N52 engine oil temp 250-260F
05-25-2020, 09:34 AM | #1 |
Rep 996
Retrofitted a temp gauge (cluster swap) but I’m seeing 250-260f operating temp. Is this normal?
Seems a bit high to me. I’m in nyc so it’s about 60-80 degrees right now. Last edited by porsche959; 05-25-2020 at 10:02 AM.. |
05-25-2020, 08:31 PM | #4 |
Rep 4,330
mine sits at 210 unless I'm being spirited.
I've never seen it higher than 240-250. my guess is the gauge needs to be adjusted. you need a can cable and perfekt toolbox. |
05-26-2020, 12:18 AM | #5 |
Rep 1,080
With a simple OBDII tester you can measure coolant temperature, and correlate to oil temp.
Also, after car has sat overnight, measure oil temp and compare to the ambient temperature. They both should be the same. |
05-26-2020, 11:44 AM | #6 | |
Rep 162
gauge has been calibrated with perkecttoolkit thing. |
05-26-2020, 03:09 PM | #8 |
Rep 624
Driving around today during a rare 95F day here, and the oil temp stayed pegged at 240. I retrofitted the oil temp gauge, and coded it with Perfekt Toolbox.
Cheers! |
05-26-2020, 04:01 PM | #9 |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
My operating temp is consistently around 240F-245F with 70F+ weather
Common sense is a flower that does not bloom in everyone's garden
05-26-2020, 07:51 PM | #11 |
Rep 996
05-26-2020, 11:42 PM | #13 |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
Use these values in perfekt toolbox:
71, 96, 121, 146, 171 I calculated these values to match the 160 250 340 oil temp gauge (like 335s or E92 328s)
05-26-2020, 11:58 PM | #14 |
Rep 996
05-27-2020, 01:22 AM | #15 | |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
06-06-2020, 10:05 PM | #18 |
Rep 733
You're seeing temps like that on a metal valve cover N52? Seems off. My 330i runs at around 200f, 215 at the most during hard driving. Later plastic valve cover N52s tend to run hotter, but they also warm up quicker which is of benefit. On the blacktop, 250 is perfectly normal, but I'm not sure about your situation.
However... with correct coolant temperatures, and no oil cooling system, I I fail to see too many ways that it can simply run hotter than other engines of identical specification. What does oil temp read with the engine off, and cold? |
06-06-2020, 11:48 PM | #19 | |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
06-07-2020, 01:08 AM | #20 | |
Rep 558
My E91N (N52K) oil temp stays in range between 97-110C when fully warmed up (20+ minutes of driving). I live in SF, outside temps here is 60-80F in the city year around. Coolant (not oil) temp behaviour should be as follows: - sprinted driving - 77C-97C - flat, constant speed - 97-110C Water pump operating range is between 39-250rpm. AC on expect it to be > 200rpm (mine just stays at max of 250rpm) AC off: - sprinted driving - cooling down (to low 80C target): 170-250rpm - sprinted driving - warming up (from low 80C to 97C) : > 40rpm - flat, constant speed: varies, usually ~ 140rpm |
06-07-2020, 11:19 AM | #21 |
Rep 4,330
my 328 has no oil cooler.
at 70F ambient and running down the road it's at 220ish if beating on it for 10 minutes, 245. I have never seen oil temps higher than 250. at 30F it runs at coolant temp. it is an xi so I do have an aluminum pan. |
06-07-2020, 11:25 AM | #22 | |
Rep 996
