Bimmerpost
4 Series
Technical Topics Cosmetic and Lighting Modifications (exterior & interior) Disable dome lights when entering?
      01-19-2020, 11:30 AM   #1
sikotic
Drives: 2020 M340I
Is there a way to disable to dome lights when entering/unlocking the car? I find them to be just a bit bright and overpower the ambient lighting
I'm sure this can be done with some sort of coding but just checking to see if anyone has found an easier way
      01-19-2020, 12:11 PM   #2
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
United Kingdom
443
Drives: BMW G20 330i RWD M Sport
I’m assuming by ‘dome lights’ (not a term we use in the U.K.) you are referring to the interior lights then this is from the manual which may help.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      01-19-2020, 12:18 PM   #3
sikotic
Drives: 2020 M340I
Attachment 2222055
Thank you! I'll give this a try a little later on
      01-20-2020, 06:33 AM   #4
-Nick
-Nick's Avatar
United Kingdom
83
Drives: G20 330e
Note that when you switch them off permanently my welcome light carpet and door handle lights also switched off.
They were still set to on in the iDrive settings. Only way I got them back was turning the dome lights back on
      01-20-2020, 09:06 AM   #5
sikotic
Drives: 2020 M340I
Well that's a huge bummer. The dome lights are just way too bright and overpowering. Wondering if there is any sort of work-around
      01-20-2020, 09:09 PM   #6
sikotic
Drives: 2020 M340I
Ok just to report back..
I have a US Spec M340i and it looks like I'm in the same boat where permanently disabling the dome lights will also disable the door handle lights and light carpet
      01-20-2020, 10:47 PM   #7
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
That sucks. I like the door handle light and carpet lights. But then, I don’t disable the interior lights because I don’t think it’s too bright anyways.
In my ex-A4, the interior light switch only turned off the inside dome lights. Not the exterior handle lights. Also, the dome lights were touch sensitive AND the brightness could be adjusted by touching it. I would’ve loved it if BMW brought that tech to the G20 as well but yea.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
g20
