08-04-2020, 06:41 AM | #1 |
Rep 149
Dealer unable to connect to iDrive ECU (Hu Headunit?)
I have my '17 M2 LCI (warranty for another month) in at the dealer for a rear indicator failure and asked them to check the iDrive system as it would freeze occasionally, especially when switching from Nav to Media after driving for about 15-20 minutes or so. As part of the diagnosis, I had to underwrite a cost of £170/hr (min 1 hour) for diagnostic time, if it was found to be a user issue.
I just received a call from the service advisor (SA) saying the tech is unable to communicate with the iDrive ECU and they suspect a blackbox or an after market part has been fitted that could cause this (previous owners kept the car stock, and it was AFAIK). There's two options, I either let me continue the diagnosis and foot up to 3 hrs worth of diagnostic time (labour charges?) and if then they seem the unit is faulty, warranty covers it and if not, I foot the bill or I cough up the 1hr already spent and call it a day (leaning towards this). Their diagnostic machine was used previously, so that is working fine. I have used Bimmercode to make changes to iDrive, like get rid of the start up warning etc previously, but haven't mentioned this to the SA. Would the diagnostic computer be connecting to the same ECU as bimmercode or would it be a different one? Due to the current COVID situation, they won't let me speak to the service tech. I'm picking the car up tomorrow, so hoping to try my luck at speaking to the tech! If nothing further works out, can I use ISTA+ to update the iDrive etc. myself? The car is under warranty for another month, and I'm not a 100% yet if I want to extend it further. |
08-04-2020, 09:27 AM | #2 |
Rep 1,337
Can they read any of the other ecu's in the car? I would suspect if there is a aftermarket module on the canbus then they wouldn't be able to read any ecu. Not just isolated to the iDrive
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
08-04-2020, 09:32 AM | #3 |
Rep 149
That's my argument as well! I'm hoping to dispute this tomorrow with them. I imagine they were able to read other ones because they validated the faulty rear light cluster for the indicators via a stored fault. I also had no issues with Bimmercode connecting, so I'll see if the tech is game to try it again
08-06-2020, 01:41 AM | #4 |
Luxury at the redline :)
9108
Rep 7,563
The previous owner probably installed an ASD bypass harness, I've heard about this before..
https://www.bimmerpost.com/forums/sh...php?p=26518066 |
08-06-2020, 02:23 AM | #5 | |
Rep 7,478
If you have ISTA I would recommend doing a scan of your car to see if you can connect, and potentially show any errors. Next I do not recommend you flash or update the car at home without being extremely familiar with coding, flashing and the involved softwares otherwise you can completely brick your car. The next thing you need to note is that if you flash you need a power supply, not any old generic one, but a microprocessor controlled power supply that can monitor voltage and charging current to your car and modulate how much power it outputs. Those things tend to run in the $1k range, or you can diy a server power supply which can do the same job. The last thing you need to note is that you can flash with ISTA but it probably is better to do it via ESYS instead, it is a lighter software and easier to run on your laptop. But you need to address any connectivity issues before even attempting to flash.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
08-06-2020, 03:26 AM | #6 |
Rep 149
Thank ya'll for the reply!
I don't think the previous owner had an ASD bypass harness as I disabled ASD via Bimmercode and noticed a difference in cabin noise in regards to exhaust when driving on the freeway and burbles in general. However, I'll double check this today. In terms of mods: - Used Bimmercode to code out a few things, like ASD, auto start stop disabled by default, start up warning on iDrive, B&O sound settings and after picking up the car yesterday, coded out the camera warning when putting the car in reverse, so Bimmercode is definitely connecting to the HU_NBT unit. - Instrument cluster speed emulator: this uses gps data to display speed on the instrument cluster. This is the only thing I can think of that is remotely connected to the HU in any way, although, it is read-only and installed on the instrument cluster. I'll be removing this and checking. - Braided brake lines. I downloaded ISTA on a laptop, so I'll try to connect it to the car today to see if I can connect to the modules. Reading more in to this, I won't be updating the car because of the need of a proper Aux power and the investment it'll need. If I can't see the module, I'll remove the speed display emulator and try after that. |
08-06-2020, 03:27 AM | #7 | |
Rep 1,337
08-06-2020, 03:34 AM | #8 | |
Rep 7,478
If not - to avoid a dealer fee, try scanning the car with ISTA with the coding still on the car, and with the coding removed.
08-06-2020, 03:44 AM | #9 |
Rep 149
No, I left the car as is, because AFAIK, Bimmercode changes are temp and get overwritten if the module is updated. I lose my favourites everytime I update HU_NBT via Bimmercode.
That's exactly what I want to do, start as is for a baseline and work backwards to see where I gain connectivity by coding out/return to normal on different modules. FWIW, I also changed the hard stop flashing of the rear lights and the velocity they activate at and this didn't stop the dealer reading codes out for a faulty rear right light cluster and they replaced it under warranty. |
08-06-2020, 03:50 AM | #10 | |
Rep 7,478
But I would always recommend coding back to stock before going to the dealer. Otherwise I am not sure why your car is not connecting properly. Do you have any after market sound systems, usb devices, aftermarket fsc codes (life time map upgrades, apple car play etc), or tuning devices that interact with the obd2 port of canbus?
