07-14-2020, 10:33 PM | #1 |
Rep 18
New rotors and brake pads
When pressing the break my car has been shaking pretty dramatically. I'm looking to get new rotors and brake pads for my 2014 bmw 335i xdrive. Ik the front calipers are larger then the rear. Just looking for any advice on what rotors and pads I should get and sizing.
07-15-2020, 09:19 AM | #3 | |
Rep 5,399
Front 340mm X 30mm rotors Rear 330mm X 20mm rotors If you have Blue 335i M Sport Brakes, then: Front 370x30 Rear 345x24 These street pads are Hawk 5.0. Great bite, instant warm up and light dust that washes right off. Made in USA. See photo for part numbers. Pads are the most critical brake component. Don't fall for some package of pretty rotors with crap pads thrown in. The best rotors will perform like crap with crap pads. I have rotor recommendations too, but I'm more concerned about the brake symptom that you are experiencing. You don't mention a dash light indicating pad wear. It sounds like you may have a missing clip, pin, broken pad, etc- something is physically wrong. It's not just normal rotor or pad wear. Is it front or rear? Left or right? Take the wheel off and look. Or take it to a local independent BMW mechanic to find out what's making the noise. It should be obvious to them with a visual inspection. If you don't have one, then check BimmerShops website. Don't let them just replace pads or rotors with whatever garden variety OEM part or even BMW part that they use. You will miss the opportunity to upgrade your brakes with better aftermarket parts. My Indy charges $100/wheel when I bring him my own brake parts including fluid replacement which should be done every two years for safety. Let me know which brakes you have, grey or blue, and I can provide rotor recommendations and part numbers. Hope this helps! |
Sad N2621.00 |
07-15-2020, 09:24 AM | #4 | ||
Rep 18
johnung4537.00 |
07-15-2020, 04:58 PM | #5 | |||
Rep 5,399
Front 340x30 Part# 150.2903.32 Rear 330x20 Part# 150.2904.20 |
07-21-2020, 02:14 PM | #6 |
Rep 741
this is from tire rack
REAR Material: Composite Manufacturer Part #: HB766B.624 Note: Rear brake pads. M Sport brakes. 370mm front discs. REAR Material: Composite Manufacturer Part #: HB825B.649 Note: Rear brake pads. Base and M Sport brakes. 340mm front discs. FRONT Material: Composite Manufacturer Part #: HB765B.664 Note: Front brake pads. Base and M Sport brakes. |
