05-28-2020, 04:05 AM | #1 |
DYI Master
9
Rep 20
Max tune on lease
Hi guys,
I started to look into more and more things to do on my 330i in order to make it louder and maybe a bit faster (I'm talking about acceleration and not top speed). Exhaust, Intake, ecu, etc. Some of the mods can be installed without any warranty voiding, so that's what I'm looking for on a lease. For example, if I'm looking to upgrade my exhaust, I asked a friend of mine that works at BMW and he said that as long as I'm not deleting my OPF/GPF/DPF (gas/diesel particle filter) and replace everything back from that, I should be ok. So my question is, with this 2.0L, without voiding warranty, from what you heard or did to your car, what do you think is a possible max spec (HP) you can get out of it? |
05-28-2020, 11:02 AM | #2 |
Joint Chiefs of Staff
24204
Rep 190,807
im running a flash tune on my car and its leased, that being said you best bet is to get a piggyback. I recommend the JB+ for easy install/uninstall
05-28-2020, 11:27 AM | #3 |
Rep 42
Drives: BMW G20 330i & BMW G30 540i
Im also running a JB+ for a quick easy power gain and you can really feel the difference. As Mike from EPH said... a piggyback is the way to go for a lease and you can expect a 30hp and 30 tq increase but its mainly only felt from 1st to 3rd gear. Definitely worth it on a lease.
05-28-2020, 12:40 PM | #4 |
Petrolhead
1943
Rep 3,521
Mine is also leased and I’m running a JB4. And I absolutely love it. I had a JB+ but a JB4 on E20-30 runs circles around the JB+.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
05-28-2020, 02:55 PM | #5 |
DYI Master
9
Rep 20
Ok, I totally get it about a flash tune. An equivalent of the JB4 on European market would be RaceChip, have it on my Focus ST and totally worth it. But even further than this, maybe a GPF/OPF-back exhaust or cotton air filters are worth a shot. I'm interested on what you guys did and what are your numbers. Maybe with a mix'n'match I can get the best for my lease. I just need ideas. Thanks!
05-28-2020, 03:54 PM | #6 |
Rep 42
We understand but we only say JB+ because its the safest route to not voiding a lease warranty. Depending on your dealership they may or may not any more modifications slide like your "Exhaust, Intake, ecu, etc" comment... anything that touches that ecu will most likely void you. Theres this free mod everyones been doing with their 330i g20s and its to keep your exhaust valves open all the time to maximize the sound look it up on YouTube on how to leave them open its literals a 30 second job that maximizes exhaust sound on cold start with extra burbles. All it really is, is unplugging the valve opener/closer it won't trigger any CEL or void anything and when you want just plug It back in. As far as intake is concerned that's a green light for sure they don't care too much but make sure you keep your original version of whatever you replace in case they are stingy about it. Ive done a JB+,permanent open valves, and a cold air intake and the car easily gained 45ish hp and 40 tq. These are the mods I did to my lease 330i to be on the safe side but as far as downpipe is concerned I wish I could do that but i don't want to yet. Your only exhaust option is possible an m sport one from bmw themselves and have them install it at your bmw dealership because its their product and they don't mind because it'll be on file that they approved it. Some Dinan products can also be installed at BMW. One extra mod you might want to do your car is getting lightweight wheels and tires because those Run Flats that they come equipped with seriously slow down the car when aiming for performance. Run Flats are heavy as f*ck compared to other tires. Hope this helps.
Royalte991.50 |
05-28-2020, 04:55 PM | #7 |
DYI Master
9
Rep 20
Yep, that helps. I'm more of a DYI person and I already targeted a couple of things.
First of all, I started with the looks, my car came with lots of chrome (car was already at the dealer so I didn't customize one from scratch). Apart from the black grille, which I hate, everywhere else I did a chrome delete and I wrapped the roof on black for a more sporty look. Also applied protective wrap on headlights for extra protection on roads while behind other cars. Installed a CS-style carbon fiber spoiler (best thing ever). I already went for some ultra-light wheels (9kg front and 9.5kg back on 19inch). I'll keep the tires for now until they wear out, then will go for Michelin PS4 RFT (I know run-flats are heavier than normal ones but still they are lighter than a full spare tire in the trunk). I also changed the air filter with a K&N one (noticed some very small changes on sound and behavior but nothing more. Further to do: - Flash tune as you already suggested - Ordered a carbon fiber front splitter and rear diffuser - Axle-back exhaust with 2 smaller mufflers that offer a louder noise and for piping, I want to do some titanium pipes and welding, the sound from titanium is way better than other materials (my opinion anyhow) - Intake resonator delete - Maybe some Eibach springs, but for later when my wallet is not screaming. Last, once every 2-3 months some performance fuel 4 times the price of normal one but totally worth it for how the car behaves with it. And that is about it for now. I didn't think it was possible to get 400hp out of this 2.0L without voiding the warranty anyway bot maybe get close to that you know.. |
05-29-2020, 05:18 PM | #8 |
Rep 42
I'm glad you've got started on personalizing the car ! I too had my alpine white g20 wrapped in black in the chrome door trim and the chrome grille as well as the white roof. Looks much more aggressive. The mods you listed are further than I would've ever gone simply because I don't want to get out of hang and force the car into 400 hp otherwise I would but I think I'm good sitting at around 280ish hp with the 320 tq keep us updated brother!
05-29-2020, 06:44 PM | #9 | |
Petrolhead
1943
Rep 3,521
Current:
05-30-2020, 12:17 AM | #10 | |
DYI Master
9
Rep 20
I'll keep you posted with the upcoming changes. I contacted yesterday IPE for their exhaust system because it sounds amazing, and if it turns out it is too expensive, I will build one just the way they designed theirs. Last edited by raptorEdko; 05-30-2020 at 12:18 AM.. Reason: typos |
05-30-2020, 12:21 AM | #11 | ||
Rep 42
Alpine white bmw w/black roof
VipinLJ1943.00 |
05-30-2020, 02:23 PM | #12 | |
Petrolhead
1943
Rep 3,521
I blacked out my reflectors using trim tape. If I could black out the rest of the chrome, that will complete the storm trooper look I’m aiming for.
Current:
05-30-2020, 02:46 PM | #13 | ||
Rep 42
VipinLJ1943.00 |
05-30-2020, 04:00 PM | #14 | |
Petrolhead
1943
Rep 3,521
And I wish I could do a DIY on the roof too but I’m not too sure. The degree of patience. Plus finding another person to help me do it. I’m hoping to find a shop a little further away that can do it for cheaper. I don’t mind spending up to $200 for the roof alone. But $500 and above is a no go. And I think the black and white look suits the sport line really well unless it’s an all black look which is better. Looks like you’ve only got the reflectors left? I’d also love to tint my taillights.
Current:
05-30-2020, 04:03 PM | #15 | ||
Rep 42
I think driving further is worth it brother definitely look into it. I'd love to see how yours looks after |
VipinLJ1943.00 |
07-07-2020, 06:18 PM | #16 | |
Rep 28
07-11-2020, 05:56 PM | #17 |
Rep 42
07-11-2020, 06:56 PM | #18 |
Rep 162
I emailed burger and they said that intake doesn't fit the G20 330i. they have one in development and should be out in a few months. you got youra to fit?
12-19-2020, 05:15 AM | #19 | |
Rep 42
Tags |
330i, exhaust, intake, lease, max, tune |
