Worth buying
05-28-2020, 07:01 AM | #1 |
Rep 29
Worth buying
Hi I'm in Canada and I'm looking at a 2007 E92 N54 it has 161k Km and here's a list of what has been done, just curious on if it's worth it.
Valve Cover Gasket Injectors and seals Front and back main seals Oil Pan Gasket WaterPump and Thermostat Boost solenoids LPF Sensors Crank Position Sensors Breaks front and back with sensors Bosch Coil packs Oil Filter Housing gasket Also hasn't been winter driven and comes with a list of different mods |
05-28-2020, 07:10 AM | #2 |
Rep 1,827
If you're not familiar with the model, get a pre purchase inspection. Also, if you haven't, see the buyers guide sticky post on this forum.
Other than the engine seals, everything looks like normal wear and tear. Oil pan gasket is a pretty big ticket item. How is the suspension? It at least looks like the car was cared for with those items listed. |
05-28-2020, 07:20 AM | #3 |
Rep 61
yep,
depending on the price |
Hunterrr16150.00 |
05-28-2020, 09:10 AM | #5 |
Rep 1,505
Thinking it's a bit steep on price but maintenance sounds like it has been kept up on.
05-28-2020, 09:34 AM | #6 |
Rep 1,100
05-28-2020, 10:00 AM | #7 |
Rep 29
05-28-2020, 12:10 PM | #9 |
Rep 776
A. Turbo wastegates likley rattle like crazy with those km. Get ready to replace those.
B. It looks like somebody threw a lot of money at this car, trying to track down a problem, and has decided to give up, and make it someone else's problem. C. At those km, everything on the car starts to go south, suspension, bushings, clutch or auto tranny. 07 has the msd80 DME, get ready to do mosfets Pulleys are old, motor mounts dying, valve cover cracks, it will be an endless maintenance battle. I've had 2 07, 335i, they are $5000 cars period. Unless you get one with under 100k km. That 150k-200k km range is the worst. Avoid, it will be a money pit, unless you only want to put 10k km a year on it. It absolutely will not be a reliable daily driver. Last edited by fredcase; 05-28-2020 at 12:25 PM.. |
05-28-2020, 12:10 PM | #10 |
Rep 1,343
Too much even for CDN funds. 2007 335i sedans are around $7500 asking with that kind of mileage over on the local craigslist. These things aren't moving. If you can talk him down to $5500 to $6000, that's probably ok. Do recognize N54 maintenance/repairs can easily exceed the cost of purchase.
Hunterrr16150.00 |
05-28-2020, 12:55 PM | #12 | |
Rep 600
Drives: TiAg e91, r53 Cooper S, e28 M5
If this will be your only car... Are you paying cash, do you have another 3-5K ready to dump into it at any time? If you are looking for a reliable DD or this would be your only car, just walk away, I'm totally serious. But if you are looking for a project and have a daily then really try to talk them down... that car, unless it is a unicorn is a 3-5k car all day long. Offer what it is worth and you could have a lot of fun for not much money. But know what you are getting into... if this is your first BMW or tuner car for that matter... there are probably better options. |
Hunterrr16150.00 |
05-28-2020, 12:59 PM | #13 | ||
Rep 29
05-28-2020, 01:13 PM | #14 | |
Rep 600
Do you have another car for when this isn't working... its kinda a joke (but it isn't) around here but you need a backup car if you own a N54 powered BMW. Are you looking to have a big power BMW or do you just want a BMW? If it's your first and you don't need 300+HP, an e90/2 6MT 328i can be had for not much money and is pretty rock-solid reliable, easy to work on, and fun to drive. It would be a way better "BMW learning experience" than an N54 car. just my .02 |
