BMW E90 4x4 ERROR ON DASH
05-27-2020, 10:08 PM | #1 |
Rep 9
So starting up my car in the morning this 4x4 and abs light turned on. Now Tn when I turned it again only the 4x4 came on. Car runs perfectly fine I'm not sure why the light is on. Any thoughts on what the light could mean or what could be? Thank you guys!
05-28-2020, 11:16 AM | #2 |
Rep 492
Drives: 2009 E93 M3 DCT
You have a very special BMW, it has started to "transform" into a 4x4 truck. Make sure that you don't scan for codes or otherwise fix it. If you do it will get scared and never complete the transformation. In all seriously scan the bloody car...............
05-28-2020, 11:24 AM | #3 |
Rep 7,215
Turn the steering wheel all the way to the left then all the way right. Also I bet your battery is dead.
trillrickyy3.00 StradaRedlands4998.50 |
05-28-2020, 11:27 AM | #4 | |
Is it the shoes!?
3885
Rep 5,112
It's like when people post "my computer is slow help" |
05-28-2020, 02:05 PM | #5 |
Rep 13,122
diagnostics required.
Did you do anything to the car recently. The speed sensors at all 4 wheels must be working as well as the DSX and the transfer case. Diagnostic Manuals Inpa/Ista D https://bimmerprofs.com/diagnostics-inpa-part-1/ https://www.google.com/url?sa=t&rct=...7x8H3pN8h1fMuF https://carmod.ru/files/icom/istad_en.pdf https://www.e90post.com/forums/showthread.php?t=1681573 https://www.bimmerforums.com/forum/s...-P-actually-do primary links https://www.bimmerfest.com/forums/at...9&d=1539905743 https://www.e90post.com/forums/showthread.php?t=1681573 https://www.bimmerfest.com/forums/at...1&d=1590283589 There is a whole xi subforum here https://www.e90post.com/forums/forumdisplay.php?f=16 Last edited by ctuna; 05-28-2020 at 02:44 PM.. |
05-28-2020, 07:13 PM | #6 |
Rep 9
05-28-2020, 07:16 PM | #7 |
Rep 9
I'm asking bc with this coronavirus going on I don't have the funds to go diagnose it,which is $150 at the dealership bro. But thanks I had in mind of diagnosing it anyways.
05-28-2020, 09:30 PM | #8 | |
Rep 492
05-28-2020, 10:09 PM | #9 | ||
Rep 9
05-28-2020, 10:30 PM | #10 |
Rep 4,088
Now that everyone has "vented":
OP, do you STILL have the 4X4 warning light? WHAT Fault Code(s) did you have, or do you NOW have? What Brand/Model Scan Tool do you have, and can it reset Adaptations? Have you tried that? Just like the SAS (Steering Angle Sensor) may need to be reset (turning Steering Wheel Lock-to-Lock a time or two), sometimes other modules need to be "Reset" or "Initialized" after battery is flat or disconnected. We'd like to learn something from this thread, and that STILL COULD HAPPEN. George |
05-29-2020, 09:41 AM | #11 |
Rep 7,215
05-29-2020, 12:05 PM | #12 |
Rep 4,330
