Machine Polishing
09-03-2008, 09:55 AM | #1 |
Rep 9,218
Machine Polishing
I find buffing my car after waxing is a real pain.
I've got some minor scratches and swirls that need polishing out, so I'm debating getting a machine polisher and havng a go myself. If I did this, would it be OK to use the polisher to buff the car after waxing on an ongoing basis? If the consensus is that the wax should be buffed by hand then I'll probably get a professional detail instead. |
09-03-2008, 10:33 AM | #2 |
Rep 1,413
If you enjoy detailing and are physically used to it, get a Porter Cable machine or similar - I have one, used it once and it nearly killed me. Sat in the garage ever since!
But I'm really unfit They can be used for paint correction, application of wax and buffing |
09-03-2008, 10:52 AM | #3 |
A member
9
Rep 153
Am having a similar dilemma - do I buy a rotary polisher (I would proabbly go for the Meguiars G220) and then have to get used to it, hope I don't introduce buffer trails, burn through etc etc or pay about £100 more for a professional to do it once and then maintain it myself....
To be honest I'm heading towards the professional as I think I know enugh about what to do when washing the car to not introduce any swirls and scratches so once the professional has done it it should look good for a very long time. I have already had a serious bollocking when the missus added up the "value" of the various washes, polishes, waxes, tar removers, clay bars, snow foam, microfibres etc etc etc that were in the garage (well over £300.... ooops) and fear buying a rotary would be a slippery slope to whole new level of product ownership... |
09-03-2008, 11:03 AM | #4 | |
Rep 1,557
ROFL, I have a tub of Zymol Ital (£360) that sits on the top shelf of our fridge, I dread to think what she would say if she actually knew what it costs. |
09-03-2008, 11:35 AM | #5 | |
Moderator
324
Rep 5,493
Think you should get it done once professionally, then just look after the basic cleaning and waxing yourself. If it's swirl-mark free, and you know how to look after the car yourself, then it's easy to keep it pristine.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
09-03-2008, 11:47 AM | #6 | |
Rep 280
Mate, if you do enquire about a detail, you`ll probably find that whoever does it will use a machine polisher in any case, rather than hand-buffing. I think that to invest in one of the machines yourself (ie, a porter cable, or the Megs G220), you need to be quite serious about spending time detailing the car yourself on a regular basis, otherwise it`s just not worth spending the money. |
09-03-2008, 11:49 AM | #7 |
Moderator
324
Rep 5,493
Certainly Paul from Shine On doesn't use a machine to buff the wax - hand job only, so to speak!! Same as the guy from Miracle Detail too...
09-03-2008, 11:55 AM | #8 | |
Lamininist
84
Rep 1,030
Only done the BMW once with it in May and it still looks and feels fantastic, paintwork silky smooth and shiny. Full treatment for me is Zymol Autobathe, Clay bar, HD Cleanse and the Glasur. Hand finishing only and most important to clay bar the car before waxing, if you dont expect lots of swirl marks. This is the first car that Ive done properly from new and there is not a hazy mark on it anywhere. Yves |
09-03-2008, 12:35 PM | #9 |
Rep 437
Don't bother get a professional to do all the correct work. once that it done applying and then removing wax is a easy. Zymol is a little harder, but once again easy when you are used to it and someone else has done the initial work. It is all in the prep, if it is not good, your finish will never be good, hence get someone to do it initially, it is money well spent.
09-03-2008, 12:57 PM | #10 |
Lamininist
84
Rep 1,030
09-03-2008, 02:24 PM | #11 |
The Grim Reapers Love Child
49
Rep 515
Drives: BMW e92 M-Sport Coupe
Location: A little bit left of Sane, near Tongue in Cheek.
