Noise when depressing gas, is it a belt?
05-30-2020, 12:35 PM | #1 |
Rep 123
Noise: https://streamable.com/sfj9bj (might not be audible without headphones, sounds like birds in forest, but its my engine sadly )
It's most prominent when depressing gas, or when rolling downhill, but also often makes noise under acceleration. It's a little bit random, one day you can drive and not hear a thing, other day it will be loudest its ever been, tbh it seems like it's progressively getting louder. No noise when idling standstill. I'm thinking it's belt or pulley, any thoughts ? Last edited by deropke; 05-30-2020 at 12:46 PM.. |
05-30-2020, 08:31 PM | #2 |
Rep 1,024
How many miles are on the belt and pulleys?
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
05-30-2020, 09:08 PM | #3 |
Rep 947
Drives: e92 335i, f22 m235i, e30 325is
Completely off topic but how do you have an RHD/Euro model with an MPH cluster?
05-31-2020, 06:29 AM | #5 |
Rep 123
05-31-2020, 09:48 PM | #6 |
Rep 733
If those components have not been changed at that mileage, it needs to be done as soon as possible. The accessory belt coming off on a N54 or N52 (probably a few others too) is not a small deal. It can nuke the entire engine.
06-01-2020, 07:59 AM | #7 |
Rep 1,024
Agreed - the belt/tensioner/pulleys are likely overdue for replacement even if unrelated, so start there. You should also familiarize yourself with other recommended maintenance for higher mileage BMWs here: https://www.dslreports.com/r0/downlo...e%20v03.13.pdf
For the belt change, check out www.realoem.com for the applicable part numbers, www.newtis.info for the replacement procedure, and I recommend www.fcpeuro.com for the parts themselves.
JonOhh672.00 |
06-02-2020, 01:00 PM | #8 |
Rep 123
posting this incase someone in the future find this relative, I talked with mechanic and he said it's most likely manifold gasket, which expands when its hot and creates this noise
06-02-2020, 01:19 PM | #9 |
Rep 414
I don't see how this can be the case.. the intake manifold gaskets expanding wouldn't cause this rhythmic ticking sound from your video.
06-03-2020, 10:05 AM | #10 |
Rep 123
