3 Stage IM Coversion on 2011 328xi LCI
01-06-2020, 11:57 AM | #1 |
Rep 55
Drives: 2011 328xi
Hello all,
I recently purchased a used 3 stage IM with new hardware, gaskets, and valves. Random question, is Bimmerlabs still functioning and do they offer the stock tune needed to run the 3 SIM? Thanks! |
01-06-2020, 01:01 PM | #2 | |
Rep 2,287
I use the site frequently for my N54 tunes. Was still there last week. |
otitxn6.00 |
01-06-2020, 02:20 PM | #3 |
Rep 996
I downloaded the 330i files and RDA delete last week and flashed this weekend.
otitxn6.00 Pilarskica12.50 |
01-06-2020, 02:28 PM | #4 |
Rep 2,099
I believe the 328to330i file is automatically uploaded if you provide the correct info. You might see it there in a few hours.
Go to bimmerlabs.com and start a project. Only if you have a unique need or have headers in the mix do you need to request an actual tuner (which costs). |
otitxn6.00 |
01-07-2020, 05:33 AM | #5 |
Rep 55
Drives: 2011 328xi
Thanks all, I was able to make the account. It was just my connection, looking forward to this project until I can grab the StageFP tune for my AA headers and axel back.
01-08-2020, 03:38 PM | #6 |
Rep 666
For your own sake, do upgrade those DISA flaps to aluminum before you start using them. Those valves will break and drop pieces into the runners and if you get lucky it stops there. If you're not lucky, it's a new motor cost.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
otitxn6.00 |
01-09-2020, 08:06 AM | #7 |
Rep 55
Drives: 2011 328xi
What upgrade kit do you recommend to do that with? I am definitely interested in this, as I am assuming it will also increase the lifespan of the valves?
01-09-2020, 08:54 AM | #8 |
Rep 666
Link provided below:
https://www.ebay.com/itm/Aluminium-R...YAAOSw44BYMxNT (you can also go to VANOS-BMW.com and type in "N52" in search box. Both large and small flap upgrade kits are there. The flap is aluminum so it won't snap in half as in some cases experienced by many. Most importantly, the spindle shaft is upgraded to metal and a straight through design where as the factory shaft is plastic and only goes half way down the flap. Once the teeth gets worn it starts to have play and quickly loses the entire flap into the runners. In any case, the upgrade kit will address it all. I've upgraded mine and now feel much more at peace in mind when driving the car around town spiritedly. I also searched and found the same kit for the smaller DISA flap. However I haven't need to install it yet because judging from the force of air applied in that chamber, I just don't think it'll wear the factory gear out, but one of those days I may elect to do the same upgrade just in case.
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump Last edited by yupetc; 01-09-2020 at 09:12 AM.. |
01-09-2020, 11:29 AM | #9 |
Rep 2,287
I question this logic,
Can I get a show of hands from the people who fried a motor with a faulty OEM plastic disa valve? There are 10s of thousands of these motors running around, has anyone heard of a disa valve damaging the motor internals? Switching to metal flaps might change this count. |
tlow982191.00 |
01-09-2020, 02:35 PM | #10 | |
Rep 666
01-09-2020, 04:26 PM | #11 | ||
Rep 2,287
Maybe they just fall off the shaft in pieces that are too large to fit into the cylinders. Or maybe a few have been ingested and converted into smog, don't know. Just does not seem to be a common failure point. I'm not saying it can't happen, things do happen just last year a woman was hit by a meteorite. |
01-10-2020, 09:59 AM | #12 | |
Rep 666
01-10-2020, 11:22 PM | #13 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
I believe flap failure is less of an issue with the revised valves as they have metal pins. Upgrading older valves are difficult as you have to cut open the motor body and seal it after. It's more likely that the motors fail
01-13-2020, 05:52 AM | #14 |
Rep 55
Drives: 2011 328xi
Not to derail the thread, but can anyone link what they feel is the best guide to do the swap? I finally got in all of my gaskets, DISAs, and hardware. It's time to get her swapped in.
01-13-2020, 06:41 AM | #15 |
Rep 55
Drives: 2011 328xi
Also, not sure if I may want to do this myself. Can anyone recommend a shop in the Northeast Ohio area (Cleveland)? Just moved out here, and left my family's garage back in NY. Thanks all!
01-13-2020, 11:00 AM | #16 | |
[Oo=||=oO]
1105
Rep 2,470
01-13-2020, 12:18 PM | #17 | |
Rep 996
It took me 7 hrs. |
01-13-2020, 04:29 PM | #18 | ||
Rep 2,287
Take notes and pictures as you pull things apart. The PVC pipe fittings can be a pain but there is a trick to releasing them. Just have spare hoses available when you do the work. |
01-13-2020, 04:54 PM | #19 |
Rep 205
Hello! Anyone feel free to correct me if I'm wrong, but don't the LCI 328i's come with the N51 engine? (N51 being Super Ultra Low Emission Vehicle, SULEV) which already comes with a 3 stage intake manifold as compared to the N52 engines which come with the single stage. N52 motor owners are the ones who do the conversion. If your vehicle is an N51, it already has the 3 stage intake manifold. Easy check is the sticker under your hood. If it says SULEV, then you have an N51 with 3 stage intake already. Best, Nick.
2011 E90 328i | CDV Delete | BMW PE | Bilstein B12 Pro-Kit | 17x9 ET30 APEX ARC-8's | 255/40
01-14-2020, 05:14 AM | #20 | |
Rep 55
Drives: 2011 328xi
Love The Drive34.00 |
01-14-2020, 07:25 AM | #21 | |
[Oo=||=oO]
1105
Rep 2,470
The last NA engine by BMW was N73 (V12 - 2016) from Phantom / 7 series. |
01-15-2020, 10:04 PM | #22 | |
Rep 666
Very interesting facts to know. Thanks. and I'll say, though, that these N52 motors are actually quite good and very reliable if you can get through most of those leaking gasketing issues and the ignition failures once in a blue moon. Other than that, putting in a 3-stage manifold, headers, and a good tune will get you quite happy with the results. The linear power curve is a bit more comfortable to drive in comparison to those turbo N20's and B48's, yet, still quite peppy with enough mods.
