Active headrest 93AF fault code
05-17-2020, 05:18 PM | #1 |
2009 E90 328i
Rep 46
Hello everyone
Started car and had a seatbelt warning and airbag symbol lights on. Scanned and came up with 93AF active headrest fault (passenger side). Searched this site and also googled 93af and didn't get a lot of hits. But most that did come up had both 93AF and 93Ae at the same time. There didn't seem to be a lot of consensus on a fix, especially for the single code. I did try clearing the fault but it came back next day. My knee jerk reaction is to just order a new active headrest off ebay...there are a few listed on there that match mine and they run under $100 shipped. I just worry I will get the new one and it wont fix the issue. Anyone have any ideas to move forward? BTW, 2009 328i USA car Non sport seats Thanks |
05-17-2020, 06:41 PM | #2 |
Rep 1,579
Inspect the wiring under the seat. The active headrest wiring is tacked onto the side of the original pre-LCI connector. I could see that being damaged by something stuck under the seat. It is just 2 wires. Raise the seat up all the way and you can see them on the front edge.
05-17-2020, 07:35 PM | #3 |
2009 E90 328i
Rep 46
Thanks for the suggestion.
I just went out and pulled and prodded every wire and connection under there but nothing seemed loose, disconnected or broken. Ill check again tomorrow when I have more light. Last edited by dan4081; 05-17-2020 at 08:03 PM.. |
05-21-2020, 06:49 PM | #5 |
2009 E90 328i
Rep 46
Don't want to jinx anything but after getting the warning repeatedly for 3 days in a row, it hasn't come back in the past 4 days.
Didn't do anything except put my seat back in the upright position (carwash people had laid it down pretty far), pulled and tugged each wire under seat, and cleared the code with Inpa each time it came up. |
05-21-2020, 09:25 PM | #6 |
Rep 5,691
That tells you even more so that it’s a wiring short because now that you’ve moved the wire from where it was shorting against the seat frame. Check closely and you’ll find it.
05-22-2020, 06:45 PM | #7 | |
2009 E90 328i
Rep 46
I looked under there and there are wires all over...wasn't sure which one it was and pulled on all of them. Thanks!!! |
05-23-2020, 08:55 AM | #8 |
Rep 1,579
Remove the hard plastic cover on the back of the seat. There are 2 plastic plugs in the bottom edge. Once removed, the cover slides down and away. You can now find the headrest wiring coming out of one of the headrest shafts. Trace it down and over to the plug.
08-11-2023, 04:34 AM | #11 | |
Rep 2
Check under seat
Sure enough, the female side (white head also) was nearby, so I simply plugged it in, and then re cleared all codes. Voila. Issue solved. My case anyhow, hope you find your issue. |
