08-17-2020, 05:55 AM | #1 |
Rep 7
Vibrations! Help
Hello guys,
I have a problem with my 435i, I'm getting vibrations after 120Km/h (75 mp/h)... I can feel the vibrations only when I step on the gas pedal, harder I press it harder I can feel the vibrations, however, once the car goes above 4800-5000 RPM the vibrations are almost gone. If I release the throttle the vibrations are gone! Thanks! |
08-17-2020, 03:42 PM | #2 |
Rep 320
could be the guibo...some of the older f30 have these metal guibos with rubber bushings. after a while those bushings can start to move.
could also be your support bearing...have you had work done recently or is this something that is getting progressively worse as you drive? |
