03-09-2020, 09:40 PM | #1 |
Rep 1,222
Rhino ramps and front lip
Anyone with a front lip able to use rhino ramps? Just checking before I buy a lip, I do oil changes in between recommended intervals and was wondering if this is an issue?
09-21-2020, 11:00 AM | #3 |
Rep 1,222
09-21-2020, 05:58 PM | #5 | |
Rep 38
Safe to say I returned the ramps the next day as there wasn't enough clearance with the lip installed |
09-21-2020, 07:10 PM | #6 |
Rep 219
I use standard rhino ramp style ramps with a lip and have had no issues. I make sure to go slow both up and down. But I'm not lowered. If I was, it would be a no go.
'20 Portimao Blue M340i – Current '17 Dark Graphite 530i – Retired '14 Alpine White 328i – Retired |
09-21-2020, 07:29 PM | #7 |
Rep 1,222
I tried the same with my lip and it was rubbing way before I was a quarter up and I'm stock height
09-21-2020, 07:37 PM | #8 | |
Rep 219
09-21-2020, 10:02 PM | #9 | ||
Rep 1,222
09-22-2020, 06:16 AM | #10 |
Rep 632
Drives: 2019 X740i
I used Race Ramps - Yes, you need the extender ramps or you will scrape the front getting off post lip install - these are very expensive but worth every penny if you dont have lift available:
https://www.raceramps.com/garage-ser...ace/p/RR-56-2/ https://www.raceramps.com/garage-ser...rs/p/xtenders/ https://g20.bimmerpost.com/forums/sh...3#post26711153 |
09-22-2020, 08:17 AM | #11 |
Rep 219
Mine are SUPER old. I bought around 2010 for $40 from an auto parts store. I can send you a pic if you want, but they are regular old ramps and ive been up and down them with my lip a few times, no issue.
09-22-2020, 09:39 AM | #12 |
Rep 190
Whats the lip clearance, though?
on my g20 its like 7 inch which apparently leaves an approach angle of 11.2 degrees max. I like the race ramps, but theyre super expensive and not sure if I can get the ones I need here in UK |
10-26-2020, 07:13 AM | #13 |
X3M Comp is a beast
89
Rep 171
My ramps wont work with my lip. So I just jack up the car and put the ramps backwards under each wheel. Its up a little extra work but no chance destroying the lip. Which I have never scraped.
10-29-2020, 05:48 PM | #14 |
Rep 167
Rhino ramp will not work with a front lip. The lip touches the ramp before the wheels even touch it. Wasted my time and money on it. You would need something more lowered car friendly.
