30FF no power to the boost solenoids
05-13-2020, 04:39 PM | #1 |
Rep 13
Hey guys first time poster will give you a quick recap of the situation.
Bought a E92 335 2007 last year with full bolt on and a JB4 car ran great for the whole summer no problems at all and since i live in Sweden i put the car in winter storage during the winter. During the storage time i decided to upgrade the charge pipe since that was original and i did not disconnect the battery while doing so and by accident i touched the generator with my ratchet and it came a big spark anyway i completed the install and started the car everything seemed normal no codes or funny noises did not think more of that. And now its summer and i finnaly can take it out of the garage and i have 0 boost so i started to troubleshoot what i've done so far Checked car for codes and only a 30FF code pops out after you floor it for a while Checked chargepipe for leaks Checked hoses from intercooler Changed all vacuum lines Checked all fuses in the glovebox and the 50 AMP in the ECU box Checked both actuators so they close the wastegates All seem fine so now today i checked the boost solonoids and i T'd in to them and checked the vacuum while idleing, It came out at 0 on both solonids then i checked the canisters and i had vaccum in them so i then proceded with applying 12v and vaccum to the solonids and they appear to be bleeding it out normaly and clicks when applying power so that just leaves me thinking they dont get any power from the harness? Is there a fuse for that harness or something im totaly out of idéas would appreciate some help! EDIT 18 May: So tonight i decided to clean the connections for the boost solonoids and test the same vaccum test on them again and to my surprise i got a reading on the gauge around 6-10 inhg on idle and 25ish when driving full throttle but still no boost.. guess there is a leak after all Last edited by Mysko1337; 05-18-2020 at 04:04 PM.. |
05-14-2020, 12:49 PM | #3 | |
Rep 13
Edit: Found out when browsing that there are 5 more fuses in the ECU box that i haven't checked will post back with results! Last edited by Mysko1337; 05-14-2020 at 01:07 PM.. |
05-15-2020, 11:44 AM | #4 |
Rep 13
Went to work on the car today again
Pulled all fuses in glovebox again, They are all fine Pulled all the fuses in the ECU box under the hood, They are all fine, Tried installning a new battery - No difference Fully removed JB4 from Ecu - No diffrence Only thing that happend was after i swapped the battery i got a 2EE6 (cooling fluid sensor) and the radiator fan started in full speed, Shut the car down and cleared the code and started it up again and it was all normal again, Feels like i've tried everything now anyone got any more idéas before have to call the dealership =/? |
05-15-2020, 12:43 PM | #6 |
Rep 946
Drives: e92 335i, f22 m235i, e30 325is
Smoke test?
05-15-2020, 01:52 PM | #7 |
Rep 13
Reinstalled and tested the old charge pipe (same O-ring tho) and i had the same results no power a few days ago so it should not be that, Unless i installed it wrong or something
05-15-2020, 06:47 PM | #9 |
Rep 946
05-15-2020, 09:43 PM | #10 |
Rep 541
this is gunna sound basic ... but unplug your boost solenoids, spray the connections of the plug and the solenoid with electric cleaner, then put some dialetric grease on the plugs, the push them back in very firmly.
i was chasing a boost leak and it was driving me nuts, i had brand new solenoids! i did the above and realized I was gettin 30FF b/c likely one of my boost solenoids had a poor connection. |
05-16-2020, 04:23 AM | #11 | |
Rep 13
05-18-2020, 03:42 PM | #12 | |
Rep 13
So tonight i decided to clean the connections for the boost solonoids and test the same vaccum test on them again and to my surprise i got a reading on the gauge around 6-10 inhg on idle and 25ish when driving full throttle but still no boost.. so i assume i got a leak somewhere back to square one. Going to try and buy some stuff so i can pressure test it tomorrow if i can find them in stock. |
05-19-2020, 01:11 PM | #13 | |
Rep 541
did you replace ur vac lines? |
05-19-2020, 10:56 PM | #15 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
Vac line going from the DV to the intake manifold? |
05-21-2020, 03:01 PM | #16 |
Rep 13
Tried to do a pressure test but i need to find a way to hold the inlets in place since they dont hold any pressure and its almost inpossible to hear any other leaks over that leak, also tried to hook it straight to the chargepipe and spray soapy water around the throttlebody and siliconpipe to the intercooler, could not find any bubles
there.. Will probably give it another try but i dont got high hopes So i booked a time at the dealer for troubleshooting in 2 weeks. View post on imgur.com Last edited by Mysko1337; 05-21-2020 at 03:20 PM.. |
05-21-2020, 03:03 PM | #17 |
Rep 13
05-22-2020, 09:07 AM | #18 |
Rep 776
05-22-2020, 11:41 AM | #19 | |
Rep 946
05-22-2020, 03:36 PM | #21 | |
Rep 13
Hope i dont have the same bad luck cant affford new turbos right now (thanks corona) dealer will check it in a few weeks.. |
