02-24-2020, 11:29 AM | #1 |
Administrator
40871
Rep 21,240
iX3 Moves Closer to Debut With Prototypes in Different Colors and Aerodynamic Wheels
BIMMERPOST NEWS iX3 Moves Closer to Debut With Prototypes in Different Colors and Aerodynamic Wheels The debut of the full electric BMW iX3 is getting closer as the prototypes are now appearing in different colors. Also see here for the first time are the Aerodynamic Wheels exclusive to the iX3. BMW has officially published that the iX3's range is rated at 440 KM (WLTP) and feature a 74 kWh battery. The electric motor featured in the BMW iX3 delivers a maximum power output of 210 kW/286 hp and 400 Nm torque.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
02-24-2020, 05:35 PM | #3 |
Rep 5,105
I have a question re: range. What happens to the 440km range when the AC, heat, headlights, radio/stereo etc are running? Not all at once necessarily. Does the 440km range drop significantly? Obviously that quoted range is optimal and likely tested with nothing else running in the vehicle
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
tringuyen775752.00 |
02-24-2020, 05:51 PM | #4 |
///M
6654
Rep 3,683
74-kWh battery is small, and hey should go with minimum 90-kWh
Tesla is ready to release new battery and is also increasing to 109-kWh He is light years ahead! https://www.forbes.com/sites/arielco...e-battery/amp/ https://carbuzz.com/news/teslas-enti...e-upgrade-soon
Life is too short...enjoy your life
///M |
02-24-2020, 05:55 PM | #5 | |
Rep 2,350
BMWZ41909.50 |
02-24-2020, 06:37 PM | #7 |
Rep 349
440km on the WLTP cycle is going to end up being around 200 miles on the EPA cycle. It’ll also be the least powerful/slowest vehicle in the segment, and be the only one NOT to offer AWD. A RWD-only SUV. BMW waited alllll this time to launch their full electrics, letting Audi, Benz, Jag, etc. beat them to market, and this is what they come out with. It’s like they want it to fail.
02-24-2020, 06:53 PM | #9 | ||
Rep 5,105
02-24-2020, 07:06 PM | #10 | |
Rep 6,248
02-24-2020, 07:59 PM | #11 |
Ring Leader of G8X Haters
25083
Rep 8,762
Hopefully the i4 and iNext/iX will make huge strides for BMW's iDivision because this RWD electric X3 likely won't do the trick unless its really cheap, which it likely won't be. I have a feeling that this will end up flopping like the EQC and E-Tron, doesn't help that Tesla is readying Model Y production.
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300 |
02-24-2020, 08:22 PM | #12 | ||
Rep 5,105
02-24-2020, 08:56 PM | #13 | |
Rep 6,248
I suppose they could do what they did with the ActiveHybrid range (former owner here), and basically give them away at the same cost as the equivalently-powered/spec’d ICE version. How much of a premium can they really ask for an iX3, over and above what a X3 30e starts at $49K? |
02-24-2020, 09:20 PM | #14 | |
Rep 6,926
Swappy531.50 |
02-24-2020, 09:40 PM | #15 | |||
Rep 1,607
"Beware of false knowledge; it is more dangerous than ignorance."
M3ditate88.50 |
02-24-2020, 09:43 PM | #16 |
Rep 1,607
There formula for BMW should be simple: Make a Model-Y competitor, equal or better range, equal or better performance, equal or better looks. Pricing could be slightly higher since it's a BMW.
But this approach to offer an electric variant of their line with nothing exciting behind it just feel like the typical legacy approach to product making and the new kids eating their pie. I think the e-tron sportback from Audi looks increíble.
02-24-2020, 10:52 PM | #17 |
Rep 892
Drives: None atm
Well if we are talking range, When it comes to my i3s during summer time if i am driving "normally" i have achieved at most 280 km in one charge when the guess o meter shows 300 km. And that is with about second setting on the fan and 19c in the car. Sens you Pre cool/pre heat your cabin when connected to the wall connector the heat/cold is rarely a problem.
Then comes winter the car drops to 250-240 km in one charge keeping the cabin at 21c inside again also Pre heating the cabin witch is one of those things you should learn to remember to do before using the car sens then the car have to use a lot less energy to heat up / cool down the car. So i am guessing with this car if they are claiming 440 km it will probably drop to 390-400 km during winter if keeping 21c in the cabin, But to keep the heat in the car as much as possible BMW should probably heat isolate the car as much as possible as with when building a new home/house the isolation the more you put in the walls the more it keep the heat in the house and the more it will keep the heat outside of the house during summer. But then again comes that dreaded equations that tells you the more weight you put in to a car the more energy is needed to move that object so you can't put to much weight either in to the car. Sens the car will probably weight a lot. It is a tricky equation for BMW to solve.
Current Car: Bicycle
Former Car:BMW i4 M50 Brooklyn Grey (MY22)| BMW i3s BEV (MY19)|Former Car: BMW X1 20d x-drive (MY16)|BMW m235i (MY14)|Former Car: BMW 120d (MY12)|Former Car: Volvo C30 T5 R-Design (MY08)|Former Car: Volvo C70 T5 (MY06)|Former Car: Volvo S40 2.0T(MY1999) |
02-24-2020, 11:37 PM | #18 |
Rep 70
Look forward more to i4 since it will be more closely related to G22, and according to media AWD and more powerful. But honestly, any platform that aims to accommodate both gasoline and electric powertrains is not optimized for EV, and is unlikely to beat Tesla.
02-25-2020, 04:02 AM | #19 | ||
Rep 804
ron_jeremy513.00 |
02-25-2020, 04:07 AM | #20 |
Rep 364
RWD, not a problem. Anyone claiming they need AWD should probably ask themselves why.
Power, plenty of power no need for more. Range. A bit on the short side. Could work if there's a proper high speed charging network that the car is capable of using. Price. Will be way to expensive. |
02-25-2020, 06:02 AM | #21 | |
Rep 25,115
My car made front page of Bimmerpost
02-25-2020, 06:04 AM | #22 |
Rep 985
The biggest joke is that the SUV EV have a RWD solution, meanwhile the sedan 3/4 series EV have a AWD, what were BMW thinking?! 😂
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive. |
Dog Face Pony Soldier9719.50 |