08-06-2020, 05:03 AM | #11 |
Rep 149
Edit: there's nothing after market installed on the car at all! What perplexes me is I can connect to the modules via Bimmercode without any issues.
So, I tried connecting IFTA+ to the car and can see the VIN number and the vehicle (albeit the colour is wrong :|), but when I click to connect to the vehicle, I get an error saying 'Vehicle could not be identified. Please check the access to the vehicle and check whether the testing-analysis-doagnosis has been activated." I'm trying to read up more on the error. Not sure if the copy of IFTA I have is incorrect :S. I downloaded it from here View post on imgur.com View post on imgur.com |
08-06-2020, 05:28 AM | #13 | |
Rep 7,478
I got my copy of ISTA+ from shawnsheridan with the full PSZDATA files. If you code it back to stock and it still does not work, then try ESYS to see if that can connect and make changes. Because I'm thinking you might need to reflash the car with a new ISTEP, but before then you could try doing a restoration by using the "code" feature on the top node of the svt ecu tree and reset the whole car back to stock. You will need a battery charger for this.
08-06-2020, 05:52 AM | #14 | |
Rep 149
I found a newer version of ISTA, from April-May this year that I'm downloading to try. The freezing on the iDrive isn't a huge deal, so I'm contemplating just leaving the flashing side of things alone. The car's running fine as well, so there's no need as such. It's just the 'why isn't it working and let me see if I can get it work' part of the brain that's making me tinker more + FOMO of the newer ISTEP that has a better steering feel etc. |
08-06-2020, 05:56 AM | #15 | |
Rep 7,478
IMO I would try to get this sorted out while still under warranty, especially since I have seen frozen and laggy head units replaced in the past, and trust me those things are so expensive I would not want to foot the bill myself. If you do reflash a new ISTEP you can always code steering response in the EPS module to something you like. For me I also have a 2017 m2 with the newest ISTEP and I have coded f87cs steering which imo feels amazing. It is alot lighter than stock but has incredible feel and none of the dead spot in the middle or center seeking pull of stock or f87gts which is too artificially heavy imo. Anyways that is besides the point, but my advice is to try and fix this issue while you still have warranty.
08-06-2020, 06:11 AM | #16 | |
Rep 149
My only hesitation is the dealership is asking to me write off ~£600, in case they physically access the DME and the find a user issue. They've already charged £140 for diagnosis since they couldn't connect to the HU ECU (this became a customer fault, until I prove the car hasn't been tampered with, but I need to pay for them to check it out). The chances of something coming up user related is very low and if it's a faulty DME, they'll cover it under warranty. It's just the small chance of coughing up another £600 is putting me off and the whole experience with the dealership has left a sour taste. The SA says they need these costs to be approved by the customer prior to works commencing, which I understand, but the tech who worked on the car just refused to talk to me yesterday. The response from the tech was 'send us an email, so everything is in writing' and this was conveyed to me by another person. Had a similar thing back home in Australia, but the techs were super nice and just hooked up the car and came back and said we can't update XYZ due to after market stuff, but feel free to remove it and we can update it. This was during a service though. |
08-06-2020, 06:31 AM | #17 | |
Rep 7,478
What I suggested was if esys can still connect and interact with your car you can use it to code the car back to stock. But make sure you know what you're doing so you don't use code default which wipes the car to a blank slate and completely bricks it. You will also need a launcher to fdl code, but it's not necessary to code back to stock which is what I think you should try. Please make sure you're familiar with this software before doing anything. Yeah it sucks that you'd had to pay. Ok my advice would be to get ista working for you, because if it's working for you it will work for them, and whether you choose to have the I drive display fixed is up to you. But you should get the interface working while under warranty just incase.
08-06-2020, 06:40 AM | #18 | |
Rep 149
Lastly, if in future, I decide to go down ESYS route to restore/make changes myself, would I still need the 70A Aux PSU or would a normal battery charger be fine? For ISTA, I understand I'll need a proper PSU and considering the pricing for them, it's not worth the investment for me since I'll be moving back to Australia in another year or 2! |
08-06-2020, 10:26 AM | #19 |
Rep 149
Got ISTA working! i installed a new version from here. This has everything and there's no faffing about with unblock reg files etc. and worked like a charm, first try.
The car connected fine and I could connect to the different ECUs, including HU-H. The only errors present were ASD, which has been coded out via Bimmercode & something on the Kombi because of the speed limit info emulator (this is a non existent code). My dilema now is do I share this info with the dealer and the tech, saying I can connect to the DME via ISTA+ without any issues and share the photos? Since they'll have this in writing, I don't want them or BMW to come and use it against me! View post on imgur.com View post on imgur.com View post on imgur.com |
MR RIZK757.50 |
08-06-2020, 10:31 AM | #20 |
Rep 1,337
You can always get them to retest and see where it lands. When they say still doesn't work whip out the laptop and prove that it does.
I don't think you have much choice and it's not like you are changing anything. Just proving the connection works.
