BMW X5
      06-20-2020, 12:52 PM   #1
UltraDave
UltraDave's Avatar
127
Drives: 2020 BMW X5 M50i
Maxton Rear Diffuser Installed
I just added the Maxton Design rear diffuser. It looks good in conjunction with the front splitter. The car has more of a sporty appearance.
      06-21-2020, 02:09 AM   #2
Aaron9k
Drives: 2019 X5, 2019 GT3rs
That a nice setup! How hard was it to install the front lip and diffuser?
      06-21-2020, 09:17 AM   #3
UltraDave
UltraDave's Avatar
127
The rear was easy to install. The front on the other hand took a few hours because it’s difficult to find space to attach the fasteners.
Aaron9k14.50
      06-22-2020, 11:49 PM   #4
samvora
The Dark Knight
samvora's Avatar
Drives: E36, E46, E90, G05 and MB W205
The rear was easy to install. The front on the other hand took a few hours because it's difficult to find space to attach the fasteners.
So is it the actual entire diffuser or just a lip that attaches below the existing diffuser? Link to the product?
      06-22-2020, 11:54 PM   #5
UltraDave
UltraDave's Avatar
127
It’s just a lip. Similar in size to the front splitter.
https://maxtondesign.com/eng_m_Our-O...html?node=2360
      06-26-2020, 06:53 PM   #6
JonnyCrash
Driver
Drives: VW GTI, BMW X5 40i M-Sport
Dang those look good. I wonder what the stripe options look like though.
Do you think the rear diffuser lip would work with the tow package?
      10-03-2021, 09:03 AM   #7
silverstar335
silverstar335's Avatar
Drives: G05
I installed the Maxton rear splitter yesterday and it is not necessarily straight forward if you don't have instructions.
Providing some basic steps:
1) Remove the 3 heat shields in the rear
2) Use a Dremel to create 3 openings in the Maxton rear splitter which would allow you to get to the middle heat shields's screws. I think that's a mandatory step.
3) Drill 7-8 holes (7/32 drill bit) in the Maxton rear splitter and rear bumper and use the supplied hardware. Note: One or two longer bolts will be required depending on where you decide to drill the holes.
4) If drilling holes in the middle section of the rear bumper in order to hold the Maxton splitter in place, then cutting a small piece out of middle heat shield will be required.
I did not use 3M double sided tape.
      10-21-2021, 10:49 AM   #8
Adblue
Ireland
35
Drives: G05 X5 M50D
Does it interfere with the towbar? (mine can be retracted).
xbimmers
