N52 rough idle, what could it be?
07-07-2020, 11:34 PM | #1 |
Hola
70
Rep 407
Hello everyone, on my daily, an e60 528i (N52), i started getting a rough idle along with a check engine light showing up. The CEL randomly turns on and off when the car sits and idles, but the rough idle stays fairly consistent. The idle while rough usually stays between 600-700 rpm, once the car is warmed up. The car drives fines, doesn't seem low on power, but i don't beat on it as its just a daily.
I pulled the codes with the Carly scanner and got: 002D06: Air Mass System 0029E0: Mixture Control 0029E1: Mixture Control 2 I was initially thinking of replacing the MAF sensor, but I'm not 100% sure, could it be a vacuum leak? Has anyone dealt with this before? |
07-08-2020, 02:00 PM | #2 |
Rep 2
Im having the same issue, but my problems started after I had a mechanic change my valve cover.. began running very rough and the mechanic claims it’s a bad ccv valve but my car shows no symptoms of it (no loud whistling sound, no strong suction from oil cap)
I cleaned the maf sensor that helped with the rough idling but the codes were still there, also changed spark plugs I’m also assuming it could be either the vcg or valvetronic gasket weren’t set problem causing a vacuum leak I noticed on the valvetronic gasket, he set it upside down it was also missing 3 fastners smh Did your problems just start out of no where or were you making a repair? |
The Maxican70.00 |
07-09-2020, 06:37 PM | #3 |
Rep 2,025
Drives: 2008 E92 328xi
Is your adapter able to show live data? Hope it is. You're gonna want to check what your short term fuel trims are at when the car is idling rough. Anything over 7 or under -7 is an issue to me.
Also you two could try unplugging the maf sensor when it's doing that and see if it changes anything or maybe swap it with a known working used one. If the fuel trims are all over the place you might wanna do a smoke test to isolate the problem. |
The Maxican70.00 |
07-11-2020, 03:17 PM | #4 | ||
Hola
70
Rep 407
07-19-2020, 01:59 AM | #6 |
@Lucky.330i
39
Rep 91
Drives: 2006 BMW 330i
Its more likely a vacuum leak than a MAF problem but it is possible. Unplugging the MAF allows it to ignore the vacuum leak but its worth taking an overall look at your intake boot, valve cover gasket, pcv, and vacuum lines.
