BMW M3 and M4 - The Icons
G80 BMW M3 and M4 General Topics G80 M3 /G82 M4 versus...
      09-23-2020, 06:18 AM   #1
b1gtuna
Drives: 2020 330xi
The M3 is only 0.2 seconds quicker to 60 mi/h than the M340i?
Sorry not trying to start anything. I’m just eyeing on an M3 after finding my G20 330xi lacking punch. 0 - 60 mph (0 to 100 km/h) isn’t everything in a car, but I kind of expected a bit more from M3 (like, sub 4 seconds). What do you all think?
      09-23-2020, 06:32 AM   #2
vampire81
vampire81's Avatar
Drives: '19 M2C / '19 ZL1
i believe BMW is under estimating 0-60 times.
X3M is evidence
spun out '
      09-23-2020, 06:34 AM   #3
spool twice
Rainbow Racer
spool twice's Avatar
Drives: BMW M4cs
2019 M4cs  [0.00]
0-60 is a function of grip, look at overall quarter mile MPH, that will tell you the full power range of available power throughout the powerband.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ]
Current Car: F82 M4cs | TT-RS | On Order: i4 M50
      09-23-2020, 07:50 AM   #4
heavyD^2
heavyD^2's Avatar
Drives: X3M Competition
I think you should wait for the magazines to get a hold of production models and perform their own testing. I have yet to see a BMW not outperform their claimed performance times which are highly conservative much like their claimed HP/TQ numbers.
Avaley735.00
      09-23-2020, 07:54 AM   #5
mkoesel
Moderator
Drives: No BMW for now
I think we should wait until the AWD M3 is released to make more meaningful comparisons.
SYT_Shadow11501.50
Ibiza3636.50
      09-23-2020, 08:08 AM   #6
HeynowbababooeyAckAck
Drives: M5 & X5
I don’t get it. 4.1-4.2 for standard M3 and 3.8 for Comp. Those are the same numbers as the previous generation M3. What gives? Increased HP, new car must be significantly heavier?
      09-23-2020, 08:14 AM   #7
mkoesel
Moderator
Yep, you answered your own question: power/weight.
      09-23-2020, 08:14 AM   #8
RPM33
Drives: 2020 M2 CS
Yes new car is bigger, more length and weighs about 300 pounds more.
      09-23-2020, 08:28 AM   #9
bm323
Drives: 12.2 E92 M3 ZCP; 12.7 C63
Many are giving the reason or excuse that BMW is underquoting G80 M3's 0 to 60. As at present, then compare BMW's official quote 0 to 60 for M3 vs M340i, m340I Xdrive ... what are they?
2013 F10 M5 FG, 12.7 E92 M3 ZCP sold
      09-23-2020, 08:39 AM   #10
danniexi
danniexi's Avatar
Drives: 2022 F97 X3M Comp LCI
0-60 is a function of grip.
I'm more interested in 1/4 mile trap speeds.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE
BMW MY08 E92 335XI - GONE
BMW MY06 E46 325XI - GONE
Transfer5260.00
      09-23-2020, 08:53 AM   #11
bmrm396
Drives: 2018 F80 M3cs
Ya about 500lbs heavier, no idea wtf is goin on over there nowadays
Formerly addicted to e46fanatics
Formerly addicted to e90post
      09-23-2020, 09:01 AM   #12
mkoesel
Moderator
Originally Posted by bmrm396 View Post
Ya about 500lbs heavier.
It's definitely heavier, but the real increase is nowhere near 500 lb. F80 Competition models were over 3600 lb. so the actual difference is about 200 lb. Still it is a significant increase, no doubt.
SYT_Shadow11501.50
bwoodahl235.00
xlover2198.50
      09-23-2020, 09:02 AM   #13
bm323
Ya, yes I'm much more interested in steering feel, but pls note what this thread is about.
And yes, grip is an impt factor, and not sole determinant.
      09-23-2020, 09:03 AM   #14
bmrm396
Oh, I saw some numbers in another thread that totaled that but maybe they were hypothesizing at the awd version
      09-23-2020, 09:04 AM   #15
heavyD^2
heavyD^2's Avatar
It would defy physics for the M3/M4 with auto and AWD to be slower in a straight line than the X3M Comp using the same engine and transmission given the X3M Comp is considerably heavier and less aerodynamic. I would expect sub-3.5 sec 0-60 and 11.5 sec @ 120 mph 1/4 mile from a ZF8 equipped AWD M3/M4 based on the numbers C&D got out of the X3M Comp. I imagine manual transmission RWD models will not likely be quite as quick in a straight line.
EXE462101.50
      09-23-2020, 09:17 AM   #16
xlover
Drives: 2023 X7 40i
Probably worth adding the rear tires didn't get any wider/stickier so the there are still going to be similar traction limits.
And the base M3 still has the same torque rating as the previous gen which matters a lot more off the line
Add that onto the 200lb gain and you end up balancing out the increased horsepower for the base models
FYI for whomever was looking for it bmw rates the M340 rwd at 4.4 0-60
      09-23-2020, 09:26 AM   #17
mkoesel
Moderator
Thanks for posting that.
I had the delayed release of the RWD M440i stuck in my head and totally forgot the RWD M340i has, of course, been available for some time.
      09-23-2020, 01:19 PM   #18
Wills2
Barge driver
Wills2's Avatar
Drives: 730d
Traction (or a lack of) and increases in weight (quite a bit of weight) means the power to weight ratios are similar despite the power hike.
So you have a traction limited drive train and no meaningful increase in the power to weight ratio, so the numbers will look the same/similar.
You need AWD to get real improvements in the 0-60 when cars are this powerful.
730d/Z4C
      09-23-2020, 01:26 PM   #19
jmg
jmg's Avatar
18857
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
Real M cars have never been about only 0-60 times. If you want that, get another car. M cars have been about the driving dynamics on a circuit. The M340i gets beat even by a less power full M2. No doubt the G80 M3/4 will demolish it on a track where it counts... if you care about that sort of thing. The G80 competition with the auto is sub 4 seconds. My F80 is sub 4 seconds... it's not the be all that end all.
Such a ridiculous thing they decided to do, make the M3/4 heavier than its predecessor.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
Ibiza3636.50
Kankles1485.50
      09-23-2020, 03:07 PM   #20
TheObviousChild
TheObviousChild's Avatar
323
Drives: '23 M3 Comp xDrive - '21 X3M40
As is tradition
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i
      09-23-2020, 03:10 PM   #21
TheObviousChild
323
Yes!
Speaking of, honest question I can't seem to find an answer to. I know the AWD M3 will be limited to Competition only. Regarding price, all I can seem to find is the $71,800 starting price which I imagine is for Core model. Has anybody floated what they think the starting price for M3 Competition will be? Figure +$3,000 on top of that for xDrive.
      09-23-2020, 04:39 PM   #22
Wills2
Barge driver
Wills2's Avatar
Drives: 730d
They got heavier with every iteration e30 onwards only the move from E9* to F8* lowered the weight a little.
But they are at the edge of how quickly a front engined rear wheel drive car can accelerate to 60 hence not much of a move forward if at all.
730d/Z4C
g80
