt and the brake pedal didn’t need to be modulated as much for a smooth stop. In the Bimmer, towards the end of the stop, it feels like the brakes grab more, making me ease up a wee bit on the brake pedal in order to reduce the jolt. Not sure if it’s the actual brake or engine braking causing it.
      12-24-2019, 02:00 AM   #5
g20beam
g20beam's Avatar
2019 BMW  [0.00]
I’m almost certain it’s not the actual brake because I observed the RPM drop when you are applying the brakes, it’s the engine braking that is making the car jerk. Since I’ve flashed the tune, I no longer have this problem, and the RPM drop and downshift is smoother now.
      12-24-2019, 12:49 PM   #6
VipinLJ
Petrolhead
VipinLJ's Avatar
If only I had the balls to try flashing my car again
      01-17-2020, 08:06 AM   #7
Chappati21
Chappati21's Avatar
France
Drives: BMW M340ix Touring (G21)
I also have the same "issue" feels like your manually downshifting (therefore feel small jerks) just before stopping. Didn't have that feeling in my previous DCT cars.
VipinLJ1943.00
      03-02-2020, 11:10 PM   #8
Beam330
Beam330's Avatar
Drives: 2019 BMW 330i xDrive M Sport
I think you should be good now to be honest... I saw your messages on a different forum and you flashed your car with the wrong engine map right? If that is the case there shouldnt be a problem now.
Do you have a JB4 currently or are you running stock?
      03-03-2020, 09:03 AM   #9
VipinLJ
Petrolhead
VipinLJ's Avatar
It was the right map. I thought it was wrong because the map said B48. But I checked with PTF and they said it’s the same for the B46 too. And it didn’t work when I tried twice.
I’m running a JB+ for now. Not JB4. I didn’t get the jb4 because of the hassle of install but, after seeing how easy it is, I wish I had gotten the jb4 back then. Right now, I’m waiting for a few more months for more people to flash their cars with a BM3 before I go at it again.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      03-03-2020, 11:47 AM   #10
g20beam
g20beam's Avatar
2019 BMW  [0.00]
Try again when BM3 has an update for B48 maps
They still have not updated the B48 map since release, I can see them updating it soon so that it will work.
      03-03-2020, 12:45 PM   #11
VipinLJ
Petrolhead
VipinLJ's Avatar
I will. I’m in touch with a guy from India who just bought a BM3 tune but his car also has an ECU software from 03/2019 unfortunately. Waiting to see how it goes for him.
Current:
      03-04-2020, 08:37 PM   #12
hamzag20
hamzag20's Avatar
557
Drives: BMW G20 330i, BMW G30 540i
Let us know how it goes for that guy
      03-04-2020, 09:51 PM   #13
VipinLJ
Petrolhead
VipinLJ's Avatar
I will! I’m guessing he’ll be fine since his car is an early 2019 car and doesn’t have the updated software. But yes. Waiting to find out how that goes for him.
Current:
      11-11-2020, 12:04 PM   #14
sid.hse
Drives: BMW 3 G20 320i
Could you tell what "Stage 1 93 tune by BMS" is, please?
Do you guys know whether the jb+ will solve the issue?
      11-16-2020, 02:09 PM   #15
g20beam
g20beam's Avatar
2019 BMW  [0.00]
My bad. I meant BM3.
Update: The jerkiness is still there, does not matter what tune or mods you do, it persists after you let the tune run for a few cycles. No clue what it is, but looks like everyone is having this problem. I can confirm it happens when you are downshifting and letting go of throttle, the engine will input throttle slightly right after the downshift, typically around 2-3k RPM. Not sure what is going on but I'm pretty sure it is normal.
There is 1 culprit I can think of, and that is the cruising function which is built in to the car, after you downshift, the car wants to stay cruising instead of slowing down, so it automatically inputs throttle so the car will stay cruising. I know that with Bimmercode that cruising can be disabled. I'm not sure this will fix the problem though, however.
VipinLJ1943.00
      11-16-2020, 04:27 PM   #16
jbarba
jbarba's Avatar
Spain
44
Drives: G21 320i
it happens to me, not very often, but when occurs its very noticable for me (im used to manual transmission, having all control on engone behaviour). Very annoying having to modulate breaking pressure, and mu impression is that occurs more in eco pro than in confort.
In my case, never use cruise control.
      11-16-2020, 07:35 PM   #17
VipinLJ
Petrolhead
VipinLJ's Avatar
Yup. It's still there after all this while (a little over a year since I've had the car). You kinda get used to it but coming to a smooth stop is still a wee bit difficult with the 330i. Either the car feels jerky when you brake normally, or it feels like you braked too hard when you apply a little excess brake pedal pressure to try and prevent the car from being jerky.
Current:
      11-17-2020, 05:29 PM   #18
BmwDriverStockholm
Sweden
46
Drives: G20 330i M-sport sedan
hear hear guys. Even in sport individual when engine does not stop and everything is not eco friendly. There is some input required to stop the car smoothly. I do not know if this is related to high torque of this engine or some software issue. The M brakes are great and crisp when pressure applied =)
      11-17-2020, 10:05 PM   #19
VipinLJ
Petrolhead
VipinLJ's Avatar
Not sure if it's because of torque. My B9 A4 was more powerful even in stock form (even though it is rated less on paper). That car had AMAZING stopping power. Hell. At the end of the lease, after lots and lots of hard driving with braking, launch control etc, that car had better brakes (stopping power) than my brand new 330i (even now). So yes. I think it's a tuning issue?
Current:
      11-20-2020, 05:09 AM   #20
sid.hse
I noticed that sometimes I have normal driving in the range of 0-30 km/h but sometimes it's so jerky with constant engine breaking that makes the whole driving experience a disaster. I also found that right after being in a traffic jam when the car is being jerky it then accelerates much slower, say to a 100, as if not all the cylinders contribute or the turbine is not performing properly.
      11-20-2020, 07:58 AM   #21
jbarba
jbarba's Avatar
Spain
44
Drives: G21 320i
this happened to me last week. After 30 mins of stop on traffic jam, throttle does not respond as always, returning back to normal minutes after.
Seems like ECU engine self protection.
Something similar happened to me with my 2007 Passat 3C diesel on traffic jams
      01-29-2021, 02:01 PM   #22
Kilgour
Drives: 2020 BMW 330xi
Same braking issues here, and am running the sport brakes. At first I thought it was me, but then tried throwing it into neutral and braking to a stop, and it’s smooth as butter. So it’s the downshifting that’s out of tune, or it’s just tuned aggressively. Will raise this with my dealer if lockdown ever ends.
g20