Hi NFS,
I have a fair bit of experience with car prep including for shows (albeit private) and have used the Porter Cable 7424 for some time - I would be happy to offer advice if you are interested. In fact I had written you a length reply with loads of advice but my bleeding machines logged me off for some reason Long story short: Please don't consider a proper 'Rotary' polisher - go the DA route - The PC is a great machine, the Meguiars also. If you are correcting swirl marks then I recommend a DA polisher such as above and 3M Finesse polish - I can explain the technique with pleasure but haven't time left now. IMHO a polisher is for polishing - i.e paint correction (swirls/scratches etc). You could buff wax or sealant with one but the results depend on what wax/sealant product you are using as some waxes/sealants are not intended for machine. Let the machine do the work for polishing out problems and do the final wax buffing by hand. Finally, you would not want to Polish (by that I mean cut) your paint regularly - as you are removing clearcoat BUT you could (with the right products) Buff a wax on your paint regularly (as wax has no cutting action). I have 26 years of car prep experience so if you want more advice I'd be happy to help. HTH
Mark II
Previous: e92 M-Sport. TiAg. Black Dakota. Creamy 6cyl diesel. Stage II Tune. Performance exhaust. K&N. Auto+paddles. Quaife LSD. BMW BBK+Cool Carbon S/T. Goodridge. 19" Breyton Race GTS. Vredesteins. M3 lip. Prof nav. Xenons. Voice. Sun protection. Pdc. etc.. |
09-03-2008, 03:47 PM | #12 |
Rep 1,085
Drives: Le Mans Blue E93 330d+
Can't you get your man servant to do it by hand
I am going to get mine done properly, if you are not careful you could do some damage. |
09-03-2008, 04:31 PM | #13 |
Rep 9,218
Thanks to all for the advice.
Having looked into it the decent random orbital polishers will set me back about £150. On that basis I reckon my best bet is probably to spend a little more and get a pro to tidy things up for me. |
09-03-2008, 04:45 PM | #14 |
Rep 3,465
ive got a brand new one that i cant be arsed with its yours for £100.
C350 cdi sport estate facelift 457lbft
130i M SportMercedes C350 CDI Sport Estate AutoMini Cooper Auto.Mercedes E250 CGI,Lexus IS-F,R36, RS4 Saloon,ML 420 CDI SPORT,M6, 335d, C55, C32, M3, M5, S3, ALL SOLD but fondly remembered |
09-03-2008, 06:16 PM | #15 | |
Rep 280
Flaming hell Mark, you certainly sound like a man of experience, with 26 years behind you. You`ll probably find that you`re going to get a bit battered for advice on the subject of detailing now mate ! Having said that, it`s always good to seek the advice of an expert on these things, and I sometimes find that with "Detailing World", there`s probably TOO much information to hand, and you end up getting bamboozled with it all............... So, as I said mate; you`ll probably get pestered here and there........
09-04-2008, 03:03 AM | #16 | |
49
Rep 515
I should stress (being totally honest) that I don't class myself as an expert on paint - more a very keen enthusiast. The company I run nowadays is not in the motor trade but I was in the trade when I was younger. My main qualifications are in vehicle engineering and I've spent the past 26 years of my life indulging that passion, including car tuning, detailing, hot rods, drag racing and sports cars for private enjoyment and showing. I don't have so much time with work commitments to enjoy it these day but would be happy to share what I've learned with anyone who is interested and if I don't genuinely know the answer, I'll defer to an expert. BTW: Know what you mean about Detailing World - the conversation sometimes does get overly-technical. Sorry if this is off topic. HTH
Mark II
09-04-2008, 03:50 AM | #17 |
Rep 8,811
E92Fan, any detailers near me you could recommend?
09-04-2008, 03:56 AM | #18 |
Moderator
324
Rep 5,493
Yes matey, sent PM...
09-04-2008, 05:30 AM | #19 |
Rep 2,333
I know one too, but I think its the same as E92's recco......he does a lot of work through the Lotus site......did my grey one before I picked it up.
Current: F13 640i MSport, e85 Z4 3.0i
Previous - Alpina D3 BiTurbo E90 LCI Manual, 320d M Sport E92 Auto, 330i M Sport E92 courtesy of BMW UK....320i M Sport E92 Auto, 320d SE E90 Manual. |
09-04-2008, 06:07 AM | #20 | |
Moderator
324
Rep 5,493
ps.. Shine On Detail
09-04-2008, 07:02 AM | #21 |
49
Rep 515
Never used them myself but I have always heard good things about Parc Ferme: http://www.parcferme.co.uk/
Mark II
09-04-2008, 03:02 PM | #22 |
Rep 1,826
Drives: Alpina G21 D3S
NFS,
No idea where you're based, but I do this in my spare time and whilst I don't consider myself a pro by any means, if you want a machine polish and wax I'd gladly sort it out for you. This is the type of correction I achieve......... Matt |
