05-16-2020, 10:49 AM | #1 |
F36 GC
143
Rep 259
System too Lean - Help Please
Hey guys/girls,
Just changed the ignition coils on 2015 435 GC. Running FBO + BM3 Stg 2 + NGK gapped to .022. I changed the plugs a few weeks back but did not use new coils. I decided that I should get new coils cause the car is at 70k miles so I did and just finished installing them. Went with the Ignition Projects N55 set. Cranked right up, idled beautifully, but then I got a P0171 System Too Lean Bank 1. Everything is plugged in and connected and the only change is the brand new coils. Have never had this code before. I also turned off the cold start setting yesterday morning on BM3 so do not know if that is relevant in any way? Those are the only two things different as of recent. Anyone else experience this after changing coils? When I did crank the car I had the hood open and engine cover off while I made sure the car was tip top and the car smelled very gassy around the engine bay. Thank you for any input or help! |
05-16-2020, 12:13 PM | #2 |
Rep 73
Sounds like the fuel is not get burnt which means no spark. Have tried the old coils? Double check that the new coils are all properly connected to the plugs. Also try swapping the coils around to see if the code moves to a different bank
ozymandias435142.50 |
05-16-2020, 01:58 PM | #3 |
Rep 7,634
I think this is another lesson of don't fix it if it's not broken, lol.
Did the code appear at idle or after driving? Did you try clearing the code and doing a little driving to see if it came back? Any datalogs of the issue? We need to see actal vs target AFR. |
05-16-2020, 02:29 PM | #4 | |
F36 GC
143
Rep 259
Will attempt to get a log tonight |
05-16-2020, 02:35 PM | #5 | |
Rep 7,634
STFT is the main one to keep an eye on. Around 0 is good; it means the DME isnt really making major corrections based on AFR. You can always monitor lambda versus target. If you see spikes in AFR (higher = leaner), you might have a misfire or other issue. |
05-16-2020, 02:55 PM | #6 | |
F36 GC
143
Rep 259
05-16-2020, 07:13 PM | #7 | |
Rep 93
unburnt fuel means rich a different bank means a Vee engine |
05-16-2020, 08:30 PM | #8 |
Rep 7,634
Sorry, but this is wrong. Unburnt fuel means LEAN. O2 sensors read oxygen, not fuel. If you have a misfire or other issue that causes the mixture to not be combusted, you get excess O2 in exhaust, which reads LEAN.
05-18-2020, 03:00 PM | #9 | |
F36 GC
143
Rep 259
Either way I did find some interesting stuff on there. -Ign 2 seems to be lower than the other 5 (3 points or so) for most of the rpms until the higher RPMs where it catches up - Overboost around 3200 rpms (17.7/16.8) - Load Actual is wayyyyyy low of Load Target. Not sure if they are supposed to match or not. Went back and just did another log and made sure this one recorded. https://www.bootmod3.net/log?id=5ec2...729b5be725232a This one is more of the exact same. That ignition 2 problem is not on any of my other logs and the only difference is the new Ignition Coils. Please take a look and see what you think about the numbers. You seem to be incredibly knowledgable with all of this. Thanks man |
05-18-2020, 03:12 PM | #10 | |
Rep 7,634
Not sure about recovering the log, i use MHD not BM3. - For cyl 2, its not unusual to see some deviation in timing between cylinders. Now if it seems like cyl 2 is always and repeatably having issues, it might be worth investigating further. For example you could try swapping cyl 2 coil with another one and see if it follows the coil. You could also pull that plug and double check the gap. But the small deviations in the log aren't necessarily cause for concern. - The overboost early is typical of BM3. I saw someone else overboosting 5psi... which is a bit much. Yours looks "fine" in that sense that its typical BM3 tune behavior. - Also a artifact of BM3. They dont used a load based tune like stock or MHD, so your load will never be close to target. So not indicative of a problem. |
05-18-2020, 03:24 PM | #11 | |
F36 GC
143
Rep 259
Seems to be cyl 2. Ran 3 Logs today, lost 2 of them, but in all 3 logs Cyl 2 was laggy. Will let the engine bay cool down and I will pull that plug, check it, and swap coils 1 and 2. Hard for me to think there is a coincidence with the CEL I got the other day about being lean right after changing the coils, smelling all of the gas, and now cyl 2 seems to be acting a fool. what would you say the benefits are of load based tuning vs Bm3? Last edited by ozymandias435; 05-18-2020 at 03:30 PM.. |
