FS: VOLK Racing LE37T 19" Wheels
04-12-2006, 04:11 PM | #1 |
Rep 20
Hi guys, I have a set of brand new 19" Volk Racing LE37T Euro Silver wheels for sale in BMW fitments. The front wheels are 19x8.5 et 43 and the rear wheels are 19x9.5 et 45. The price is $2400 plus shipping. PM me if you're interested, thanks. |
04-12-2006, 04:17 PM | #2 |
MAUI BUILT
486
Rep 7,781
Drives: 2006 330i MT
You might try posting on e46fanatics.com, as those are e46 fitments & not e90.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
04-12-2006, 04:31 PM | #3 |
Rep 20
Sorry, forgot to mention that these will be a great fit for the E90 with a 15mm hubcentric spacer in the rear, making the effective offset an ideal +30. Thanks.
04-12-2006, 04:35 PM | #4 | |
MAUI BUILT
486
Rep 7,781
You would still need at least a 10mm or more spacer in front, cuz +43 is more tucked than stock. Spacers on the front are not good IMO. These are best for the e46, but hey, if anyone with an e90 wants them, go for it. Check HERE for a similair add with lots of hits at e46 Danny
04-12-2006, 04:53 PM | #5 |
Rep 20
Hi Danny, sorry but I'm going to have to disagree with you on that one. The front wheels on this set are 8.5" +43, so if you do the calculations, they do not need a spacer for the front. The stock type 179 or 199 18" sport wheels are both 8" wheels and have an offset of +37, so it is the same exact offset in relation to the front fender as the 8.5" wheel because of the extra width. Thanks for the input though.
04-12-2006, 05:05 PM | #6 | |
MAUI BUILT
486
Rep 7,781
Front: Either 17" or 18" by 8.0 with +34 Rear: Either 17" or 18" by 8.5 with +37 Your Volks Front 19" by 8.5 with +43 Your Volks Rear 19" by 9.5 with +45 If I put your E46 rims on my car, without spacers, the following will happen: Front: 15mm LESS clearance on the strut side, and the outside edge of the wheel will RETRACT 3mm Rear: 21mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 5mm And that's if the e90 has the zsp package, if not, even more of a "tuck". You can sell them to whoever, but I know what I'm talking about, just trying to help you. Check out e46fanatics, they use that, the e90 uses more of a M3 offset. Danny
Last edited by HRC; 04-12-2006 at 05:09 PM.. Reason: Correct OEM sizes from 18 and 19 to 17 and 18" |
04-12-2006, 05:19 PM | #7 |
Rep 20
So Danny, just to make it clear on this, are you saying that at least a 10mm spacer will be required for the front because it won't clear the strut side- or to clear the 3mm difference in relation to the front fender?
04-12-2006, 05:35 PM | #8 | |
MAUI BUILT
486
Rep 7,781
I and others here have been waiting a WHILE for the LE37T in e90 offsets. We could've went with your setup, no waiting, they were in stock last December. Danny
04-12-2006, 05:47 PM | #9 |
Rep 20
Ok, got it thanks. So the conclusion is that these wheels will fit the E90 with a 15mm spacer in the rear. The fronts are almost the same offset as the E46 M3's optional OEM 19" wheels. I know the wheel wells on the E90 are not nearly as big as the M3's, which bulge out. The M3's 19s are 8.5" +41, and these Volks are 8.5" +43. So it's a 2mm difference from the M3 offsets that are commonly used on the E90.
Therefore, at the end of the day, if you don't mind a 2-3mm difference (which I doubt will even be noticeable) I have a set of brand new Volk wheels for anyone who doesn't want to wait 3-4 months for a special order. |
04-12-2006, 05:58 PM | #10 |
MAUI BUILT
486
Rep 7,781
Just for reference, here is a e90 with stock M3 rims. No spacer in front.
Danny
04-12-2006, 06:10 PM | #11 |
Rep 20
Danny, those are stock 18s. My previous post was about stock M3 19s. The stock M3 18s have a +47 offset and they are only 8 inches wide. These Volks will extend an EXTRA 10mm beyond the stock 18" E46 M3 wheels.
(Plus, the front wheel is turned in that picture so it's irrelevant anyway...) |
04-12-2006, 06:16 PM | #12 | |
MAUI BUILT
486
Rep 7,781
Danny
04-12-2006, 06:35 PM | #15 |
MAUI BUILT
486
Rep 7,781
This is how a front 8.5 inch wide +30 offset that most m3's use looks like. This is also the same front fitment for the e90. "Wheeler" already has this +30 front on his car with a +45 and a 15mm spacer in ther rear.
Danny
04-12-2006, 06:48 PM | #16 |
Rep 20
I just looked at Wheeler's pics and I think it looks good, however it would have looked even better if he had gotten a matching set- instead of M3 fronts and E46 rears. It looks like his set has a very concave face in the front and a much flatter face in the rear. It should be the opposite. The front face should have less concavity than the rear, as it is in the standard M3 and E46 sets.
04-12-2006, 07:12 PM | #17 | |
MAUI BUILT
486
Rep 7,781
Here is another BMW with e90(m3) fronts and e46 rears... Yike! Danny
04-12-2006, 07:29 PM | #18 |
Rep 20
Wow, that looks horrendous. The rears look perfect but the fronts are a disaster. So I guess the moral of the story is, running spacers or not: If you want Volks, you should get a matching set!
04-12-2006, 08:17 PM | #20 | |
MAUI BUILT
486
Rep 7,781
Danny
