      03-18-2020, 10:00 AM   #1
bimmer456
Drives: 340i
Thermostat recommendations?
So this thermostat has been giving me some issues since I don't have a c wire. Thought I'd upgrade a couple years ago but knew there might be some caveats vs just sticking with a dumb thermostat. About to switch back but won't be going back to the old mercury thermostat something a little newer maybe but not necessarily with any smart features or WiFi. Any recommendations?
      03-18-2020, 10:04 AM   #2
Salty Dog
Salty Dog's Avatar
3579
Drives: Austin Mini,MBGLK, Porsche 993
I used some of these tutorials and found them helpful.
https://www.youtube.com/watch?time_c...ature=emb_logo
      03-18-2020, 11:21 AM   #3
Alfisti
Drives: 2008 Saab 9-3 Combi
I am looking for a dumb thermostat too because i think having google spying in your house is insane. Looking for one with a nice big screen but they all seem to be smart ones which is annoying.
      03-18-2020, 11:47 AM   #4
bimmer456
Drives: 340i
I think it will be pretty easy to install a basic thermostat just label the wires and attach to the same terminals in the dumb thermostat no need to pay a technician $200 bucks when I can do it myself in two minutes.
Rmtt8203.00
      03-18-2020, 12:01 PM   #5
Rmtt
Rmtt's Avatar
Drives: 2011 BMW 128i, 2008 LS3 C6
I haven't looked in ages....but you can google the color coding for them as most HVAC controls are standard.
I changed mine awhile back.
Everybody has a gameplan....until they get punched in the mouth.
      03-18-2020, 01:28 PM   #6
sethwas
Drives: 228i
They make C wire adapters that allow you to bridge a ground connection. (this gets installed in your AC fan coil in the closet). You then connect the wires differently in back of the thermostat itself.
Or you can simply replace the Nest. They have super super slick software, but as an actual thermostat they don't regulate temperature as good as a honeywell (or even carrier). Unless you are married to the nest ecosystem there are better thermostats (ecobee comes to mind).
Seth
      03-20-2020, 03:17 AM   #7
mecheng77
mecheng77's Avatar
  [0.00]
  [0.00]
Return it and buy an ecobee, it takes power from the furnace so no battery to worry about
vreihen1620851.00
      03-20-2020, 08:48 AM   #8
FuriouslyFast
Drives: Miss Daisy
I bought a Nest t-stat & it was DOA. Got a replacement & same thing. Got an Ecobee & 100% trouble free so far!
vreihen1620851.00
      03-20-2020, 09:15 AM   #9
NoGuru
NoGuru's Avatar
779
Drives: 335is
2021 Chevy Silverad ...  [0.00]
2014 CTS  [0.00]
2011 335is  [0.00]
I can attest, the Ecobee is pretty awesome.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
vreihen1620851.00
      03-20-2020, 09:35 AM   #10
bimmer456
Drives: 340i
I was told if you don't have a c wire the eco bee won't work though there is an ac adapter for it to plug into a wall outlet. The nest gets around this by attempting to get power from one of the other wires. I was able to charge up my nest using a cell phone charger as it has a USB port in the back. If they had a way to route the cable to plug it into an AC outlet while montes to the wall that would work too. Maybe the dial could be narrower to allow a space to run the USB cable. After charging it it's made it through the night so the micro charge it gets from the rh wire should sustain it for a few months hopefully before needing another charge.
      03-21-2020, 08:00 AM   #11
2000cs
Drives: Potato
We have Honeywell thermostats but they are both smart. I like being able to control them from the couch or out of town (if I ever go out of town again). What I learned putting them in two houses over time is that the type of system you have might not be compatible with all t-stats. A geothermal heat pump has fewer t-stat options than a regular gas furnace, for example. So be sure to either get a truly universal t-stat (esp if you’re likely to replace the equipment soon), or one that you’re sure works with your equipment.
      03-21-2020, 11:04 AM   #12
I have a "sorta smart" thermostat. It's programmable but not connected to teh interwebz. Does everything I need done and nothing that I don't.
lakefront646.50
MKSixer34133.50
      03-21-2020, 11:22 AM   #13
oVeRdOsE.
oVeRdOsE.'s Avatar
3583
Drives: F25 E91 Audi Avnt E90 Cayenne
for 24v thermostat I've tested few.
My 3 first pick
1- Venstar T8000 series
2- Ecobee 3
3- Nest last gen
I really like venstar because of the 'unlimited', option. For more advanced user.
Ecobee is a great balance.
Nest just dont et enough setting for my taste, its a dummy user thermostat. It was perfect for my gran ma tho.
      03-21-2020, 11:34 AM   #14
zx10guy
Drives: 2013 135i
Another Honeywell user/owner here. So far it does everything I need and has worked reliably. I have it in my vacation home and use it to pre-condition the house before I get there. It also saved my bacon a couple of times when the furnace malfunctioned during a winter where we were having long record cold temps. I got alerts that the interior temp was way below the set temp on the thermostat.
It also helped me get some money back from my ISP as I had records that there were extended outages that were on their end because I was getting email notifications the cloud server was not getting any communications from the thermostat.
Originally Posted by Lups View Post
We might not be in an agreement on Trump, but I'll be the first penis chaser here to say I'll rather take it up in the ass than to argue with you on this.
      03-23-2020, 12:16 PM   #15
flipnkraut
flipnkraut's Avatar
Drives: 2016 BSM M3
... do you only have 2 wires for your thermostat? That's the only configuration that an AC plug would even be an option. If you have at least 4 wires, the ecobee comes with a power extended kit that you wire up to your furnace if you don't have a c wire. That will send power down your existing wires to the ecobee.
      03-29-2020, 06:08 PM   #16
Kolyan2k
Drives: 2006 S2000
Nest has been Ok, had to pay extra for remote temp sensors. I'd try Ecobee (comes with free remote sensors) but it's not 100% compatible with my system.
I really like when I walk close to thermostat it automatically displays current temp and gives hourly changes, very useful. Dont know if Ecobee does that
      03-29-2020, 07:15 PM   #17
bimmer456
Drives: 340i
Seems like the nest is working now. Maybe they updated the software. I like the ability to use the app to adjust temperature.