05-18-2020, 03:47 PM | #12 | |
Rep 7,634
I am not entirely sure how much adaptations play into coils... i know there are specific flash options for different coils, so my initial thought was that there is some sort of DME adaptation going on, which could explain why you got a code right after install but it has not reappeared since. I suppose a misfire on cylinder 2 could also lead to a lean condition, but if there was a serious problem with that cylinder (coil/plug, etc) i think it would be more apparent. I personally like the load based approach because i feel like it better adjusts for variations in atmospheric conditions to deliver consistent power and it is a bit more conservative in terms of implementing protective measures, e.g. throttle closures for overboost. Not going to say one is "better" than the other since they can both work, just my 2c. Load based is also OEM design. |
05-18-2020, 04:45 PM | #13 | |
F36 GC
143
Rep 259
What do you mean exactly by the MAF? what would stability or ideal MAF look like? I have Dinan CF Intake and aluminum pure inlet pipe. The silicon connection binding the two is difficult to get lock tight on the inlet pipe cause the inlet mouth is almost too close to the Dinan mouth if that makes sense. Could potentially be a small leak there. Will check that as well when I pop the hood |
05-18-2020, 04:53 PM | #14 | |
Rep 7,634
As a point of comparison, here is a log of mine - check out the MAF curve; much smoother without those "oscillations." I am on stock intake with a drop in filter. https://datazap.me/u/thejeremyman9/4...0&data=4-19-25 |
05-18-2020, 05:25 PM | #15 | |
F36 GC
143
Rep 259
Your MAF reading is very linear and solid. |
05-18-2020, 05:54 PM | #16 | |
Rep 7,634
05-18-2020, 08:12 PM | #17 | |
F36 GC
143
Rep 259
Swapped out the Dinan CAI for the factory M performance top with drop in filter. Still a closed system. Went and just did another log: https://www.bootmod3.net/log?id=5ec3...729b5c747a1dde -2 Cyl timing cleared up -MAF still bouncing and it appears stock airbox flows less in lower RPMs Also is that MAF low for FBO + Fabspeed Sport Cat + Pure Inlet + BM3 Stg 2?? Feel like I see a lot of other logs that are getting up to 40. I really wonder if the AFE Ram scoop is causing the turbulence |
05-18-2020, 08:22 PM | #18 | |
Rep 7,634
Interesting that it flows less at lower RPM? I honestly dont pay much attention to the actual MAF values themselves, but i do recall other people maxing out the MAF with BM3 stage 2 FBO? Might be worth looking at other logs in the BM3 thread to see. I thought about the scoop also... i guess its easy to test. You would expect the filter to dampen that turbulence, if any, especially with how much air the engine is sucking at WOT. (In other words i dont think the scoop is actually producing positive pressure at the MAF; i think you are sucking in more air than it is "scooping") |
05-18-2020, 08:39 PM | #19 | |
F36 GC
143
Rep 259
And again thank you for all of your help my man |
05-19-2020, 08:09 PM | #20 | |
F36 GC
143
Rep 259
Just did a log and hit 45.3 Peak MAF reading. Thats 10 higher than my peak from yesterdays logs. 10 higher is pretty insane Was having a hard time getting the Pure to seal to either the Dinan or the Factory Inlet....the pure actually sat inside the mouth of both instakes and there was some space around it that probably was creating a small leak. On top of that maybe the scoop was creating that crazy turbulance? Todays Log https://www.bootmod3.net/log?id=5ec4...0b431d55ba8756 |
05-19-2020, 09:21 PM | #21 | |
Rep 7,634
It's hard to say whether it was the scoop or the leak causing some buffeting or instability at the MAF since you changed both at the same time. I guess if you really wanted to know you could reinstall the scoop now and see how it affects the magnitude of the MAF readings and the curve. EDIT: Also looks like you had a few degrees of timing pulled from 4 cylinders up top. Last edited by thejeremyman9; 05-19-2020 at 09:26 PM.. |
05-19-2020, 09:29 PM | #22 | |
F36 GC
143
Rep 259
I did notice the timing pulled as well. Im switching to new factory coils tomorrow. Going to check the other 5 plugs as well and make sure they are gapped correctly. Have not been impressed with these coils I installed last Friday |
