Speaker Upgrades for E90
05-07-2020, 07:03 PM | #1 |
Rep 68
Has anyone upgraded their speakers? I've seen the ads for BAVSound, but they seem pricey for what they are. I also saw Crutchfield carries vehicle specific Focal's, and Bimmer-Tech has their own upgrades as well. Is it worth it, how hard was it, what's the general experience?
05-07-2020, 07:14 PM | #2 |
Rep 13,122
To correctly upgrade a BMW sound system you need to know
which of the three common system you are starting with. This does not mean which Head Unit you have it means which sound system you are starting with. Upgrade difficulty is dependent on what you start with the middle system Hi FI option 676 is the easiest to upgrade. To find out what you have put your vin in mdecoder.com 676 option is Hi FI 677 or 688 is Top Hi Fi often called Logic 7 neither option is stereo with no amp and no tweeters. There is a whole stereo sub forum here. which is where the next links come from. BMW stereo types http://www.e90post.com/forums/showthread.php?t=352586 http://www.e90post.com/forums/attach...2&d=1266451970 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/showthread.php?t=138949 http://www.e90post.com/forums/attach...1&d=1209780865 http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ http://technicpnp.com/menuDiagrams/d...e90_92_93.html http://www.musicarnw.com/page-2/ http://www.e90post.com/forums/attach...3&d=1169133185 http://www.e90post.com/forums/attach...1&d=1209780605 http://www.e90post.com/forums/showthread.php?t=641323 http://www.e90post.com/forums/attach...4&d=1278871872 http://www.e90post.com/forums/showthread.php?t=343673 You can put it something much better than any of the stock system but a medium low price would be around 1500 plus in parts. Depends on how deep your pockets are and how much you value your car tunes. You are right I think Bavsound is rather expensive for the price . I believe the Bavsound speakers are made by diamond audio, at least that was the old rumor. Both the Bimmertech and Bavsound DSP/Amps are remarketed Audiotech-Fisher Helix units. Last edited by ctuna; 05-07-2020 at 10:48 PM.. |
05-07-2020, 10:01 PM | #3 | |
Rep 68
It’s the HIFi (676) system. Any opinions on the drop in replacements (Bavsound/Bimmertech)? |
05-08-2020, 09:55 AM | #5 |
Rep 68
Thanks ctuna, appreciate the help. I'm thinking about going with the Match 7BMW unit (https://www.crutchfield.com/S-vhsMqB...H-UP-7BMW.html) because it's plug and play before I start down the speaker upgrade path. Any disadvantages to doing it that way versus going with the JL Audio and custom harness route?
05-08-2020, 12:39 PM | #6 |
Rep 13,122
The Hi Fi system is super easy as far as wiring goes .
Most people would just buy a Technic Harness which is a plug that goes into the factory amp plug(dissconected by a single lever) and breaks out the signal.(Technic Link supplied) I don't know exactly what the Amps come with as far as and adapter for the stock amp connector. If you buy the DSP/Amp be aware you will have to determine where to route the channels and you will have to tune it yourself. You will definatly want better speaker to handle the power for at least everything in the front. Looks like the 7bmw comes with a harness. I would download the manuals from crutch field or audiotec fisher to get familiar with it. You will need better speakers to handle the power especially for the under seats. I don't have anything bad to say about JL I have one of there amps myself. I think audio tech fisher is ahead on the DSP. they have been doing these types of DSP/AMPs with decent to great power longer than anybody else. Also Hi Fi system in the e9x has no center channel you can put one in if you want you would have to run another wire though. Last edited by ctuna; 05-08-2020 at 01:27 PM.. |
sk193918.50 |
05-08-2020, 01:03 PM | #7 |
Rep 780
Drives: 2009 BMW 328i, Honda Civic Hat
BavSound yoooo best upgrade!!!! Underseat subs. Everyone who sits in my e90 says my sound system is so clear and is the best. Any music even Jazz plays well. Ghost underseat subs and if u write a review u get 35$ refunded back hahahhahaha. And they have discounts alot. Plus warranty.
05-08-2020, 01:45 PM | #8 | |
Rep 428
Drives: 2008 BMW 335i Coupe
Set? |
05-08-2020, 04:00 PM | #9 | ||
Rep 780
05-08-2020, 04:10 PM | #10 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
You need to figure out your budget and from there decide on :
1) head unit 2) amp or amps 3) DSP or amp w/ built in DSP 4) speakers 5) subs (underseat) 6) sub woofer - trunk w/ ski pass It would very easy to spend $1500.00 on just speakers & a DSP w/ an AMP built in. I would highly suggest getting a center channel speaker and hardwire it into the OEM harness. |
05-08-2020, 08:26 PM | #11 | |
Rep 68
05-08-2020, 09:05 PM | #12 |
Rep 13,122
One of those Audio Tech fisher DSP/AMPs or one from the major
brands and some decent speakers for the fronts will put you in a different world . The OEM Head Units are good enough for sound quality though if you want modern features BMW is kind of behind on that at least for the E9x series. There are a lot of stereo purists that think rear speakers and center speakers are a communist plot. |
sk193918.50 |
05-08-2020, 09:57 PM | #13 |
Rep 137
I'd do the Audiotec-Fisher 7BMW. It's got a great DSP & comes with a tune for your car. Do that amp & then figure out if you need to change anything else. It's really good and a really easy install. Also has sub out if you want to add a real sub without issue.
sk193918.50 |
05-08-2020, 10:48 PM | #14 | |
Rep 68
05-09-2020, 12:47 AM | #15 |
Rep 13,122
https://unexpectedcreations.com/mobile-audio/
You might want to talk to Don at unexpected creations for a package. I have seen the 7bmw a little cheaper sometimes. (than the crutch field price) |
05-09-2020, 08:56 AM | #16 | ||
Rep 6,968
I would absolutely encourage you to get a center channel speaker & hard wire it into the OEM harness. It sounds like you are leaning on getting one of the two after mkt DSP/amps & speakers to match. The center channel speaker will help the DSP/amp sound that much better. The only thing I don't like about the BAV sound speakers is that they don't publish their specs. Sort of silly, really. 99.9% of companies do. Most people like how they sound. The only thing is, if you want the complete package (underseat subs included), you are spending $1200.00 on speakers... 😣 For almost literally 1/2 that, you can get a used set, in very good condition, of BMW Individual Audio speakers that includes the underseat subs. The M3 guys prefer either BMW IA subs or the BAV sound subs. Just something to consider is all. |
