02-24-2020, 03:50 PM | #1 |
Rep 17
Passing emissions with a JB4 and catless DPs
Hi guys. I'm pretty new here but I've been having some issues passing emissions with my car in NY.
Been doing a ton of research on this but I can't seem to find a definitive how-to on the topic above. As the title says, I have a JB4 and a catless DP on my car, and i'm reading that the only surefire way to pass is go back to stock DP. Problem is, I can't seem to find an OEM DP for sale for the life of me. I have a code scanner, JB4 is switched to Map 0 and disconnected and I can't find the VRSF dp fix any where either. Hopefully someone can point me in the right direction. Thanks! |
02-24-2020, 04:07 PM | #2 |
Rep 7,634
I am pretty sure the VRSF DP fix never worked to pass emissions, but someone can correct me if i am wrong. It's for sale on their website, but i wouldnt buy without confirmation it actually works from someone who used it.
If your state requires you to get all emissions monitors in ready state (some allow 1 NOT ready monitor), then yes, you need the OEM DP and/or a aftermarket DP that passes emissions (fabspeed catted, AA). I'm sure you can find an OEM one for sale on here or on ebay. Aftermarket catted ones typically run $1,000+ if you want to pass emissions with it. I think you can probably get a used OEM for ~$200-300. |
sspade2476.50 |
02-24-2020, 04:15 PM | #3 | |
Rep 17
yeah that's what I'm seeing for the catted DPs. Been trying to find a OEM DP and can't find one anywhere lol
02-24-2020, 05:49 PM | #4 |
A family of bimmers
2757
Rep 7,743
NY and Catless do not mix. The jb4 just clears the check engine light. It does nothing for the readiness check. It's why I haven't gone catless and I can't justify the price of the fabspeed.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
02-24-2020, 05:53 PM | #5 |
Mike: Everyone's Pal
2046
Rep 2,972
Drives: F80 M3
damn I have a catted DP im not using, but its for a 2013 F30 335xi. Doubt it will fit
[CENTER]
2021 6.2L Trail Boss, 6" BDS lift, Chevy Performance intake, 35" Nitto Grapplers, 20" Fuel wheels |
02-24-2020, 07:20 PM | #6 |
Rep 7,634
02-24-2020, 07:38 PM | #7 |
Rep 352
I don't recommend Fabspeed dp. Mine only lasted little over a year and you will eventually get CEL. To get any warranty be ready to jump through hoops to prove their $1400 dp is faulty. They do not reimburse you for anything not even shipping back the faulty dp.
2016 435i M-Sport | Carbon Black | 20" 624M Wheels | MPPK | MPE | M Performance Brakes | M Performance Steering Wheel II with Display | xHP | Dinan Stage 4 | Dinan Big Turbo | Dinan High Performance Intercooler | Dinan Intake | Dinan Shockware | Fabspeed Sport Cat Downpipe | Custom Quad Tips | Autotecknic Red Paddle Shifters
sspade2476.50 superherorockstar63.00 |
02-24-2020, 08:06 PM | #8 | |
Rep 7,634
This is the first i am hearing of fabspeed catted DP eventually causing a CEL. Sucks because i just installed mine a few months ago... I hope i don't run into this issue. Just curious if you did anything out of the ordinary to cause excessive wear. |
02-24-2020, 08:31 PM | #9 |
2046
Rep 2,972
Drives: F80 M3
nope pwg
[CENTER]
02-24-2020, 09:19 PM | #10 | ||
Rep 352
Google Fabspeed dp with CEL will see there are others with same issue. They guarantee no CEL but don't really stand behind their product. Wish I had did more research before purchasing one.
02-25-2020, 12:26 AM | #11 | |
Rep 7,634
02-25-2020, 06:37 AM | #12 |
Rep 164
I am at 2+ years on mine with no issue. To be fair, I do not have a lot of miles on it, but they are not exactly highway miles either.
2014 F30 335i xDrive 6MT - Pure Stage 2 GFB DV / Inlet | XDI-35 HPFP | Fuel-It PI w/ AIC and LPFP Upgrade | BM3 | Fabspeed Catted DP | Dinan axle back | VRSF Race FMIC/CP | Dinan CAI | KW V3 | Wiechers CF strut bar | Dinan ARB | Spec stage 2+ clutch SMFW | Full M Performance Interior | M Performance BBK | Vorsteiner VFF107 MPS4S | Jordan Tuned Full E85 - 558WHP/520TQ on Mustang Dyno
02-25-2020, 07:01 AM | #13 | |
No 55mph
1623
Rep 8,479
And mine is DD with ~10K per yr Including the bigger turbo, BM3 custom tune, no heavy burbles
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
