Oil Level Sensor in my 2006 Bmw 325i
05-22-2020, 09:36 PM | #1 |
Rep 3
I swapped my oil level sensor out on my 06 325i and it’s still not reading my oil level. I have 210k miles on it and I’m wondering if these cars just get to a point where they no longer read oil levels ? Has anyone experienced this issue before ?
05-23-2020, 06:27 AM | #2 |
Rep 18,800
So the e-dipstick is not reporting an oil level in the gage cluster and not indicating any error? You should scan the car for BMW trouble codes as a first level of troubleshooting.
05-23-2020, 12:42 PM | #3 |
Rep 13,122
Get the bimmergeeks.net cable and diags.
It may be likely that one of the devices that the BSD Line shares with the oil sensor is bad. You might try unplugging the IBS for a little while and see if you can take a reading. |
05-23-2020, 01:58 PM | #4 | |
Rep 4,088
Try to read oil level BEFORE starting engine ("Static" oil level, read with Ignition ON but engine OFF, Press START WITHOUT pressing Brake or Clutch). NOTE exactly what message or info is displayed on Instrument Cluster. THEN try to read oil level AFTER starting engine. NOTE exactly what message or info is displayed on Instrument Cluster. Let us know that information. Do you have ANY Scan Tool or Diagnostic Software? Fault Codes saved in DME (Engine Control Module) would be helpful in diagnosing the issue. Do you have any warning lights on Instrument Cluster after engine is started? Here are TIS circuit diagram for (1) "Oil Supply" which shows OZS as "B62540a", and (2) Interface Signals circuit, which shows the four components which communicate with the DME via the BSD Interface or BUS, see the Violet-colored wires: https://www.newtis.info/tisv2/a/en/e...ne-oil/oXDCoJm https://www.newtis.info/tisv2/a/en/e...rfaces/g2ozm6t Do the following tests at the Connector to the OZS under the car with Multimeter: 1) Test for 12V+ (with Ignition ON) in reference to chassis ground at Pin #3, Orange wire, and for continuity to chassis ground at pin #2, Brown wire. 2) IF those tests are OK, check for IBS disconnected from Chassis Connector, X13895 at the TIS Installation Location shown in this link (above battery negative terminal): https://www.newtis.info/tisv2/a/en/e90-325i-lim/SQE9rMY The TIS wiring diagrams are "interactive" so you can get more information on a component, such as Installation Location or Connector View, by simply clicking on a component. George Last edited by gbalthrop; 05-23-2020 at 02:04 PM.. |
Efthreeoh17426.00 |
05-24-2020, 07:13 AM | #5 | |
Rep 18,800
If the OZS is defective, the gage cluster should come up with an "inactive" message at a minimum. It's such a simple device, that usually the problem is the circuit it plugs into rather than the sensor itself, as you are alluding to. Hope the OP figures it out.
05-24-2020, 11:31 AM | #6 | |
Rep 4,088
AFAIK, the Oil Level Sensor reading on the Instrument Cluster using the B/C buttons on the turn signal stalk, and resetting the Oil Service "counter" are two SEPARATE functions, and NOT related electronically, as far as chip function or programming. ANYONE have a link to "Fix"/"Workaround" for the 183,000 mile "limit" on CBS Oil Service "Reset"? Is there a "software update" where you can keep resetting (beyond 400,000 miles for "F30"'s sake ;-), or HOW do you just turn it OFF so it doesn't keep telling you that you need Service when you don't? "F30", you need to speak to the "knucklehead" at BMW who determined (either intentionally or accidentally ;-) that 183,000 was "End-of-Life". Send them some photos of your car & Odometer reading (displayed in km, as that's even MORE impressive). Thanks, George |
05-24-2020, 11:47 AM | #7 | |
Rep 18,800
There is a software fix for it, which simply codes out the past due oil notification from the combi, so it just doesn't appear as a notification (the ECU still thinks the engine is over sue for an oil change). Back in 2013 when BMW and I discovered the issue, BMW did not have a software fix (even though they has a service bulletin on it - I posted it long ago). BMW N.A. opened up a PUMA case on my car with BMW AG and at some point BMW AG fixed the software so the code-out now works; they never told me about it. The coding section has the details on how to code it out. * There is a guy on E46Fanatics with more than 620,000 miles on his E46. He found out the "limit" of the E46 odometer is 1,000,000 km. He car just stopped counting miles after 1 million kilometers. I wonder if that'll be my next problem... LOL.
