Battery vent tube routing? Where should it go?
05-14-2020, 09:00 PM | #1 |
Rep 541
Ok i have to replace my battery. Just pulled the old one out, there’s a vent tube elbow in the battery but no hose. Great!
I will go buy a hose tomorrow. But when i do, what is the proper way to route the battery vent tube? Where should i place the end of the hose? |
05-14-2020, 09:54 PM | #2 | |
Rep 4,102
Most Flooded Lead Acid (FLA) batteries that are sealed and vented have a hole in EITHER END, so you need to make sure your replacement battery has a PLUG inserted in the Rear end (Negative Post) or the vent tube is for nothing. Most "International" or Vented Batteries come with both the elbow and plug, and some come with a new vent tube. ANYONE who can advise: Does the AGM battery have the same vent tube setup described above? Does your car currently have an FLA or AGM Type battery? Do you know the size & Ah rating of the battery currently installed? Do you have INPA, ISTA, or other software or Scan Tool that can read current Setting/Option in the DME Power Management Module or CAS so you know whether or NOT you need to change the code/option? If the battery currently installed is NOT the original battery, you should NOT assume that replacement battery is correct for your vehicle or that the Code/Option was changed for the correct TYPE & Capacity of the replacement battery. The battery compartment is large enough for an H8/Group 49 battery which should have at least 90 Ah capacity. George |
05-14-2020, 10:47 PM | #3 |
Rep 541
George i just bought an interstate mtp 49/h8. I’ll have to code my car so i have that handled.
My problem is i just am taking this old battery out which was installed by a mechanic a few years ago and am realizing the vent tube hose is gone. I need to know where it routes too. I don’t see a grommet for it to go to. Is it supposed to dangle through the floor into the fender or something? My battery has vent hole plugs in both sides. I believe on the e92 it’s normally plugged into the positive terminal side. |
05-14-2020, 11:20 PM | #4 | |
Rep 4,102
Gray hose to Elbow & Grommet to left of two "Transfer Points" forward of battery. George Last edited by gbalthrop; 05-14-2020 at 11:27 PM.. |
feuer4277.00 |
05-15-2020, 12:45 AM | #5 |
Rep 541
You freakin rock man! I would have never found that. Mines likely the same. Thanks a million that made my night
06-14-2021, 11:04 PM | #6 |
Rep 59
gbalthrop, thanks for the picture. My tube came off when removing the battery and I didn't notice the little elbow in the corner. To answer your earlier question, the AGM battery I just installed, Interstate MTX-48/H6 AGM does have a vent hole on both pos and neg ends of the battery. The vent tube plugged right into it on the positive side.
'06 330i Alpine White
06-14-2021, 11:26 PM | #7 | |
Rep 4,102
The other half is: Do you have a PLUG in the hole on the opposite (Negative Terminal/Rear) end. IF NOT, any Hydrogen Gas or Battery acid that SHOULD go out the tube you installed on battery front is more likely to come out the rear opening. I don't know that much about AGM batteries, but I would assume that if they have vent holes, they can eject Hydrogen gas or battery acid similar to their FLOODED counterparts. It's EASY to NOT THINK about plugging the vent on the other end, and the battery doesn't come from the store with any plug installed. "International" batteries with vent holes just come with an elbow and a small plastic plug, and YOU have to know what to do with them. George |
06-14-2021, 11:42 PM | #8 |
Rep 59
Hi George,
I read about the plug in your post above. When I was at BMW parts counter today buying a new battery hold down bracket (something one of the shops along the way that replaced a previous battery apparently left off and discarded...), I asked about a plug for the vent hole. They didn't know about it. So for now, I don't have the hole on the negative side plugged. Where do I find a plug for it? Edit: Actually, I just found an article on the web that said the battery should come with a plug, and showed a picture of it attached to the red positive post cover that gets removed. Sure enough, it has a plug on it that I almost threw away. Will put this on the battery tomorrow. Thanks!!! Robert
12-13-2021, 06:31 PM | #10 | |
Rep 4,102
George |
