03-31-2020, 05:04 PM | #1 |
Rep 2,141
Drives: 2011 E92 M3
S54 Crank Awesomeness
I just have to share this.
An owner with an S54 with that spun a bearing was given the advice to "emery cloth" it and it should be good to go... Ah, Facebook for the win. Attached is the photo of the crank. Hey deansbimmer, this will buff out, right? Stay safe out there.
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
03-31-2020, 06:01 PM | #4 |
Hoonigan
6851
Rep 3,000
Drives: '09 328i, '98 Wrangler
I've actually done similar. Got some muriatic acid and let the crankshaft sit in it for a few hours and cleaned the aluminum off the crank journal from the connecting rod.
To be fair this was on a 9hp snowblower engine, I wouldn't attempt that on an S54. Edit: This also likely wouldn't work because I believe the bearings in the S54 are lead not aluminum.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
