12-28-2019, 05:56 PM | #1 |
Rep 55
435i rear inner tire wear
So I’m having some rear inner tire wear on both rear wheels, I’m lowered on H&R super sports and I got an alignment the last time I changed tires for the same reason and the alignment sheet came back good. So I’m lost I have no idea why it’s wearing so badly. Anyone have ideas?
12-28-2019, 06:21 PM | #2 |
Rep 10,304
How many miles did your vehicle generate since H&R Super Sports springs were installed?
My humble thoughts without knowing more about the vehicle. Although wheel alignment came back within specifications, the problem might be negative camber being introduced during certain driving conditions. This will cause inner tire wear. The question is of course why. One possibility: the rear springs are compressing to such an extent that negative camber is in fact being introduced. Again - what's the condition of rear springs? Did you buy them new or used? |
Justin_F3222.00 |
12-30-2019, 10:48 AM | #3 | ||
Rep 55
12-30-2019, 12:20 PM | #4 |
Rep 10,304
I suspect rear springs are either worn out or defective. Good independent shop can inspect the rear suspension and provide more insight.
12-31-2019, 02:42 PM | #5 |
Cheapskate
4457
Rep 4,995
What were your alignment specs? And how much inner wear over how many miles are we talking? Worn springs won't matter if the alignment is good. I have 2.5* of camber in the rear and the tires are wearing pretty evenly. I think with My Super sport springs I was around 1.8 in the rear. But I also like to drive the car hard and take turns at speed. If 90% of your driving is cruising on the highway then your camber is working against you.
01-02-2020, 09:58 AM | #6 | |
Rep 55
kern4174456.50 |
01-02-2020, 10:19 AM | #7 | ||
Rep 55
01-02-2020, 10:52 AM | #8 |
Rep 891
I would check on your rear trailing arm bushings. While static on the rack you have consistent (enough) numbers between sides but under changing loads/compression it will be a different story. I run -2.4 in the rear and mine wear pretty evenly but I don't do a lot of highway miles. Toe can change dynamically along with the camber with bad RTABs which can really accelerate the wear.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
01-02-2020, 03:35 PM | #9 |
Cheapskate
4457
Rep 4,995
Yeah potentially either your driving style or a bushing. You can jack it up and see if the wheel has any play when you try to move it around. That'll indicate there's a bushing/bearing issue.
It also looks like you have stretched tires. 20s + small stretched sidewall + camber means you're likely to roll over onto the sidewall and put a lot more load on the edge of the tire. What are your wheel/tire specs? |
01-14-2020, 06:36 AM | #11 |
Cheapskate
4457
Rep 4,995
reduce your rear camber.
01-14-2020, 08:46 AM | #12 |
Rep 8,509
My rear geo is
Camber -1º25' each side Total toe 0º17' Thrust angle 0º Tyres are run at 2.4 Bar and wear is pretty much even across the treads. These current tyres, Michelin Pilot Sport 4S, have done around 20K miles including 6 track evening sessions and a full day track session at Spa (Belgium) where they did around 150 hard track miles, and still have ~4mm remaining (i.e. ~50% worn).. Is there a reason why you're running more camber at the rear than the front ? Definitely check all bushes for wear - if there's wear in the system the geo can change when the car is moving. What tyre pressure are you running ? What wheel and tyre sizes are you running ? Are the tyres run-flat ? RFTs, especially on 19s, have a rep for inner shoulder wear especially with incorrect inflation and/or >OEM camber.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
01-15-2020, 06:56 AM | #13 | |
Cheapskate
4457
Rep 4,995