05-24-2020, 02:36 PM | #8 |
Rep 4,330
if you have an ISTA install it's one of the service actions for the combi as well.
I can't remember the exact wording, but it's in there. I looked as I'm at 160K, so quickly approaching. |
05-24-2020, 04:55 PM | #9 | |
Rep 4,088
It would appear that either the Factory programming had a limitation in the mileage counter formula/computation, or the allocated memory area or field size is too limited, or something of that nature. If it's a programming error, that can be easily corrected. If it's a hardware limitation, then disabling it is the only practical solution. ANYONE got any reliable concept of WHAT is causing the 186,000 mile "ceiling", and/or what ANY "Fix" actually DOES, conceptually at least? BTW, "I don't KNOW" is an acceptable answer -- although seldom heard in the Trump era. For the RECORD: I (George) do NOT KNOW!!! Thanks, George |
05-25-2020, 09:09 AM | #10 |
Rep 4,330
the description stated it removed the oil life reminder from the kombi.
I think all it does is remove the nag on the cluster, but I don't know for sure as I haven't gotten there yet. |
05-25-2020, 09:18 AM | #11 | |
Rep 18,800
Obviously it's not a mileage or oil change "counter" problem bug in the software, or BMW would simply fix the bug. The SCBS-6006 routine just codes out the past-due oil service notification from the KOMBI so it doesn't show up as an annoying notification (I lived with the condition for more than 3 years BTW ). If the dealer reflashes the software, the notification comes back, as I found out after the airbag recalls were performed on my car. I had to take my car back to get the routine reinstalled.
05-25-2020, 10:42 AM | #12 | |
Rep 4,088
I have, but have NOT used, NCS Dummy in BMW Standard Tools. It shows the following Option (Coding) selection in the KOMBI Module: CBS_STAT_01H - CONDITION BASED SERVICE (CBS) STATUS FOR ENGINE OILANYONE who has/uses NCS (BMW Coding Software) might check to see if that option/setting is currently "anzeige" (display), and what happens when "sperre" (hide) is selected and saved instead. My SWAG is THAT is what the Dealer did, perhaps using software OTHER than NCS, and NOT understanding what was actually being done, but just following the "bread-crumb trail." I can see NO reason one would have to wait until 300,000 km (~ 186,000 mi.) BEFORE "hiding" Oil Service warning. I think that was just a CYA by BMW "Legal" to prevent possible liability for turning off the warning BEFORE the customer complained about the "inconvenience" of "the warning light from Hell". "F30", thanks for the pdf (again ;-). When I went to save it in my "Instruments" (KOMBI) Folder, I realized I had already saved that on 1/5/19. TMI/TLM (Too Much Information/Too Little Mind ;-) The fact that all the "highly-credentialed US Techs" you describe didn't know what the "Engineers in Munich" knew eight or ten years earlier (KOMBI coding) is rather amusing. I hope the US guys at least provided you with a free "loaner" during the 8 days. So much for "American Exceptionalism". George |
05-25-2020, 11:07 AM | #13 | |
Rep 18,800
In late July 2016, I found myself near my selling dealership, BMW of Charlottesville and figured I'd take a shot to see if the PUMA case had been resolved. The Service Manager at Cville BMW said he had heard of the issue and was familiar with the oil life monitor service notification, but that he had never seen a car with that level of mileage to "operate" on. We agreed that he'd try the fix and not charge me if it didn't work. Cville BMW was successful, and finally at 306,000 miles and 3 years of waiting, I was finally relieved from the effing oil notification. It cost me $100, just to add insult to injury. In August 2013 the dealership did provide a loaner for the entire 8 days they had the car. I had an F30 335i automatic. It was at that time, after driving such a crappy 3-series as I found the F30 to be, in combination with the oil life monitor fiasco, I decided at that time BMW would never sell me a new vehicle from their catalog. A review of any of BMW's 3-series since August 2013 I've done (and the eye-opening revelation Cadillac builds a great chassis) has proven BMW has become the old GM IMO . Now, dropping a manual transmission option from the G20 in the US market has further solidified my opinions and feelings toward BMW. My relationship with BMW cars goes back to the mid 1970's; but eh, the world remains non-static. If there is any lack of exceptionalism, my experience indicates it is with the Germans and BMW AG.
