02-09-2020, 12:25 PM | #1 |
Rep 407
Drives: Miss Daisy
Laptop to TV via HDMI...no sound
Done this a million times to watch movies. Hook laptopto home theater receiver via HDMI cable. Now, all of a sudden, I get no sound no matter what I do, but video is fine. Tried all the normal fixes, but nothing helps.
Yes, HDMI device shows up & is set as default. Any ideas? |
02-09-2020, 01:43 PM | #3 |
Rep 407
Drives: Miss Daisy
02-09-2020, 03:24 PM | #4 |
Rep 885
02-10-2020, 03:27 AM | #5 |
Rep 440
Drives: 2013 335i xDrive
Can you try hooking the HDMI cable directly from the laptop to the TV? If the sound works that way, then the problem is most likely in the home theater receiver.
I'm not completely useless, I can be used as a bad example.
02-10-2020, 09:19 AM | #6 | |
Rep 407
Drives: Miss Daisy
However, I then hooked my laptop up to my workstation (Via USB) on my desk & now I get no audio going to the speakers there out of the blue. This thing hates me |
02-10-2020, 10:15 AM | #7 |
Rep 2,476
Check the playback devices and make sure HDMI is selected for your audio source.
If that doesn't work, update both your video and audio drivers. It's possible a Windows update is the issue, and updating drivers usually fixes it. |
02-10-2020, 10:49 AM | #8 |
Rep 1,965
Simple fix. Took me a while to figure it out as well. If the laptop is powered on, when you connect the HDMI, restart it after the HDMI connection is made.
02-10-2020, 11:55 AM | #9 |
Rep 407
Drives: Miss Daisy
02-10-2020, 11:56 AM | #10 |
Rep 407
Drives: Miss Daisy
02-10-2020, 12:04 PM | #11 |
Rep 1,929
I would check your source. For example on my laptop, I use realtek source as my laptop speaker output but as soon I plug into HDMI, my source changes to Invidia speaker output.
02-10-2020, 04:16 PM | #12 |
Rep 407
Drives: Miss Daisy
It goes to the right source when either is plugged in. Not sure wtf is wrong as all settings are correct, drivers are good, blah blah. I have restarted, uninstalled & reinstalled & all that stuff many times. Still not working. Makes no sense as both worked perfect & now, out of the blue, neither works. I didn't even mess with anything to cause it.
02-10-2020, 05:56 PM | #13 |
Rep 440
Are you using the workstation to play the video or the laptop?
02-11-2020, 10:05 AM | #14 | |
Rep 1,929
Did you try restoring to a earlier point? |
02-11-2020, 03:44 PM | #15 |
Rep 407
Drives: Miss Daisy
