07-19-2020, 12:02 AM | #1 |
Rep 281
Drives: 2016 EB 340i
I have fixed about 90% of my clunks and rattle after retorqueing the whole suspension. I occasionally get a clunk in the rear and some in the front.
First, has anyone tighten up their steering rack that has then solved some other clunks up front? (Bought a tool to do this) See video one: Second, under +40% throttle I hear this constant grinding noise coming from the rear passenger side wheel. Does not happen when cursing normally or braking. No clue what it is but someone said it could be a parking brake clip. See video two: |
07-20-2020, 01:23 AM | #3 | |
Rep 281
Strut Clamp Knuckle = 41.5 ft. lbs. Shock Damper = 47 ft lbs. Shock Tower Bolt: 5-Bolt = 22 ft. lbs. Shock Tower Strut Brace = 41.5 ft. lbs. Camber Arm = 122 ft. lbs. Shock Bolt = 75 ft. lbs. Upper Shock Mount = 20.65 ft. lbs. |
G80S58135.00 |
07-24-2020, 11:23 AM | #4 | |
Rep 354
Originally zip tied the e-brake line and it stopped for a while until the zip tie broke. Thread: Weird Rattle Noise Coming From Undercarriage https://f30.bimmerpost.com/forums/sh....php?t=1628225 |
07-24-2020, 12:22 PM | #5 | ||
Rep 281
07-24-2020, 12:31 PM | #6 | |||
Rep 354
Wouldn't count on it holding up for long. Its a good quick fix for sure! |
07-24-2020, 01:08 PM | #7 | ||||
Rep 281
07-24-2020, 01:40 PM | #8 | |||||
Rep 354
Aldor2788.00 |
