08-15-2020, 09:03 PM | #1 |
Rep 100
LCA to wheel bearing carrier bolt not threading through!!!
Hi guys, currently installing H&R springs on my 435i xDrive. Started with the rear and the left side went fine. I moved onto the right side and took off the spring and put the new spring in. I put in the shock absorber bolt that connects to the LCA, went in fine. I tried lining up the wheel bearing carrier to the LCA and it did not line up, after 2 days of trying to line this up with the bushing that is between both sides...
When I was trying to jack up the LCA to get the holes to line up, I noticed that the front side of the LCA was actually hitting the bushing and sort of bending it upwards, so I preceded with caution. However, it never lined up after that. I am assuming that when I jacked up the LCA and it got stuck on the bushing it did bend it or somehow damage it. After two days of this project I put the bolt through the LCA without the wheel bearing carrier and it seemed straight, I also did this with the bushing and it went through as well. So I am ruling out that the bolt is bent. For reference: #1: the left side went fine and is finished #2: the shock absorber to LCA bolt lines up perfectly fine and after I had put the new spring in on the right the only thing that did not line up was the LCA to wheel bearing carrier If theres any techs or anyone that knows what I can do to fix this, I'd appreciate any advice. I am looking at replacing the bushing, on FCP euro it's $20 (part # 33326792553). However if the wheel bearing carrier assembly is damaged I would be out around $600. I currently cannot just take this to a shop because without the suspension all buttoned up you can't drive. Should I ask a shop to come to my house and figure this out? Here are some pictures: |
08-15-2020, 11:21 PM | #2 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
1) Put some alignment/witness marks on your lower camber arm eccentric washer/subframe. This is where the lower camber arm connects to the subframe. A paint pen or whiteout pen works well for this.
2) Loosen the lower camber arm eccentric nut/bolt. 3) You should be able to align the ball joint in the wheel carrier and lower camber arm holes. Connect them and torque to spec. 4) Jack up the wheel carrier to the normal position (where it sits at normal ride height). 5) Align lower camber arm eccentric bolt/washer with your previous witness marks and tighten to spec.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
08-16-2020, 10:36 AM | #3 |
Rep 272
It looks close. I usually have luck shifting alignment around with a thick flathead screw driver on the other side. Might have more play if the shock bolt is loose and endlink is off
08-16-2020, 11:05 AM | #4 |
Rep 100
Yes I did that and the other side would then shift and the LCA would block the bolt. I tried threading it through on both sides and it just wouldnt line up.
08-16-2020, 11:20 AM | #5 | |
Rep 100
08-16-2020, 01:46 PM | #6 | ||
Rep 124
mgc999115.00 |
08-16-2020, 06:46 PM | #8 | |||
Rep 100
08-18-2020, 11:18 PM | #9 | ||||
Rep 116
08-19-2020, 05:50 PM | #11 | |
Rep 100
08-19-2020, 06:35 PM | #12 |
Rep 3,540
When dropping the car on H&Rs and not shortening the bump stops proportionally? Absolutely. You're probably already riding on the bump stops at static height.
08-19-2020, 07:06 PM | #13 |
Rep 100
Shihhh, I read a while back on one of the threads that they were not needed for aftermarket springs. Is it something I should've upgraded as well or do I just have to go much slower over rough road? The specific place I bottomed out twice was a construction patch filled with a little gravel so I'm not too worried but at high speeds on the highway that might be some place for caution.
08-19-2020, 08:05 PM | #14 | ||||
Rep 3,540
mgc999115.00 |
08-20-2020, 11:22 PM | #15 |
Rep 100
FaRKle! Ig I should've done more research before doing this idk. Too late at this point I spent $230 on alignment at BMW lol, not gonna waste time either taking off that stubborn suspension. But I also guess it is a good way to get me to slow down lmao. Thanks for your help tho
08-21-2020, 12:40 AM | #16 | |
Rep 3,540
Changing just the bump stops is pretty easy since for the front you can just unbolt the strut from the top mount with the car on the ground, and then when you raise the car the knuckle/strut assembly should drop down out of it enough to pull the bump stop out. For the rear you just need to take the damper out, so no unbolting the lower camber arm from the wheel carrier or subframe.
