Bimmerpost
4 Series
Technical Topics Cosmetic and Lighting Modifications (exterior & interior) BMW M-Performance Interior Trim
      02-22-2020, 07:30 PM   #1
WXdrivefun
WXdrivefun's Avatar
Drives: G20 330Xdrive
Hi anyone have these installed and instructions how to remove and replace existing trim without damaging existing OEM trim?
      02-23-2020, 03:02 AM   #2
Xsapper
Xsapper's Avatar
United Kingdom
234
Drives: G20 330i M Sport
I have just placed an order for this trim and have asked them to supply fitting instructions.
This may help:
https://www.newtis.info/tisv2/a/en/g...corative+strip
What price were you quoted?
Uk price is £740 ish
vicfalc09211.00
purpl3ish755.50
      02-23-2020, 06:52 AM   #3
vicfalc09
vicfalc09's Avatar
211
Drives: M340i xDrive
This may help:
Really looking forward to seeing this install / pic of the quality of the carbon fiber. When's it coming?
      02-23-2020, 07:37 AM   #4
RedKloud
RedKloud's Avatar
737
Drives: BMW i4 M50
This may help:
+1
      02-23-2020, 08:24 AM   #5
Xsapper
Xsapper's Avatar
United Kingdom
234
It will have to come from Germany and although I have paid for it I have told the dealer that they must get me fitting instructions before ordering it. Couple of weeks maybe!!
      02-23-2020, 12:23 PM   #6
WXdrivefun
WXdrivefun's Avatar
This may help:
I'm still deciding myself depending on the ease of replacing them by the instructions. Another thing I read from the link, Special wedge and pry tools are needed to prevent scratches and damages.
      02-25-2020, 12:38 PM   #7
OM3RTA
United Kingdom
391
Drives: 330i M Sport, Audi A3 2.0 TDI
Originally Posted by RedKloud View Post
+1
+2.
      02-25-2020, 12:41 PM   #8
OM3RTA
United Kingdom
391
Interior trim tools are easily picked up for cheap.
      02-25-2020, 02:22 PM   #9
Cabby
Drives: 2019 X740i
2020 BMW M340xi  [0.00]
2019 BMW X7  [0.00]
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      03-21-2020, 07:26 AM   #10
Xsapper
Xsapper's Avatar
United Kingdom
234
Fitted the trim this morning. Took a couple of hours to remove & re-fit very carefully. Followed instructions from BMW but they are very basic. I will do a write up and add to the mod's section.
Before & After:
      03-21-2020, 08:51 AM   #11
Burrcold
Drives: 2024 M3 Comp xDrive
Looks much better!
      03-22-2020, 04:19 AM   #12
OM3RTA
United Kingdom
391
Before & After:
Definitely better👍 although I think it'll just be the lighting it does look more glossy than open pore.
      03-22-2020, 11:28 PM   #13
Conezz
Drives: G20
Is this intended as a matte CF or some other material?
      03-23-2020, 01:45 AM   #14
Xsapper
Xsapper's Avatar
United Kingdom
234
The light when taking these photos with my phone was really bright.
I can confirm though that the trim is matte open-pored carbon fibre
      03-23-2020, 06:52 PM   #15
WXdrivefun
WXdrivefun's Avatar
Thanks for sharing looks nice and clean. Just curious what were your thoughts and opinion about going with the OEM mat carbon fibre M-Performance trim instead of aftermarket gloss carbon fibre or a carbon fibre wrap on the trim?
      03-24-2020, 07:04 AM   #16
Xsapper
Xsapper's Avatar
United Kingdom
234
To be honest I did a wrap on a previous F30 interior, it was ok but looked a bit chav therefore I changed it to OEM performance parts which had excellent build quality and fit. I looked at the after market stick on trims which do look good but decided to go OEM for the matte open-pored carbon fibre again on my current G20.
My local dealer reduced the price which persuaded me to purchase it. Some are advertising standard trim sets for close to what I paid and I would think the performance interior will sell when its time for me to change the car.
I guess its down to personal taste and ££££'s but in my opinion well worth the cost. It just looks right and I will probably also do the steering wheel trim at some point.
      04-12-2020, 10:11 AM   #17
phayze
How did u remove the center trim? The top part seems difficult to remove.
      04-15-2020, 10:23 AM   #18
phayze
Are we able to purchase the parts separately?
      04-15-2020, 11:54 AM   #19
Xsapper
Xsapper's Avatar
United Kingdom
234
If you are talking about the trim around the gear selector then I would say this for me was the hardest part to remove because of the two clips as marked at the dashboard end. All I would say is do not lift the trim too high and use a long thin screw driver to carefully unclip, it did eventually pop out. If you haven't seen it I have done a basic guide in the DIY section.
VipinLJ1943.00
P-ToK72342.00
      04-15-2020, 07:31 PM   #20
phayze
Hi,
I have seen your pdf. But i am unable to unclip it. Do u push the screwdriver from the top to release the trim? Any risk of breaking anything? Do you have a close up photo on the clips of the trim you took out?
      04-16-2020, 01:47 AM   #21
Xsapper
Xsapper's Avatar
United Kingdom
234
Originally Posted by phayze View Post
Hi,
As I said this was the hardest bit and to be honest I am not 100% sure how eventually the two clips disengaged as I was trying different things. I used a long screwdriver from the side into the gap between the trim when raised and the gear trim and pulled/pushed at the same time. I seem to remember one clip disengaged before the other and being quite forceful but didn't break anything. It was hard and took a few attempts but came out in the end. If you enlarge the photo of the trim above you can see the two clips with tabs. Also if you do identify a method please let me know and I will amend my original guide.
      04-16-2020, 04:18 AM   #22
phayze
I am looking at the below link for the method. Does this really work?
https://youtu.be/sqAdj24leVA
g20
