08-19-2020, 02:48 PM | #1 |
Rep 1,121
Drives: 2015 BMW 435i Xdrive MSport
Yellow M Performance Brake Kit
So,
I managed to secure one of the last yellow m performance brake kits in the U.S. and my dealer is holding it for when I come in for the install in September. Here's what they'll look like after install. Thoughts[IMG]undefined[/IMG]?!
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
08-19-2020, 06:11 PM | #2 |
Rep 1,934
Dealer? You paid way too much money lol. But for the color I suppose it evens out so what
Used calipers - ~$1K USD 4 Rotors - ~$500 USD Zimmerman 2 piece Powder coat yellow - $2-400 USD Install - (diy $0 - $3-500 indie) Estimate $1700 - 2500 ____________ Dealer parts ~$2400 USD Dealer labor?????? Estimate ~$2400 just for parts.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
08-19-2020, 09:25 PM | #3 |
Rep 150
They are discontinuing the M Performance brake kits?
08-19-2020, 10:54 PM | #4 |
Rep 421
I could imagine that they aren't making anymore since the the F3x platform is almost EOL with the F33 I believe still being made present day so makes sense that inventory would be running low but I'd imagine most don't normally spring for the m perf brakes.
Curious to see if / when they do run lower on stock if they'd do a sale on them similar to the 335/435i LSD sale a while back. I wouldn't mind picking up another set of orange calipers before they're gone. |
08-20-2020, 05:41 AM | #6 | |
Rep 1,121
08-20-2020, 05:42 AM | #7 | |
Rep 1,121
Stlblues68.50 |
08-20-2020, 06:35 AM | #8 | ||
Rep 1,934
johnung4537.00 |
08-20-2020, 08:32 AM | #9 | |
Rep 1,121
08-20-2020, 08:33 AM | #10 | ||
Rep 1,934
08-20-2020, 08:37 AM | #11 | |
Rep 1,121
08-20-2020, 08:40 AM | #12 |
Rep 1,934
Just make sure they aren't charging you individual hours for the coding. You'd be paying for something you already have. If it's time charged in parallel for mounting the kit then you are fine.
08-20-2020, 08:43 AM | #13 | |
Rep 1,121
https://f30.bimmerpost.com/forums/sh...+Brakes+coding
09-28-2020, 02:20 AM | #14 |
Great Teacher
1124
Rep 1,314
Drives: 06 e91 325ix
The coding is for the bias on the rear brakes.
I went 312/300 to 340/330 and didn’t need it, and got enough (95+%) of the Possible improvement that the tires are Absolutely the limiting factor now. OP, they are brakes, nothing wrong with yellow or new. Your car and not everyone has the same comfort level on DIY and used parts. If you have 312/300 upgrade For safety, if you have 340/330 it’s really for looks. I’m super happy with used Calipers and Drilled and slotted rotors for under 1k whilst painting my own. Don’t need the 370/345 for performance nor looks, got that already. Mine are purple in the sun and black violet in the shade. Really happy with them.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
09-28-2020, 09:17 AM | #15 | |
Rep 1,121
09-28-2020, 08:26 PM | #16 | ||
Rep 127
The 4-piston fronts have 4x40mm pistons (equivalent area to a single 80mm piston). The 2-piston rears have 2x44mm pistons (equivalent area to a single 62mm piston). I upgraded from 312/300 to 370/345. The cost was only a bit more than to go to 340/330, and the labor was the same ($0 + coding). Also, the pad replacement in the dual/quad piston caliper is much easier than with the 1-piston caliper. |
09-28-2020, 08:29 PM | #17 | |||
Rep 1,934
09-29-2020, 12:02 AM | #18 | |
Great Teacher
1124
Rep 1,314
I wouldn’t say easier, jsut different. I can change single pistons in about 2 minutes tops once the wheel is off, if that, bc it’s easier to retract pistons with a big c clamp and unscrew the two Allen’s than to spread multiple pistons with a special tool and pull pins then fit them again. Neither is hard but the single pistons are much easier. My wife can change single pistons in about 4 minutes herself. Brembos... not a chance.
09-30-2020, 02:38 PM | #19 | |
Rep 127
I did the work myself. Not really a "deal", but it makes sure I understand the system better.
FYI, all pistons in a caliper can be compressed at the same time by spreading the pads. The "special tool" is actually quite common and fairly inexpensive. A set of pin punches helps to pull the pins. |
09-30-2020, 03:09 PM | #20 | ||
Rep 5,399
Rather than explain that some cars will not need coding because they have that same brake bias code that came stock, the instructions just have an instruction to code all new kits during installation. The front Brembo 4-piston calipers come in two sizes that fit over either 340mm x 30mm rotors or over 370mm x 30mm. Those calipers have the same pistons, seals, dust caps, pins and clips. They even take the exact same front brake pads. But they are NOT interchangeable. Their castings are difficult. The casting of the 370mm caliper is stretched out by an additional 15mm to fit over a 370mm rotor rather than a 340mm rotor. See photo. The 340 Caliper has raised lettering on the back of the casting that says "340". The 370 caliper says "370/380". |
pdxdbo331.00 |
